go_a_way1
Old 04-08-2015, 06:11 PM   #2059
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Xuningshen View Post
I find it hard to believe that flywheel, crankshaft, whatever other crap is attached, would INSTANTLY stop climbing revs once you cut fuel/spark.
please... please... dont respond to me in analogies.
This is because you are thinking of RPM as distance. RPM are not distance. RPM represents velocity.
You are thinking "the needle is moving through the RPM range so FAST! Surely it wont just stop instantly". The reality is that when the RPM needle stops, it doesn't mean velocity of the crankshaft is 0, it means the acceleration of the crankshaft is 0 and velocity of the crankshaft is whatever it stops at. If the needle stops suddenly at 7,000 rpms, the crankshaft is spinning at 7,000 rpms. It cannot go any faster unless it has a force acting on it (ie combustion).
Simply:
A. Watching the needle sweep through the rpm range means the engine is accelerating (engine speed is changing)
B. When you let off the gas, the needle will stop moving. This means the engine is not accelerating (engine speed is constant).
C. needle will start to come back down. This means the engine is decelerating.
The Following User Says Thank You to sw20kosh For This Useful Post:
0351USMC (04-08-2015)
Old 04-08-2015, 06:35 PM   #2060
Xuningshen
Drives: Subaru BRZ
Simply:
I'm not thinking of it as distance....
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 04-08-2015, 07:01 PM   #2061
waterbison777
Regarding the figure skating analogy...
If we cut her in half while she's spinning, aren't we reducing her effective mass, consequently instantaneously reducing her moment of inertia and providing a means for increased RPM?
waterbison777 is offline   Reply With Quote
Old 04-08-2015, 07:07 PM   #2062
sw20kosh
No it has to do with where the mass is in relation to the center of spin. If you have an elephant on a spinning marry-go-round, when the elephant jumps off, the marry-go-round doesn't spin faster.
Now if the elephant is initially on the outer edge of the marry-go-round, and he now moves closer to the center, the marry-go-round will spin faster.
Old 04-08-2015, 07:24 PM   #2063
sw20kosh
The thing people are getting confused by is that when you are comparing the:
RPM needle moving up the rpm range
vs.
Ball being thrown up into the air
The RPM needle moving up the rpm range is a representation of acceleration. Acceleration can absolutely become 0 instantaneously. When the throttle plate shuts (when combustion stops) = acceleration becomes 0. Acceleration needs a force and when you take away that force acceleration becomes 0. This is why the needle stops moving instantaneously. Velocity stops increasing.
You can use the ball analogy but you have to take gravity out of the equation. If you are standing in space and you throw a ball towards the moon. The moment it leaves your hand, acceleration becomes 0. This is exactly like taking your foot off the gas and watching the RPM needle stop moving. The velocity of the ball remains equal to the velocity it reached right as it left your hand. The RPM of the motor remains the RPM of the motor right as you let off the gas until other forces (friction) pull (decelerate) the RPMs down. If the ball in space traveling at a certain velocity now entered a cloud of space debris, friction would slow it down too and its velocity would decrease (ball would decelerate just like an engine would),
Thorpedo (04-11-2015)
Old 04-08-2015, 07:24 PM   #2064
waterbison777
I can see that... if the elephant is modeled as an infinitesimal point. Then the moment of inertia is preserved if the elephant is in the center of the merry-go-round and it jumps off.
But what if the elephant is the same diameter as the merry-go-round? We're effectively changing the moment of inertia because mass is being removed where r>0, relative to the CoG...
Old 04-08-2015, 08:31 PM   #2065
Xuningshen
Drives: Subaru BRZ
vs.......
Isn't acceleration the rate of change? Can an object with mass and inerta who's rate of acceleration is "pretty fast" (I'm so scientific and eloquent) become 0 instantly?
2014 WRB BRZ
Old 04-08-2015, 09:13 PM   #2066
sw20kosh
Yep. Think of throwing a bowling ball down a lane. The ball is accelerating super fast while it is in your hand but once it leaves your hand it's acceleration is 0 and then starts to decelerate due to friction. If there was no friction it would maintain a constant velocity (no rate of change).
Old 04-08-2015, 09:19 PM   #2067
dp1
driving smoother faster
Drives: Sold
Let's derail this thread by writing something about Jackson Racing SC
dp1 is offline   Reply With Quote
The Following 7 Users Say Thank You to dp1 For This Useful Post:
0351USMC (04-08-2015), CSG Mike (04-08-2015), Dream20b (04-11-2015), drewbot (04-29-2015), HaloFRS (01-20-2016), PikachuBRZ (01-22-2023), Xero-Limit (04-08-2015)
Old 04-08-2015, 10:03 PM   #2068
bfrank1972
Drives: 2013 FR-S Argento
why don't you guys just think about it like an actual engine instead of all these analogies. they're giving me headaches.
for a simple minded guy like myself. I find it hard to believe that flywheel, crankshaft, whatever other crap is attached, would INSTANTLY stop climbing revs once you cut fuel/spark.
lol, ok ok, maybe it's time for an empirical approach...
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 04-08-2015, 10:05 PM   #2069
bfrank1972
Funny! you're right, sorry guys, just trying to help
dp1 (04-09-2015)
Old 04-08-2015, 11:52 PM   #2070
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Someone send me the link to the thread that continues this conversation
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 04-08-2015, 11:59 PM   #2071
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Yeah I think we can end the whole side convo of the physics and mechanics of the engine as it relates to the seconds after you clutch in.
A tame rev limit is in order, so let's put the analogies to rest.
0351USMC is offline   Reply With Quote
The Following User Says Thank You to 0351USMC For This Useful Post:
dp1 (04-09-2015)
Old 04-09-2015, 11:16 AM   #2072
fasteddy
Originally Posted by mfd1012 View Post
I have always wondered about the time it takes to exhaust the plenum volume with this type of FI design. Is it detectable when driving (throttle response)?
I have the JRSC with the carb tune. I think I have noticed this at high RPM a couple times. I also think Moto Mike probably nailed it with his explanation of the throttle cut style. That sure makes sense to me that the compressed air in the intake system has to go somewhere, unless you are venting it at throttle cut.
OK, I have about 500 miles on mine now. let me just say WOW! this thing is freaking awesome! As many have said this is exactly what this car needed! The power is incredible!
The thing I was most nervous about the install was the computer flashing. In the end that was the easiest part, took five minutes with no drama.
Car starts, idles drives like stock except for the extra power.
My mileage has not been affected more than 1-2 MPG at highway speeds over 70 MPH, other than that it is the same.
The system is very quiet, which I like. There is some minor whooshing sounds from the blow of valve and a faint whine under hard acceleration. Most average people would not even notice the extra sounds.
I did quite a bit of research and am very happy with my purchase. I would highly recommend this kit.
I bought mine from CSG and both CSG and Jackson have been very helpful with all of my questions before and after the sale.
Pat
fasteddy is offline   Reply With Quote
The Following 6 Users Say Thank You to fasteddy For This Useful Post:
*LongFella (04-11-2015), 0351USMC (04-09-2015), CSG Mike (04-09-2015), dj2020 (04-09-2015), dp1 (04-09-2015), Jackson Racing (04-09-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
