Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-20-2017, 12:59 AM | #1 |
Drives: raven FRS
Oil leak under intake!
Oil build up/ or leak under intake ? Is this normal for N/A set up? Need a catch can?
Leak by Louis li, on Flickr
IACRO RAVEN86
https://www.instagram.com/louislee0828/?hl=en Last edited by snk828; 11-20-2017 at 01:10 AM. |
11-20-2017, 02:49 AM | #2 | |
http://www.ft86club.com/forums/showthread.php?t=123110 No, that's not normal. I don't believe a catch can is going to fix it. You might start by checking the PVC valve and its hoses and connections. I suggest you clean up the area and see if reappears. humfrz |
11-20-2017, 04:18 AM | #3 | |
Drives: raven FRS
IACRO RAVEN86
https://www.instagram.com/louislee0828/?hl=en |
The Following User Says Thank You to snk828 For This Useful Post: | humfrz (11-20-2017) |
11-20-2017, 12:02 PM | #4 | |
Back-in-the-day, when something on my car leaked, I started by torqueing (just tightening in those days) the bolts/nuts that held the suspect pieces together. If that didn't fix it ...... I would go get a gasket kit and some permatex, take the part off, goop up the gasket real well and slap it back on ......... OR ...... just live with it ....... the barn floor was dirt and absorbed oil real well. I'll defer to others to recommend what to do these days ...... humfrz |
11-20-2017, 12:47 PM | #5 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I just live with my timing cover leak until I feel like taking it off to reseal. And it's been leaking for a while lol |
The Following User Says Thank You to finch1750 For This Useful Post: | Ultramaroon (11-20-2017) |
11-20-2017, 01:20 PM | #6 | |
Really! Leaks don't hurt nutten if they aren't leaking on something that is not supposed to have oil on it, or, dripping on something that burns it, creating a bad smell ..... or ...... the leaking unit runs low on oil. In the latter case just add some more oil. In the former cases just get a drip pan. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | finch1750 (11-20-2017) |
11-20-2017, 01:23 PM | #7 |
Drives: 2003 S2000, 2008 Fit
11-20-2017, 01:29 PM | #8 |
Heck, after all, I suspect that back-in-the-day that some of ol @Tcoat 's cars created, what today would be considered, an EPA superfund clean up site ..........
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | chaoskaze (11-21-2017) |
11-20-2017, 01:32 PM | #9 |
11-20-2017, 01:58 PM | #10 | |
Now I must confess that I probably sprayed much more coolant on the ground than any one person should have ever have been entitled to.
The Following User Says Thank You to Tcoat For This Useful Post: | chaoskaze (11-21-2017) |
11-20-2017, 02:15 PM | #11 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (11-20-2017) |
11-20-2017, 02:32 PM | #12 |
Try this one:
[ame="https://www.youtube.com/watch?v=3VgufM9iLbI"]Crying Indian - The Single Tear - YouTube[/ame] But you got the gist of it: It is a short clip of a Native American shedding a single tear. Although there's a poetic nature to it all: the oil came from the depths of the earth, and to the depths of the earth it shall return. Ashes to ashes and all that... |
The Following 4 Users Say Thank You to daiheadjai For This Useful Post: |
11-20-2017, 02:37 PM | #13 |
義理チョコ
VW engines with cork valve cover gaskets and those shitty pushrod tubes.
11-20-2017, 02:55 PM | #14 | |
After all, mother nature NEVER got sloppy ....... cepten at places like the la brea tar pits ........ humfrz |
Similar Threads | ||||
Oil Leak | Brz_racer | Engine, Exhaust, Transmission | 22 | 07-17-2017 04:28 PM |
Intake manifold leak | Diz86x | Engine, Exhaust, Transmission | 5 | 07-13-2017 12:42 PM |
oil leak ! | frsqc | Issues | Warranty | Recalls / TSB | 5 | 07-01-2015 07:08 PM |
Oil leak. | ohnoitsthefuzz | Issues | Warranty | Recalls / TSB | 2 | 03-23-2015 01:31 AM |
A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
