Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
03-23-2018, 04:26 PM | #15 | |
humfrz |
03-23-2018, 04:26 PM | #16 |
ಠ_ಠ
Drives: 860 SansOverspray
Can't be worse than the new corolla with the led lights, or the Cx5 or all of them old beaters with misaligned HID conversions.
03-24-2018, 02:27 PM | #17 | ||
Drives: 17 Asphalt 86
Thank you everybody for the responses!
Now that I have driven the car a little more I notice it bounces around on bumps which causes the lights to flick up and down. Coming up hills somebody gets a face bull of headlights. When I am in trafficthey seem to be at a reasonable level. Everybody who has ridden in the car has been blown away by how effective these new LED headlights are. No, they are not. The foglights only come on with the low beams. Quote:
I have appointment with the dealer to fix minor dents in the body from sitting on the dealer lot. I will be asking them about the adjustment out of curiosity. |
03-24-2018, 02:39 PM | #18 |
ZWEI KOLBEN
Drives: 2017 86 Halo 6MT
The projector headlights on the 14-16 Corolla are the brightest things on the road. They run at reduced level for DLRs. The 17 86 has OK headlights, but they are nothing compared to the Corollas.
03-24-2018, 09:45 PM | #19 | |
Drives: ‘16 4Runner, ‘19 Corolla HB
So much this. It is one of my pet peeves. Fog lights are there for lighting the area just in front of your car in heavy fog. If you run them in normal conditions you are just making your own visibility worse. Think about it this way. Your eyes adjust to the available light. If you are traveling 70mph down the freeway, your eyes should be looking where you will be several seconds later. At 70mph, that is far down the road. If you have a more intense light aimed at the pavement directly in front of your bumper, your eyes will consider that light when adjusting. Running your fogs in clear nighttime conditions effectively takes in useless data when determining how your eyes should adjust. Sent from my iPhone using Tapatalk |
03-25-2018, 09:32 AM | #20 | ||
In my '13 BRZ I get flashed constantly by oncoming traffic and have since I got the car. I tend to drive with them adjusted quite low too, usually on 2 or 3 on the height adjuster but that doesn't seem to matter. I've been pulled over 3 times for my lights being too bright and try to show the officer that I have them set low and tell them that they are stock lights. Twice I've had to go prove that they are stock within 24 hours of being pulled over (fix-it ticket) and one of those times necessitated a hotel room stay overnight because I was 200 miles from home and didn't want to go round trip to take care of it. I hate that I keep them adjusted so low because I outdrive them at speeds over ~50mph. |
03-25-2018, 12:56 PM | #21 |
Dismember
Drives: 2013 Red Scion FR-S
Just shitty headlights then. This is why the IIHS tests glare, though not on our cars. This is also why I'm not a huge fan of HIDs and the like. Though they do a great job of lighting the road up, they often blind others. Personally, I'm just interested in the brights. Everywhere I drive, there's plenty of light or I use my brights. No in between.
03-25-2018, 01:00 PM | #22 | |
Drives: 2013 FR-S Series 10
03-25-2018, 01:29 PM | #23 | |
High end Mercedes LED headlights have sensors that detect oncoming traffic and and dynamically shut off individual zones of the LED projector to reduce oncoming traffic from being effected by bright lights. With regards to these headlights I haven't had issues since shutting off the fog lights. I will double check with the dealer to ensure the headlights are set correctly. |
03-25-2018, 10:06 PM | #24 |
Dismember
All sorts of fancy tech, but the luxury cars aren't built to last anymore. Nothing but issues with a 5-year-old BMW. Not going there again anytime soon.
03-25-2018, 11:33 PM | #25 | |
Drives: S2000
In what way? The 17 86 headlights have the same projector housing as the BRZ right? Ive seen the BRZ, and it is extremely bright. Not sure how good the coverage of the light is though. |
03-25-2018, 11:39 PM | #26 |
Drives: 2017 BRZ
03-25-2018, 11:59 PM | #27 |
義理チョコ
Plain ol' stock halogen FTW.
The Following User Says Thank You to Ultramaroon For This Useful Post: | EAGLE5 (03-26-2018) |
03-26-2018, 07:47 AM | #28 |
Similar Threads | ||||
Is my ECU flashed? | Italian | Software Tuning | 13 | 07-08-2016 12:16 AM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
Just flashed OFT Stage 2 UEL | Luftwaffel | Software Tuning | 14 | 11-30-2015 09:33 PM |
Just flashed 2015 FRS with OFT | Flat_4_Life | Software Tuning | 4 | 03-23-2015 09:22 PM |
Flashed ECU | Djen | Software Tuning | 5 | 08-13-2013 09:00 AM |
