Tracking / Autocross / HPDE / Drifting What these cars were built for! |
12-05-2019, 10:53 AM | #85 |
Scott M
Drives: '13 BRZ (DocWalt's old car)
^ Thanks for the clarification, sounds pretty reasonable.
13 BRZ (STX prep)
14 Lotus Evora S 06 BMW Z4M Roadster, 01 740i |
12-05-2019, 11:43 AM | #86 |
Purist
Drives: 2013 FRS - Hot Lava
I see a lot of people with only an upgraded front swaybar. Is this a SoloII thing, or is there reason it benefits any track setup? 949 Racing also only has a front bar. Would you guys prefer to run stiffer front coils and this is whats available because not all coilovers have a choice?
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
12-05-2019, 04:54 PM | #87 |
Seems to me that being much stiffer than about 550# or so on the front the car reacts poorly to shitty/bumpy/broken up surfaces, even at that spring rate a stiffer front bar than stock helps with transitions. Many run softer springs than that (300# to 500#) and up the sway bar rate to keep the car quick through slaloms and offsets. There's plenty of spring rate and damper options available so this isn't limited when it comes to Street Touring setups, more related to the physics of the chassis.
The rear suspension gets most of it's stiffness from the springs, the rear bar is pretty low impact with a 0.5x motion ratio. Just lucky/good design that matching the rear spring for good longitudinal manners to the front also results in a good roll stiffness match with the stock rear bar. Slightly different suspension design (pickup points, arm lengths, mounting points, etc.) could totally change that, but we got what we got. Most people develop on a budget, why spend a ton of money testing when the OE rear matches well with a stiffer front and stiffer springs all around? 949 specifically tests on tracks with crappier pavement and consider autox use (I would be surprised if they didn't do some skidpad testing with slaloms and offsets) so it makes sense to me that they're in a similar ballpark when tuning for the same wider stickier street tires. Add aero and bias towards smooth well maintained tracks and you start seeing stiffer spring rates like what's on track focused Teins or JRZ's with 10k-12k rates. |
12-06-2019, 10:28 AM | #88 | |
Purist
12-06-2019, 12:05 PM | #89 |
The damper is not a limitation, you can get whatever you need in this class. More spring makes the car unsettled over bad surfaces while the bar does not. That's just my experience and observation, feel free to experiment and seek other opinions.
The Following User Says Thank You to strat61caster For This Useful Post: | Westen86 (12-06-2019) |
12-06-2019, 01:43 PM | #90 |
Drives: Track preped NA FRS
While "conventionnal knowledge" says that a softer sway bar would net more grip overall (softer more grip but slower to react), the reality is that "it depends". While im sure there are plenty of cars out there that work best with stiff springs and soft bars, or even no bars at all, what I have found in my own car is that, even if you have ridiculously stiff srpings (700+), a stiffer sway bar works better than a stock one. Dont ask me how or why, but the car became much easier to drive after putting in stiff swaybars (keeping a around 200% stiffer than stock in both front and rear). I dont know the effect that only the front bar will have, in theory it should understeer, but again, this is another "it depends" answer.
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post: |
12-07-2019, 10:55 AM | #91 |
Hi folks,
This isn't exactly a setup post, but a rules post. The 2019 SCCA rules for STX only list the 86/BRZ through 2017. I assume this is basically an oversight since the 2017 to current cars are virtually identical in spec, so I wrote a letter to the STAC asking them to update the listings. Of course, the other route would be to run a newer car in STS under the catchall rule and get protested, but I'd rather not I think it would be helpful if a few other members wrote and asked for the update as well.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
12-07-2019, 11:28 AM | #92 | |
Drives: #337 2017 Toyota 86
949s suggestions are track focused but will still work well at autocross. I've been running the stock 2017 sway bars at autocross for a while and it's neutral-loose which I like but would be faster with a bigger front bar. I am currently running 450lb springs F/R with MCS 1WNR shocks. I do not think you need more than a 15mm rear bar in 99% of use cases. It'll be too much and make the car more difficult to drive on the limit.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
12-07-2019, 02:44 PM | #93 | |
Drives: 15BRZ
My complaints with dailying are related to space in the car etc. not so much suspension etc. lol Sometimes i think some setups are more specific for smooth concrete like Lincoln (never been there but i am sure its nice) but i know i will never be there due to don't really get much seat time due to work etc. ( and I suck ) lol Sometimes i wonder why i have this car due to being a 95% daily/5% racer but its so damn fun, thats why! Last edited by KevBRZ; 12-07-2019 at 07:18 PM. Reason: add |
12-09-2019, 07:22 AM | #94 |
Drives: 2016 Scion FRS
Another thing in the spring versus bar conversation is adjustability. Most people aren't going to find it viable to swap front springs on an FRZ between autocross runs.
12-09-2019, 03:04 PM | #95 |
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Is there an equivalent SCCA time trials class for STX setup FRS?? I know the SSC translates well to TT S6, wasn’t sure about STX.
12-09-2019, 03:16 PM | #96 | |
The FRZ86 is classed in Tuner4 I thought there was an allowance for STX -> T4 a la the SSC (some SSC parts aren't actually allowed in Streetk, mostly the camber parts from SPC) but I can't find it now, that might have been eliminated as it's been a good year since I took a close look at the rules. |
The Following User Says Thank You to strat61caster For This Useful Post: | skylinekin (12-09-2019) |
12-09-2019, 04:40 PM | #97 |
Drives: 2013 FRS
Yes its tuner 4.
Go to timetrials.scca.com Click on 'what's my class' Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
The Following User Says Thank You to bmacfrs For This Useful Post: | skylinekin (12-09-2019) |
12-09-2019, 04:57 PM | #98 |
Drives: '15 STX
There isn't a direct ST > Tuner translation for TT but the ruleset is basically a copy/paste from ST. You'll find that Tuner 5 is STS/STR, T4 is STR/STX/STH and T3 is STH/STU. Rules are locked for another year so this isn't likely to change.
Unfortunately STX cars find themselves in-between the speed of Tuner 4/5, so they don't really have a premium competitive home unlike the Sport classed cars. There is an "Alt Motorsport" classing but currently it only covers autocross Street class and SSC direct to Sport. The rest of the "Alt Motorsport" is Road Race, etc. RE: Spring vs Bar in AX; it's better practice to keep the spring rates on the softer side and use adjustments of sway bars to get roll stiffness required. It's much easier to make a change on the sway bar than it is to change springs if there is an issue with surface grip. Since autocross is slower, on imperfect surfaces and has more undulations than track, big spring doesn't have the same benefits. This has been proven in practice more often than not in ST. |
The Following 2 Users Say Thank You to tony_r For This Useful Post: | skylinekin (12-09-2019), strat61caster (12-09-2019) |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
2019 CDC & SCCA Autocross Thread | JakeRogue | Mid-Atlantic | 15 | 05-17-2019 09:58 AM |
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited | Busybee | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 02-24-2019 12:05 PM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 10:05 PM |
