11-30-2015, 06:41 AM | #225 |
Drives: 2013 Subaru BRZ
One question. I have been wondering if the 57xtreme 9.5 40 on our cars need a hub rings. 65 to 56 is what i found. Is it required for safety? Thanks!!! It seems there is a mixture of information which concerns me.
11-30-2015, 08:27 PM | #226 | |
Drives: 2014 BRZ
And yes, 65 to 56 is correct. |
12-01-2015, 04:00 AM | #227 |
12-02-2015, 03:09 AM | #228 |
Formula GP~/~
Drives: 13' Brz Limited
Hey, just wanted to let ya guys know (even if you got them already) you do not need hub rings on these wheels. I have them also and another 57 model and they are made for brz nicely. Fits on the $ with the hub
12-02-2015, 03:42 AM | #229 |
Formula GP~/~
12-10-2015, 04:35 PM | #230 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Would these fit on stock struts with lowering springs?
NVM found the answer. Quote:
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
12-11-2015, 05:41 AM | #231 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I like driving!
12-11-2015, 06:39 AM | #232 |
Drives: FR-S Release Series 1.0
The Following User Says Thank You to Mikey2style For This Useful Post: | derekbrz24 (04-21-2017) |
12-23-2015, 04:11 AM | #233 |
Hello~ Just installed my 57xtreme sp spec 18 9.5 40 with RE11 255 35 18 lowered about an inch or slightly more...
My rears seem okay but i see rubbing marks on my front wheel. I have the RSR sports i club racer with camber plates. Haven't messed with the camber plates yet but would changing the front camber a little bit negative prevent further rubbing? and what degree would be ideal for camber in the front. Thanks for your help in advance!!! will post some pix once i adjust the front camber and a car wash. |
12-23-2015, 04:19 AM | #234 | |
12-23-2015, 04:27 AM | #235 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk |
12-23-2015, 04:36 AM | #236 |
@dkstylezz It is probably the side marker or near it. Add camber and you are good. At one inch drop the rear will be about 1.5ish camber, I would say 2-2.5 is good in the front.
If you want to check, you can turn the wheel and look how close it is. You can also stiffen the shocks up a click or two. |
The Following User Says Thank You to swarb For This Useful Post: | dkstylezz (12-23-2015) |
01-07-2016, 03:01 PM | #237 |
Drives: Subaru BRZ Limited
Are these needed? When i ordered these wheels, i was told by the vendor they are not needed. I think in the original spec these maybe had a larger bore? Hard to get a caliper down into the center, but it appears to be around a 56 center bore on the wheels i got, so maybe the newere versions were made to the 56mm bore diameter for our vehicles.
03-06-2016, 10:54 AM | #238 |
Drives: 2013 Subaru BRZ, 1999 Dodge Neon
What lugs to use on these wheels? Would these work?
Tags |
gramlights 57xtreme, toyo tyres |
Similar Threads | ||||
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 | L8Apex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 71 | 08-05-2023 09:20 PM |
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 | jadewbj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 378 | 06-26-2017 05:57 AM |
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 12-04-2014 10:56 PM |
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 | MVJ1975 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 10-05-2013 02:29 AM |
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-05-2012 12:44 PM |
