Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-18-2016, 04:44 PM | #43 | ||
Drives: FR-S Whiteout
As mentioned there is a specific oil galley plug at the front/top of the block along with a part from subaru that allows for fitment of a pressure sensor (1/8 BSPT thread).
Intent > Content
cowardice is the mother of cruelty. |
02-19-2016, 04:06 PM | #44 |
Drives: 2013 FR-S Whiteout MT
Is there a picture of this spot? If this place can be used for oil pressure, is there another one for the temp?
When in doubt, throttle out!
02-20-2016, 05:43 PM | #45 | |
Here are some photos of the previous set up I installed then uninstalled with a larger oil pressure sender that required it to be relocated, the Subaru galley plug, and a hose to relocate the oil pressure sender. Gally plug installed into the block: Original plug vs galley plug with 1/8 BSPT thread fitting: My prosport setup using the prosport galley plug (1/8 NPT) and the more compact "premium" sender did not require relocation, but is a very tight fit right on top of the galley plug. did not take pics tho. I'm sure you can rig up some connections to the galley plug for both a temp sensor and a oil sender pretty easily. Edit: Prosport sender and galley plug. Nice and tidy.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 02-20-2016 at 06:03 PM. |
The Following 2 Users Say Thank You to solidONE For This Useful Post: | FRS Johnny (02-21-2016), SPCorBUST (05-07-2017) |
02-21-2016, 12:31 AM | #46 | |
02-25-2016, 12:09 PM | #47 | |
Drives: Toyota
The Following User Says Thank You to boomslang For This Useful Post: | stevesnj (02-25-2016) |
02-26-2016, 08:32 PM | #48 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Lunatic's set up is the dog's danglies. It would be very cool if some enterprising fabricator would design and market one just like it for 52 and 60 mm gages. I'd love to slip a set of defi oil pressure, and oil and water temps into one of those. I don't track the car, and this would be perfect.
Slow is smooth, and smooth is fast
03-06-2016, 12:36 AM | #49 |
Drives: Acura TSX
If your gauge needs illumination where did you tap into it?
03-06-2016, 01:49 PM | #50 |
Inactive
Drives: .
I just followed rallysportdirect instructions on installing the Defi boost gauge with ATI vent pod. Go on the website it has step by step with pics, the rest is just plug and play so you can just use the spots they tapped with.
03-06-2016, 01:50 PM | #51 |
Drives: Acura TSX
It didn't have anything about illumination. It just skipped that completely
03-06-2016, 02:31 PM | #52 |
Inactive
Drives: .
03-06-2016, 04:03 PM | #53 |
Drives: Acura TSX
Guess so. The way they had it worded
03-06-2016, 08:20 PM | #54 |
^ you can always use a fuse tap if you're uncomfortable with splicing into your harness. Which is exactly what I did.
Intent > Content
03-06-2016, 08:20 PM | #55 |
Drives: Acura TSX
Yeah I'm gonna use a tap though I have no issue splicing
04-03-2018, 12:24 PM | #56 |
Drives: 2016 FRS
Oil Pressure gauge.
Do you have a problem with the accuracy of that oil pressure gauge. I have the same gauge and my oil pressure has always read lower than other people that have different brands of oil pressure gauges. Its possible the sensor is ruined because the startup oil pressure exceeds the limit of the gauge and its sensor.
Similar Threads | ||||
oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 05:46 PM |
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 12:48 PM |
best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
DIY: mechanical oil pressure gauge | litemup | DIY (Do-It-Yourself) Guides | 14 | 09-06-2014 11:12 PM |
Have a tire pressure gauge you really like? | Anthony | Tracking / Autocross / HPDE / Drifting | 21 | 09-10-2013 06:09 PM |
