DIY (Do-It-Yourself) Guides For all DIYs. |
09-07-2015, 12:48 PM | #43 | |
Drives: 2018 Cayman, 2013 FR-S
09-07-2015, 01:04 PM | #44 | |
Drives: 2014 FR-S 6MT Whiteout
Yes, there is a gasket that goes in there.
09-11-2015, 02:16 PM | #45 |
Drives: Asphalt Scion FR-S
question about the muffler to midpipe bolts... lol. i accidentally stripped the head on the bottom one... can i just pick up areplacement at walmart or lowes?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
09-11-2015, 03:33 PM | #46 | |
Get some Grade 5 or 8 machine bolts from Lowes or Fastenal. I had to hacksaw mine apart when I put the Nameless muffled track pipe on because the stock bolts rusted so much.
09-12-2015, 09:28 PM | #47 | |
Drives: 2015 Subaru BRZ; 2001 Mazda Miata
Great DIY!
09-13-2015, 10:50 PM | #48 |
i did the same thing, with the same part. i got the old bolt off but i do need to replace it here soon
11-04-2015, 10:54 PM | #49 |
Drives: 2013 frs; 1988 porsche 944s - > 948
quick question on aftermarket overpipe
any possibility of re-using the factory heat sheilds on an aftermarket overpipe?
seems like there would be some heat on the aftermarket overpipe to try to mitigate but maybe its larger size makes this impossible? thanks in advance |
11-05-2015, 08:07 AM | #50 | |
No, they're quite specific to the bends and bobs of the stock piece. Most aftermarket parts are also larger diameter.
11-05-2015, 12:50 PM | #51 |
Senior Misanthrope
If you're concerned about heat, a ceramic coating would be your best alternative.
11-05-2015, 08:25 PM | #52 |
This all makes sense that those heat shields can't be Re used but what performance could be sacrificed by presenting a source of heat with a bigger overpipe. From what I have seen there isn't much gains in an overpipe swap, the big win is in the header. Could the be any truth to having best performance with stock overpipe and heat shield with after market header to prevent heat leaching that would be presented from an aftermarket overpipe?
Just asking for discussion and experience here |
11-11-2015, 09:30 PM | #53 |
Are you 20/20?
Drives: Hopes and dreams
Thanks for this! It helped a lot, although install wasn't that hard. Heh.
Similar Threads | ||||
Exhaust tip removal | Draco-REX | Cosmetic Modification (Interior/Exterior/Lighting) | 97 | 05-27-2017 05:50 PM |
T1R exhaust for the FRS/BRZ ! | AJ PwR | Engine, Exhaust, Transmission | 57 | 06-22-2013 10:39 PM |
AVO Exhaust | Blaaaack-BRZ | Engine, Exhaust, Transmission | 22 | 10-16-2012 11:28 PM |
HKS Exhaust | 01s0uljah | Engine, Exhaust, Transmission | 1 | 05-18-2012 09:15 AM |
Exhaust system: dual or single | KiingDavid | Engine, Exhaust, Transmission | 163 | 05-04-2012 01:33 AM |
