02-01-2016, 09:14 PM | #715 | |
Drives: 2013 FRS
I'd be happy just to make it to the store and back... I have no intentions to seriously track the car or beat on it in anyway, not like I can right now anyway! lol I'm glad some have had no issues, gives me hope we can figure out mine! |
02-02-2016, 03:13 PM | #716 |
Drives: anything you let me
Has anyone put together a 'just in case' list? Small odds and ends that you should/might need to change while everything is apart? ie, if you're higher mileage maybe injector o-rings, intake gaskets, exhaust gaskets, etc.
Basically anything that might leave the car in pieces while you wait for delivery of a $.30 part? |
02-02-2016, 03:21 PM | #717 | |
If you're getting aftermarket injectors to use with your kit, they will include all of the o-rings, and every intake manifold gasket I've seen has been in good condition so far, but I haven't seen many cars with more than 50k miles on them. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Uplink (02-02-2016) |
02-02-2016, 03:49 PM | #718 | |
Drives: 14 BSP Edelbrock BRZ
02-02-2016, 03:49 PM | #719 | |
The Following User Says Thank You to Uplink For This Useful Post: | CSG Mike (02-02-2016) |
02-02-2016, 05:45 PM | #720 | |
Drives: 2013 FRS
The provided bolts are M4x10mm, at least on the MAF housing that was included in my kit, the bolts bottomed out 4mm too soon, they would not go far enough into the MAF housing before even get close to the MAF mounting plate surface. They are too small to cut down successfully. I found some M4x6mm bolts at a well equipped hardware store. At least one other person confirmed they had to find a solution to this problem using washers/etc... |
02-02-2016, 07:39 PM | #721 |
Drives: 2013 FRS
I shot some GoPro video of startup and idle with a walk around and poke into all the components of the kit.
I did notice there was no initial startup rumbling sound this time. It also just happens to be behaving for the past few drives randomly... possibly they are realated?? If not, I'm thinking it might have been the clutch release bearing or tranny output shaft making the noise. It just started happening after the install so I thought it was the SC, I'll have to see if it comes back to comment more on that. Closer to the end when I put the camera near the top of the manifold you can hear the grinding kind of noise it makes, but listening to others that is probably normal/typical. Let me know if you see anything out of place. I doubt it, since I've checked it over so many times... [ame="https://www.youtube.com/watch?v=1z_gRxz-4wo"]FR-S Edelbrock Install startup and walkaround - YouTube[/ame] |
02-04-2016, 11:02 AM | #722 | |
Drives: '13 BRZ | '04 E55
My car was sitting over 60k when I did my install. All gaskets were in great shape. The injector seals were a little dirty, but they cleaned up fine. So I ended up not replacing any, but I could see how these could be the little ones that would cause a hang up.
The Following User Says Thank You to NotSoJDM For This Useful Post: | Uplink (02-04-2016) |
02-04-2016, 11:03 AM | #723 | |
02-04-2016, 01:40 PM | #724 |
Drives: 2013 FRS
Can someone post a screen shot of their ECUTek page which has the Map Access button? I'm thinking I'm missing a bunch of tabs from mine, but I'd like to compare with someone who is using this kit. Mine is attached.
02-04-2016, 02:12 PM | #725 |
Looks right to me. What features were you looking for that you don't see?
02-04-2016, 02:16 PM | #726 | |
Drives: 2013 FRS
I was checking with ECUTek about my strange disconnects and they asked for a few versions/values, but cannot find them. Attached is their screen shot, which I cannot find on my software. |
The Following User Says Thank You to 86fun For This Useful Post: | NotSoJDM (02-04-2016) |
02-04-2016, 02:19 PM | #727 |
You are not seeing some of those tabs because they are locked from viewing/editing by Edelbrock in the CARB tune. Maybe Edelbrock support can give you that info. I haven't looked through ECUtek enough to know for sure if there is anywhere else you could find it.
The Following User Says Thank You to NotSoJDM For This Useful Post: | 86fun (02-04-2016) |
02-04-2016, 02:32 PM | #728 | |
Drives: 2013 FRS
Yes, this must be so, Edelbrock was able to send me the version info I needed and am unable to view myself. |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
