Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-26-2013, 09:50 PM | #29 | |
Drives: 2013 Black FR-S
@King Tut Picture of where it sits in the manifold tomorrow. |
11-27-2013, 07:39 AM | #30 |
Drives: 85 corolla gts
Unfortunately it is a nice and simple design but the sensor sits out side the direct air stream. There is a port that leads to it and it does give you a better idea of what is going on. It would be more effective to move the sensor into the direct air stream. I would recommend keeping the normal plate for the map sensor in place and drill and tap the manifold to put the sensor in after the blower / intercooler to get a more accurate reading. You can get a gm open element sensor kit with the connector for around 35 to 45 dollars, then just run 2 wires and and rescale the sensor settings in the ecu. You will see the sensor heat soak a bit sitting at lights or when you have shut the car off, such as running into the store and such. Heat soak will be much more pronounced when the vehicle sits not running as compared to sitting at idle. These are just my opinions from what I have seen on other platforms. For now on this is what I will be doing when I install one of these blowers though. There are other sensor options out there as well to look into that will work for this type of application.
The Following User Says Thank You to Ross For This Useful Post: | Xero-Limit (11-27-2013) |
11-27-2013, 08:16 AM | #31 |
Drives: UK GT86
I'm pretty sure that Mark@Abbey m/s has adapted the plate to take a sensor that sits into the air stream. That's what will be going on mine. I should be able to report back in the next month.
.: Stealth 86 :.
11-27-2013, 11:16 AM | #32 |
11-15-2014, 07:57 AM | #33 |
Drives: GT86 in Orange
Sorry for the delay in keeping this thread up to date;
Yes we have developed our own IAT kit that paces the Bosch fast acting sensor in the airflow; Sensor and plate We have to modify the manifold to allow the Bosch sensor to put direct in the airflow we modify the loom to allow the IAT to be inputted on the normal IAT wire; We have just done some more tuning on our Demo car , fitting a HKS manifold running no cats at all and a 69mm pulley , seeing some great numbers now; spent sometime on the dyno yesterday and I now can remove the dip totally in the torque/power curve. Waiting for P tuning to hopefully ship me on there manifolds(headers) very soon. Next mod will be water/methanol injection(I know I said I don't like it before) but I have spent sometime looking into it and I have a pretty trick idea to allow the car to be tuned nicely on the water/meth mixture. Will keep this thread up to date. thanks |
11-15-2014, 10:02 AM | #34 | |
That Guy
Drives: 2013 asphalt FRS MT
11-15-2014, 12:41 PM | #35 |
Drives: Flat grey Toyota 86
Do you have the IAT logs to show how the newly fitted sensor is working. Would love to see a multi pull session with the current set up. It is intercooled now, correct?
Thx |
The Following User Says Thank You to Lawnik For This Useful Post: | sw20kosh (11-15-2014) |
11-15-2014, 02:40 PM | #36 |
Now that is a proper IAT sensor... The fail FA20club sensor was for fluid. lol
Would be interesting to see logs of how it is detecting air temps during a wot pull. @King Tut
11-16-2014, 04:09 PM | #37 | ||
Drives: UK GT86
I've had this sensor setup on for some time now, it works well. Plenty of log data of it on normal and fast driving. Shows how the manifold heat soaks after being stationary but also how quickly the temps drop once moving again.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Lawnik (11-16-2014) |
11-16-2014, 06:08 PM | #38 |
@Kodename47
Please share some of these logs, preferably the hard driving ones. You got this from Abbey? |
11-17-2014, 03:29 AM | #39 |
The FA20 IAT is a IAT sensor not a liquid sensor but I agree it doesn't get a good airflow over the sensor.
Our car is still running this sensor and the IAT temps do "hang" where as our sensor set-up reacts quickly. I will get some logs uploaded sometime over the next few days. thanks |
The Following User Says Thank You to Mark@Abbey m/s For This Useful Post: | Lawnik (11-17-2014) |
11-17-2014, 05:45 AM | #40 |
Super 86
Drives: Red 86 GTS
If you're replying to sw20kosh he was talking about a sensor that another vendor sold, they were called FA20club and........well they suck.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
The Following User Says Thank You to Khorne For This Useful Post: | Calum (11-17-2014) |
11-17-2014, 10:09 AM | #41 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
11-17-2014, 11:15 AM | #42 |
Drives: UK GT86
.: Stealth 86 :.
Similar Threads | ||||
Khorne's - AUDM Red 86 GTS Sprintex | Khorne | Member's Car Journals | 53 | 08-31-2014 09:44 AM |
Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 11:09 AM |
Abbey Motorpsort GT86 Sprintex installation | Mark@Abbey m/s | Forced Induction | 18 | 09-07-2013 04:11 AM |
Sprintex Supercharger Sneak Peak!!! | invisage | Forced Induction | 52 | 03-03-2013 06:11 AM |
ARC (Abbey Road Company) Goodies When? | track_warrior | Engine, Exhaust, Transmission | 46 | 12-30-2012 08:37 AM |
