DIY (Do-It-Yourself) Guides For all DIYs. |
04-19-2017, 04:55 PM | #29 |
Drives: 2017 BRZ Limited
Thanks for the guide Akuma!
Quick question does connecting the wires involve any soldering/crimping or are you just plugging them into the harnesses? |
04-19-2017, 06:06 PM | #30 |
Drives: between cars...
great DIY! 2 questions:
1) would this proceedure be any different for a Double din HU that had Carplay? 2) Is there any way that you saw that would allow you to reuse the factory microphone? |
04-20-2017, 04:10 AM | #31 |
Drives: 2017 DGM BRZ Limited
Yes, you would need a way to connect a few wires together. In my guide and the pictures shown, I used butt connectors, to show that it can easily be done by anyone. You can solder wires together if you want to.
04-20-2017, 04:29 AM | #32 | |
I haven't tried it myself, but I hear it's not worth the trouble and that the factory mic isn't that good to begin with. It's been a while since I checked, but, I believe the mic is amplified and needs power, most likely you have to convert it to 5v. There's a pin out of the 28 pin harness on the forums that show where you need to connect the mic wires. You would then connect the wires to a 3.5mm plug and plug that into the head unit. |
04-20-2017, 11:27 AM | #33 |
Drives: 2016 scion 86
@Akuma147...that's my next upgrade for 16frs and my question is, can the unit plays cd and displays gauges from ecu at the same time ( plan to get bt adapter for torque app)?
Really appreciated ur time doing research and make this helpful post....thank you. |
04-20-2017, 10:51 PM | #34 | |
04-21-2017, 08:53 AM | #35 | |
05-12-2017, 03:47 PM | #36 |
Last Starfighter
Drives: 2016 FR-S Series 2.0
I'm about to attempt this. Has anyone tried this harness from joying? It looks like it includes the 28pin connector for camera output? Comments?
I definitely don't see a 12<>6 volt converter I can see the the 6, 10, and 28 pin plugs. Looks like there are extra not needed and will mostly likely require rewiring? Seems nice that it includes the 28 pin though? https://www.carjoying.com/joying-har...ess-cable.html Last edited by djwishbone; 05-12-2017 at 04:01 PM. |
06-03-2017, 08:13 AM | #37 |
Drives: MY20 Hakone Toyota 86
Are you saying that this harness will work out of the box, no modifying? Cause I'm running into issues with this DIY. Reverse camera is a black screen, I'm assuming fault on my own somewhere with that. And only the mode button on my steering wheel controls is registering. Which is strange, I'd figure it would be an all or nothing. This is on a 2017 86, not sure if there are differences from the BRZ.
06-03-2017, 05:46 PM | #38 |
Last Starfighter
That harness will not make your reverse camera work. You need to try their brZ harness (no one has tried yet that I can find) or build your own from other options you can find on this forum ( sorry I can't link you at the moment. ). Basically you need to make some RCAs to one of the plugs and use a 12v to 5v converter to tell the camera to turn on. I'm not completely sure why that last part is necessary (maybe the stock head unit has a 5v output). Anyway. Good luck
Sent from my SM-G955U using Tapatalk |
06-06-2017, 12:42 AM | #39 | |
Regarding the steering wheel controls, do you have a Joying head unit or something else? If it's Joying, did you use the steering wheel app to map the buttons to the head unit? Make sure you hold the steering wheel button, then press the desired function on the head unit to map it. |
06-23-2017, 12:39 AM | #40 |
Drives: 2016 Subaru BRZ
I bought one tonight, I have all the wiring harnesses to make one right now though. I'll let you guys know if it works next month when I get it.
06-29-2017, 01:01 AM | #41 | |
Drives: 2017 Subaru BRZ
I installed a Pioneer AVIC-5200NEX into my 2017 BRZ and got it working. I however cannot get my Steering wheel controls to retain yet. Still trying to figure that out, but I am ever so close, studying the iDataLink RR product wiring patterns. Also, I am going to order another DROK (12 to 5 v converter) because that is the last wire I need to get the OEM microphone working... I have all the other wires in place. |
06-29-2017, 01:55 AM | #42 |
Good luck with the mic
The Following User Says Thank You to Akuma147 For This Useful Post: | kothetimeless (06-29-2017) |
Similar Threads | ||||
Aftermarket Crank Pulley Install | Enigmus | DIY (Do-It-Yourself) Guides | 305 | 02-04-2019 11:37 PM |
Aftermarket snorkel / HKS air duct install | 8RZ | Engine, Exhaust, Transmission | 2 | 10-19-2016 11:57 AM |
Aftermarket Bumper install | Pug_BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-06-2015 05:15 PM |
Aftermarket 2DIN Radio Install | DetroitJake | Electronics | Audio | NAV | Infotainment | 4 | 07-08-2012 11:17 AM |
Will you install an aftermarket Security System? | ShoGun | BRZ First-Gen (2012+) -- General Topics | 40 | 04-06-2012 03:04 AM |
