12-18-2019, 11:26 AM | #8779 | |
Drives: '14
I had the same issue too, my tuner just sent me a revised tune and it cleared it up. |
12-18-2019, 03:26 PM | #8780 |
Drives: 2013 GT86
Thanks Kev0. I was hoping to solve it before I bothered Mike. I know he gets a lot of troubleshooting and 9-10 times it's user error. I noticed a few posts reporting similar problems. So I unplugged the MAF sensor and it started up fine. I then turned it off, plugged in the MAF and tried again. It started.. but idled really really horrid. Perhaps the MAF needs a spray clean?? I mean it was fine before but I did have the airbox sitting on my garage bench for a month maybe it gathered dust?? Seems unlikely. Maybe I need to bother Mike after all...
12-18-2019, 04:36 PM | #8781 | |
Drives: 2017 toyota 86
Clean your maf, double check all connections, grounds, and hose clamps. Then if it still persists hit up mike with your problems and your findings from troubleshooting, if it starts fine without MAF that is info i am sure will help him resolve the issue if its tune related. |
12-18-2019, 07:36 PM | #8782 | |
Drives: 2013 GT86
I'll see what Mike says. Might as well clean the MAF just in case it's that. |
12-18-2019, 08:03 PM | #8783 | |
Drives: '14
12-18-2019, 08:12 PM | #8784 | |
Drives: 2013 GT86
I thought I was being clever replacing the bolt with a stud! |
12-19-2019, 02:56 AM | #8786 |
Drives: 2013 GT86
Ok I’ve done that and yeah it made a difference. Lol here I was thinking I was clever replacing that lower bolt with a stud! Why did they do it like that!
Anyway, it started up and ran fine.. for a few minutes then died. Then didnt really want to start again. Managed to get it to start and nursed it with the accelerator for a moment but then it died again and wouldn’t run. I cleaned the MAF sensor and put it back in. Car started up and ran again nice.. then died. It’s like it doesn’t mind starting when it’s cooled down but as soon as it get warm after a minute it does the same thing. It idles at about 1200rpm for about half a minute, then the revs go up momentarily to about 1700rpm and then it dies and doesn’t want to start again until it sits for a while. So it seems like I have another / different issue to figure out. Edit: I'm wondering if the fact it runs on the start up loop.. maybe I have a port injection leak. So when it warms up after about 30sec and switches to port inj it leaks and dies? Last edited by tzbang; 12-19-2019 at 03:29 PM. |
12-21-2019, 12:30 AM | #8787 | |
2013 Series 10 FRS #553
12-21-2019, 01:17 AM | #8788 | |
Drives: '14
12-21-2019, 11:54 PM | #8789 |
Thoughts guys. Starting about few months ago my car starting to at idle and no throttle will max STFT positive and eventually maxes out LTFT. During normal driving FTs will fall back to normal. Based on reading I have a vacuum leak somewhere. What and where should I look. Also could this be caused by the SC itself if the seals are starting to go? My unit does leak a bit of SC oil under high loads.
Otherwise it seems to drive fine. Can't tell if I have lost a bit of power since I got the SC Installed. Boost is still there for sure just may not pull as hard or I am just used to it now Sent from my GM1915 using Tapatalk
12-22-2019, 12:29 AM | #8790 | |
Drives: '14
Replacing my bypass actuator next week to see if it fixes the issue. |
12-22-2019, 12:33 AM | #8791 | |
12-22-2019, 12:36 AM | #8792 | |
First i would clean maf, and double check all fittings on intake cold weather makes things shrink and worm clamps don't shrink with changes like spring clamps. could always try spraying some brake cleaner or do a smoke test to find a leak. |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
