Software Tuning Discuss all software tuning topics. |
10-05-2019, 12:42 AM | #1 |
Drives: brz
Why is midrange so flat after a new flash?
C
10-05-2019, 07:34 AM | #2 |
Rust bucket enthusiast
Who is tuning it? Are you logging LTFT? Did they change anything with the tune?
Let me try to reword how I'm understanding this. You reflashed the car, it pulls good until 4k, when you have positive boost pressure. After 6k you have built up to 12 psi and the car pulls hard again. 2 days after this, the car pulls good UNTIL 6k and then it loses its power? This sounds like timing and fuel are being bamboozled up top. Check your LTFT and timing in areas where the car bogs in datalogs. Most importantly, let your tuner know. Do you have and datalogs you can share with us? |
10-05-2019, 11:07 AM | #3 |
Please get a turbo blanket, you're defeating your intercooler but not protecting the piping going to your throttle body.
Anyway, without datalogs it's tough to pinpoint causation. I'm assuming that these runs are done WOT and with the car at the same temp? Have you tried reflashing the exact same map right after the car does a "good" pull to see if driving right after results in the issue you're describing? I'm going to assume you're tuning it yourself if you're using Romraider. Can you datalog a good run, a bad run, and present them here? |
10-05-2019, 02:27 PM | #4 |
Not sure, I just know that the goal is to keep the air as cold as possible. The slightly cheaper alternative would be to at least put some gold tape on it, but it looks tacky in my opinion. I'm getting a blanket for mine soon because it superheats everything in the area.
The one advantage you have are the badass track spec hood vents. It rains a lot here and my car gets driven every day so I just can't add vents . For a PTP blanket it's less than $200. I'd say it's worth it with your turbo being so big. |
10-05-2019, 05:21 PM | #5 |
I'm not sure why I thought you had them. Well if you're comfortable with the heatsoak when you're not flat out then it's fine
10-08-2019, 03:33 PM | #6 |
Drives: WORKS CARB Legal Turbo BRZ
When you say flash, are you e-tuning or dyno tuning? You really need to dyno tune it to get the most out of the setup. As far as it getting its midrange back after two days, I would datalog it after a flash, and then datalog after it gets the midrange back and compare the two side by side. It may be difficult but it can be done. This is really all the advice anyone can give without seeing the logs. Well.... this may be happening but I dont know. On some of these vehicles, the Exhaust cams don't like to swing for a while after flashing. We've experienced this a few times, but the problem is very pronounced. What you could do is just plug in and log VVt Exhaust and see if it shows any angle change when you blip the throttle (sitting still is ok).
10-09-2019, 10:13 AM | #7 |
Is there a reason you won't give us datalogs? https://datazap.me/ lets you upload them for free.
The Following User Says Thank You to DarkPira7e For This Useful Post: | wparsons (10-09-2019) |
10-09-2019, 11:59 AM | #8 |
The Fail Boat
Drives: CWP S.B.
YOUR INTAKE TEMP is probably around 180f or more. knock knock.
The Following 2 Users Say Thank You to chaoskaze For This Useful Post: | DarkPira7e (10-09-2019), wparsons (10-09-2019) |
10-10-2019, 12:17 PM | #9 |
The Following User Says Thank You to DarkPira7e For This Useful Post: | tomm.brz (10-10-2019) |
10-10-2019, 04:00 PM | #10 |
Drives: 2013 Ultramarine FR-S
Takes a bit for everything to settle and learn after a reset.
p.s. That is a huge turbo
11-27-2019, 11:39 AM | #11 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
11-27-2019, 03:16 PM | #12 | |
LOL, not intake temp... ambient temp of the header (or this case the turbo housing)... like, if you just got done driving your car, opened the hood and grabbed hold of your turbo, you'd rebrand your fingerprints. But if you had a turbo blanket, you could tell "hey, this is pretty warm, I should let go before I get burned." 90°F to 100°F isn't that bad for IAT's. The turbo blanket may reduce IAT by 10°F, but it'll also protect plastic and rubber parts around the turbo that probably weren't designed to withstand that kind of heat-cycling. Also.... press ALT+0176 on a keypad for degrees °, press ALT+0177 for plus and minus ±. |
Similar Threads | ||||
Midrange speaker in dash? | yomchi1989 | AUSTRALIA | 59 | 10-15-2022 03:39 PM |
WTB: 4" midrange speakers | rva_86 | Want-To-Buy Requests | 0 | 10-23-2018 11:42 AM |
OEM Audio + 4" midrange upgrades | ft86me | Electronics | Audio | NAV | Infotainment | 11 | 04-07-2017 08:57 PM |
Open flash tablet Flat Floot shifting | 7Seraph | Software Tuning | 1 | 03-11-2016 03:27 PM |
EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
