09-02-2013, 11:08 AM | #141 | |
Drives: '13 BRZ Ltd
09-02-2013, 11:37 AM | #142 |
Drives: '23 BRZ
There's also scrub radius to consider. I.e., how close is the intersection of the steering axis with the ground to the tire centerline? Positive scrub radius would act to further reduce the ratio, negative scrub radius would make it closer to 1:1. Search did not reveal FR-S scrub radius, but apparently McP struts do often have negative scrub radius. So maybe it's 1:1 after all...
09-02-2013, 11:47 AM | #143 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
I absolutely LOVE the stock suspension setup on the BRZ, but believe the wheel well is just a little but large... I've read around a ton, but I can't seem to find what people in my situation are doing.
Is my best bet to japanparts the STI springs for best hope of preserving the existing stock feel? Or are there other great springs with a similar spring rate and 15mm drop?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
09-02-2013, 01:57 PM | #144 | ||
Kuruma Otaku
So that should be close enough?
Because titanium. |
09-02-2013, 02:03 PM | #145 | |
09-02-2013, 02:08 PM | #146 | |
For example, I daily drive my s2k with this alignment: Front: -3.5 camber 6.5 caster 0 toe Rear: -3.5 camber 5/32" total toe-in My last set of RE-11 lasted 7 track days and 18k miles with that alignment (and constant tire rotation). That wear may not be acceptable to some, and far better than expected for others. Is it an alignment I would use on a FR-S/BRZ? No. The CSG BRZ's alignment is currently: Front: -3 camber (via coilovers and camber plates [included with Tein SRC purchased from us]) 0 toe Rear: -2.4 camber (natural camber from the drop) 0 toe This is the alignment we recommend to experienced drivers that expect to see 6 or more track days per year with some street use. However, as previously stated, alignments are highly subjective, and my recommendations will vary. The more data and feedback you can provide me, the better I can recommend changes. However, there is no right or wrong. What may work for me may not work for you, and vice versa. |
09-03-2013, 01:50 PM | #147 | |
Front -4 camber 1/16" total toe-in Rear -2.75 camber 5/64" total toe-in Change came from altered ride height and tolerances with the installation of the latest revision of the CSG-Spec Tein SRC. Latest specs as of today: Front -3 camber 0 toe Rear -2.75 camber (natural from ride height drop of -1.4") 0 toe[/QUOTE] |
09-03-2013, 03:03 PM | #148 | |
Drives: '13 BRZ Ltd
However, for something like a swing axle, wheel offset will have a definite effect on motion ratio. |
09-03-2013, 03:06 PM | #149 | |
Drives: '13 BRZ Ltd
Also FYI, motion ratios for the rear: 0.78 measured for the spring, 0.59 measured for the bar. I've got some calcs for wheel rates/frequencies for front and rear due to springs and bars, but that's probably better suited in the Suspension Modeling thread. |
The Following User Says Thank You to Wepeel For This Useful Post: | Dimman (09-03-2013) |
09-03-2013, 05:56 PM | #150 | |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | ultra (09-03-2013) |
09-04-2013, 04:10 AM | #151 | |
Just a dude
Drives: Scion FR-S 2013
FR-S 1-1.25" drop tops to retain stroke and function Rear 18x9.5" - 255/35/18 Michelin Pilot Sport A/S Front 18x8.5" - 225/40/18 Michelin Pilot Sport A/S Suspension: KWV3 with Vorshlagg front plates and Rear Stance LCA (have read and noted that Vorshlagg plates add a degree of caster.) not sure what stock is and how much the vorshlagg affect goals on front camber etc? Goal driving: DD/ Street & Spirited /5% autocross Guess: -2 degrees camber in rear with zero toe Guess: -.5 degrees camber in front with zero toe How would that work or any advice based on that setup? Lastly if it were 18x9.5" and 255/35/18 tires all way around what would you then reccomend given all other data same?
09-04-2013, 09:38 AM | #152 | |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
Why on earth were you running toe in up front??? |
09-04-2013, 09:40 AM | #153 | |
Drives: '13 BRZ Ltd
Where the offset does make a difference is in lateral force applied at the strut top (and hence the tension in the lower arm). |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
