Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-22-2012, 06:15 PM | #43 |
provided that they follow the trend from previous cars. a lot of the time monotubes can have rougher ride because of the way they have to be valved but i think tein has some microvalve gimmick that counter acts that
07-22-2012, 06:25 PM | #44 |
Vtec Jesus
Maybe older monotubes... Mono tubes and react faster and have a better ride quality than a twin tube.
07-22-2012, 06:30 PM | #45 |
i think that ride quality is more a function of using monotube on higher quality applications because they have certain inherent advantages like staying cooler and being less prone to hysteresis. i understand they react faster simply because of lower piston speeds. with those lower piston speeds though the accuracy of the valving is reduced and thats why you see components with surgical precision
The Following User Says Thank You to fatoni For This Useful Post: | Matt Andrews (07-22-2012) |
07-22-2012, 07:17 PM | #46 |
give us this day
Drives: AE86 - FRS
but there should be an aftermarket camber plates that can work with the kw v3's right?
07-22-2012, 08:02 PM | #47 |
Drives: Legacy GT
Yes, basically anything for a GD (02-07) Impreza. Racecomp Engineering/GTWorx, Turn in Concepts, Ground Control, and Vorshlag all have great options.
07-22-2012, 10:00 PM | #48 |
Drives: 2013 FR-S Asphalt
I am using and usually recommending the Whiteline offset mounts for mostly street cars... Nice and quiet, you get more camber and caster. And if you go with KW's you still have camber adjustment on the strut (remembering that you are already gaining over -1 from the mounts to start with).
02-05-2013, 07:25 PM | #49 | |
Drives: 2008 CIVIC SI, 2013 BRZ, 2013 M5
I respect you. Cheese |
Similar Threads | ||||
>>>> KW Variant 3 Coilovers ~ Now Available for FR-S and BRZ !!!! | Circuit Motorsports | Brakes, Suspension, Chassis | 56 | 10-25-2012 02:55 PM |
D2 coilovers | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-27-2012 03:50 AM |
Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 03:24 PM |
Coilovers? | trueno86power | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 32 | 05-29-2012 05:20 PM |
coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 08:49 PM |
