Old 10-06-2015, 05:16 PM   #15
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Love how you documented your build and your thought process(so I know you are not made of money or an idiot either). My main concern is the weight and balance of the car..do you have any numbers or thoughts on that?
Great job!
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
The Following User Says Thank You to Swift For This Useful Post:
Manji (10-11-2015)
Old 10-06-2015, 08:19 PM   #16
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Great job!
Thanks.
Re:balance. I've got an idea of where it's sitting but want to wait till I've corner weighed it. Problem is, I've since moved out of the city into a regional area, and the local tyre places don't have what I need. Tempted to buy some corner scales for myself just seems a waste when I'm just doing it for one weigh. I intend on going back to the city for Xmas and then I can take it back to the place I weighed it when it was stock.
Based on weighing the components that went in and out, I reckon I've picked up about the same weight as a stock 86 with a FI kit. My box weighs more, but its a shit ton stronger. But I've also got lighter brakes and front wheels. I could've not put in air con, but I wanted it. (I think I'm the only motor swap that has all OEM features working, aids/cruise/PS/AC etc etc)
When I weighed it bone stock (I have the base model with 16" wheels etc) it was 1198kg with a quarter tank. Say 1180kg without fuel. I'm fairly confident I'm in the 1220-1250kg bracket now. Balance I don't suspect to have moved a great deal. Larger box and axles etc. Even if it has say 20-30kg heavier over the front axle than it was, it would be a better driver than I to feel it. And if I was that worried about 20-30kg then I could stand to loose 20kg myself. Ha ha.
Truth be told it handled like a dog in the video I posted the other day. The spring rate is too firm, going to go softer. The dampers I didnt even check their setting. And what I think was having the most effect, the swaybars are still sitting in my garage.
Manji is offline   Reply With Quote
Old 10-06-2015, 08:21 PM   #17
tirespin782
Drives: 02 s2k, 08 350z, 08 Fit sport
I was looking at you pics again and I may have missed if you mentioned it, but did you keep the OEM power steering? In one of your pics I saw a container at the front of the engine driver's side (?) that reminded me of a power steering reservoir?
Also, really to bad your tuner is not making that wiring harness for sale. I'd think there would be a nice market for it. I'm seriously considering following your path once I finish my graduate program.
tirespin782 is offline   Reply With Quote
Old 10-06-2015, 08:44 PM   #18
Manji
Manji's Avatar
Not sure what the reservoir you saw was, but def kept the oem ps.
Old 10-06-2015, 09:19 PM   #19
tirespin782
Ah, thanks. It's the 5th pic after your alignment specs sheet pic on your FB page.
Old 10-06-2015, 09:32 PM   #20
Manji
Manji's Avatar
Ah. That's not my car. Was a pic of a 1uz in another car I looked at before starting my project. Have deleted.
Old 10-06-2015, 10:36 PM   #21
tirespin782
That makes sense. I was curious about the engine bay color difference, but thought it was a mock up setup.
I saw your dyno of this block and remember reading somewhere this block was good for 300-330 NA whp? That dyno showed 230 whp. If it's not proprietary, what's your plan to getting to 300?
Old 10-06-2015, 10:52 PM   #22
DarkSunrise
DarkSunrise's Avatar
Sounds incredible, very well done!
2022 BRZ Build
2013 FR-S Build
Old 10-06-2015, 11:03 PM   #23
Manji
Manji's Avatar
Andre's dyno is reading very low. Stock fa20 only reads barely 110kw on it.
Here's a comparison dyno between the two. Sorry don't have a better copy, was just a screen shot from a phone.
Tells a few stories. Numbers aside, you can see the gains are significant. Look at the power I have at 3200rpm, pretty much peak fa20 power. Problem with chasing a peak hp number (I'm not, I always wanted driveability) is that you need revs. HP is torque times revs. Hard to make one without the other etc. To make say 100 more whp, it just needs to rev more. Head work and cam work etc. We measured this the other week and looks as if could only get about another 8 degrees of duration in the cams before fouling, hardly worth it. So that means would have to do a different piston design to do headwork that would be worth it. So now its a $15k exercise, which ruins the whole point of using the 1uz in the first place.
Its a different car to drive now. Where as it used to be like a sewing machine, keep revs high or else, now I don't have to wait for the power, its there in the revs where you spend 98% of driving.
Sure I'd love it to rev to 8000rpm and make 400whp but then it wont be as smooth down low. More so, it'll cost far too much money. It would be cheaper to turbo it (if chasing a number), but that seems like such a waste with regards to the headers.
Here's a local guy's 1uz turbo setup. vs his previous worked sr20 setup. You can see the huge differnce in torque, but the hp doesn't show anywhere near the same, because different rev ranges.
The Following User Says Thank You to Manji For This Useful Post:
CxG (10-09-2015)
Old 10-08-2015, 10:50 AM   #24
CxG
Drives: Pearl White '13 ZN6
awesome work man keep it up. Do you know how much heavier that 1uz is than the fa20? did it throw off the handling of the car or is it barely noticeable
CxG is offline   Reply With Quote
Old 10-08-2015, 03:17 PM   #25
Manji
Manji's Avatar
It handled like a dog last time I drove it, but I'm putting that down to the fact the swaybars weren't in. I want to get them in and see how it feels.
CxG (10-09-2015)
Old 10-08-2015, 05:34 PM   #26
tirespin782
So it would be reasonable to say, outside of cams, your current power level is about capped without getting into an expensive build (NA or FI) for your motor?
If so, does this make the new positive displacement blowers (edlebrock, Harrop) look like a reasonable alternative cost/performance wise?
Old 10-08-2015, 07:59 PM   #27
Manji
Manji's Avatar
No I don't think so. I had a PD blower on mine 2 years ago (Bullet) and it offered no where near the performance of the v8. Sure it might hit the same peak number, but the low down torque wasnt there. You could load boost up the fa20 down low easily enough, but the rods wouldn't take it.
The Following 2 Users Say Thank You to Manji For This Useful Post:
cf6mech (10-09-2015), CxG (10-09-2015)
Old 10-09-2015, 01:22 PM   #28
CxG
Let me know how that goes I love this swap and build man major kudos
Sent from my D5803 using Tapatalk
The Following User Says Thank You to CxG For This Useful Post:
Manji (10-09-2015)
Aerocatch hood pins, anyone got pics and comments? K-NoMs Cosmetic Modification (Interior/Exterior/Lighting) 3 08-28-2014 12:51 PM
Custom Cat-less Exhaust (Pics & Vids) Ch3cho86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 03-08-2013 01:44 AM
2JZ GT86 first Drag test, 11.1@220km/hr (vids) Bahraini86 Tracking / Autocross / HPDE / Drifting 4 02-07-2013 09:12 AM
Norcal: Alice Meet Official Pics and Vids Thread 86_ZN6 Southern California 21 08-01-2012 11:34 PM
Yokohama Ride & Drive with Scion FR-S ( pics & NOW VIDS ) gatorfan462 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 05-17-2012 04:30 PM
