Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-19-2014, 08:13 PM | #1 |
Drives: 2013 Crystal Black BRZ Limited
water trickle noise 'n' wet floor
On the way to dinner I hear this water trickling noise thought it was weird but wasn't sure where it came from. Take a turn and girlfriend tells me it peed on her. Dark out and can't see where it is coming from exactly. Water was not warm and floor is soaked. Got worse when heater turned to higher temp. Any ideas?
09-19-2014, 09:04 PM | #2 |
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
Is this real life
The Following 3 Users Say Thank You to samisons For This Useful Post: |
09-19-2014, 11:03 PM | #3 |
Could be the A/C drain hose is clogged and the water is coming out from under the dash.
Could be the heater core is leaking ...... does it smell like anti-freeze .. ?? Was it raining outside when this happened .. ?? humfrz |
09-20-2014, 08:27 AM | #4 |
Yes this is real life.....Got some time and a good light after dinner, looked into it. It is definitely the a.c. drain line clogged somehow. I pulled the drain hose and if I blow into it I can hear the bubbles inside the housing. However if I suck on the hose I can't get anything. It is deep, if I turn the blower on high I can hear the water getting picked up by it. Im just out of warranty so ill see if I can convince them to fix it since it looks like a pita to disassemble that shit.
The Following User Says Thank You to 2_slo For This Useful Post: | samisons (09-20-2014) |
09-27-2014, 10:58 AM | #5 |
Drives: white Sport-tech
Where is this ac hose under the dash specifically? If been battling a musty smell and occasionally hear trickling water, thanks in advance
09-27-2014, 11:16 AM | #6 |
Drives: hot lava frs
Theyre just gonna take an air nozzle and blow into the drain to clear the clog.
09-27-2014, 11:27 AM | #7 | |
Drives: '13 FRS - STX
*pro-tip it's that black line in the center running vertically |
The Following User Says Thank You to strat61caster For This Useful Post: | Packofcrows (02-27-2019) |
09-27-2014, 12:16 PM | #8 |
IT IS the A/C Drain Hose; either its clogged or became disconnected someone. Same problem happened with me and the dealer fixed it under warranty
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
Similar Threads | ||||
Road noise? Tread Noise? | zERoTu | Issues | Warranty | Recalls / TSB | 21 | 10-07-2020 10:21 PM |
water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 02:57 AM |
New cars and tuning...will this trickle down to the FT86 | LexusFman | Engine, Exhaust, Transmission | 1 | 12-15-2011 08:58 AM |
