Software Tuning Discuss all software tuning topics. |
04-14-2017, 06:49 PM | #1 |
Drives: 2014 BRZ Limited
OFT E-Tuning VS EcuTek Experience and Results
Hello everyone; I'll be doing a head to head comparison of the OFT E-Tune to EcuTek with dyno results courtesy of ProCom Racing.
I am installing a Kraftwerks C30 kit and wanted to see if there really is a big difference for forced induction between the two tunes on 93. Log: 4/12/17 WE: Paid for E-Tune and provided original flash to OFP. 4/17/17 MO: Shiv requested MAF tube ID and MAP sensor that will be used. 4/19/17 WE: Received initial base flash, instructed to log the following: 1) 10 seconds of idle 2) 10 seconds of high cruise (65mph in 6th gear on flat road) 4/22/17 SA: Install complete; recorded idle and 65 mph. 4/22/17 Sa: Email sent to Shiv containing logs. 4/25/17 Tu: Shiv requested log of full third gear pull 2000-5000 rpm. 4/26/17 We: Email sent to Shiv containing logs. 4/26/17 We: Shiv requested a couple logs of full throttle pulls 2000-7500 rpm. 4/27/17 Th: Email sent to Shiv containing logs. P0103 code appearing in 3rd gear at 7.5k. 4/30/17 Su: Shiv sent new tune to remedy P0103 and requested to perform logs again. 5/1/17 Mo: Email sent to Shiv containing logs. Felt like I was a little down on power this time, might be in my head. 5/1/17 Mo: Definitely down power and burning excess fuel with tune 02. 5/2/17 Tu: Flashed 02 again; fuel economy seems better but power is still slightly down at peak. Was roasting the tires in a straight line at 7.5k in first and could get it started in second too with 01. 5/3/17 We: Emailed updated logs. 5/4/17 Th: Received updated file, requested to log again; Shiv explained he was getting the MAF scaling sorted before making it more aggressive. 5/5/17 Fr: Emailed updated logs, will probably log 2-7.5k again due to losing traction in the rain. 5/17/17 We: C30 bearings may have eaten themselves, blue rotrex fluid became black over 45 miles. We'll see what's wrong when I get the kit off and what needs to be fixed. 5/18/17 Th: Marks 2 weeks without communication. 5/19/17 Fr: Shiv contacted me, said that he'd be willing to tune the SBD kit from the previous fee which is awesome. 5/23/17 Tu: Purchased SBDX500 Turbo Kit, welded oil pan, SBD over pipe, and front pipe. 5/31/17 We: Received full turbo kit minus the SBD exhaust pipe, contacted Chris; said he'd get it shipped out 6/1/17. Ordered an AEM Failsafe AFR/Boost gauge with 6k used; for safety and data logging. Also ordered a vacuum manifold from Fast-Turbo to clean up vacuum lines for boost gauge and eventually Electronic Boost Controller (still deciding on which to buy, probably will pick up once I start using EcuTek). 6/01/17 Th: New owner of the SuperCharger broke down the unit for repair; he questioned why Rotrex says they aren't repairable. "Looks like it needs a shaft, impeller, and 3 new bearings. That's it!" Looks like he's off to the races with that setup, he said I may have overspun it to cause the failure. IMO the C30-94 is an excellent setup and really keeps the car balanced still, I'm just looking toward more power at this point (probably more than I can control). 6/04/17 Su: Waiting on drift armor and SBD piping; need to order SouthBend Stage 3 Endurance Clutch and Velox Fork. Still deciding on which electronic boost controller to use, or if I'm going to use one. New owner of C30 found that the oil pump in the unit may have failed, needs to source a new spring and inspect the pump. 6/05/17 Mo: Received ATI vent gauge, adapter, some side marker A clips, and my Kosei center caps from Ray! Things to order:
Ordered:
Things to do before install:
The Following User Says Thank You to elitegunslinger For This Useful Post: | phrosty (04-17-2017) |
04-14-2017, 07:25 PM | #2 |
Reserved for results.
04-15-2017, 03:43 AM | #3 |
Drives: UK GT86
Who's doing the EcuTek tune though? There's not a blanket EcuTek tune, all depends on the tuner.
Also it's worth noting that while dyno results should be similar, it would be ideal to compare how they are off the dyno.
.: Stealth 86 :.
04-15-2017, 11:49 AM | #4 |
ProCom will also be doing the EcuTek tune; forgot to mention that. I'll make some butt dyno and handling notes as well.
04-17-2017, 11:49 AM | #5 |
Drives: 86
I was going the ECUtek way because you are able to do custom maps. My ECU is faster than a human watching two gauges.
OFT is very good for N/A applications but as I said the custom maps (failsafes) are the (my) point. |
04-22-2017, 09:10 PM | #6 | |
Hopefully I see a difference between the two tunes as I think $800 for just software is a little excessive when for $440 + $245 I've tuned for NA and FI this also provides me with an entire data logging device, code scanner, tuner, etc. Which is a bargain compared to EcuTek. I'll have to buy a cable, laptop or tablet, and software for EcuTek. Hands down OFT wins for value but until I've tested them both I can't compare quality. |
04-23-2017, 04:35 AM | #7 | |
Drives: UK GT86
At the end of the day the quality comes down to the tuner. Having used both to write tunes, EcuTek is the more powerful tool to do everything. It's also better for dyno tuning as it will save you time. However as an end user I get that most don't understand or get to see this.
.: Stealth 86 :.
04-23-2017, 04:52 AM | #8 |
Drives: 2013 FRS 10 series
Wow you actually got a hold of shiv? I sent him my idle and 65 logs back on the 11th and have emailed him 5 times since then and haven't heard a single word from him...
04-23-2017, 10:49 AM | #9 | |
We will see how long it takes to hear back after these logs; I sent them yesterday and he's open Monday - Thursday so I don't expect a response yet. Unsure why you haven't gotten a response yet... |
04-23-2017, 12:41 PM | #10 | |
Drives: UK GT86
A custom tune is adjusting the maps found in the stock ECU. EcuTek add 16 maps (on this platform) that you can get to do pretty much whatever you want, so you can add functionality when and if required like traction control, boost control, WMI control, temperature based limiters/control etc. These are the custom maps. Then there's the other features that they have added, like gear dependent limiters, and now with the new Bluetooth EVI device you can control various settings and log with your mobile/tablet.
.: Stealth 86 :.
04-23-2017, 04:24 PM | #11 | |
06-01-2017, 07:11 PM | #12 | |
06-01-2017, 11:27 PM | #13 |
Drives: frs
Seems like a month. I wonder how much time consume fo ar NA car
06-02-2017, 05:26 AM | #14 |
Huge E85 fan!
Drives: 2016 Scion FRS
Could the OFT tune have caused the failure of the supercharger?
Similar Threads | ||||
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1212 | 03-10-2023 11:07 PM |
Your real world results when tuning your aftermarket intake | Nah | Engine, Exhaust, Transmission | 3 | 08-08-2016 05:43 PM |
Dyno results from R/T Tuning Greddy turbo FRS | R/T Tuning | NY / NJ / CT / PA | 1 | 10-12-2013 07:38 PM |
DDPR EcuTek Tuning results | Illusive | Engine, Exhaust, Transmission | 26 | 02-11-2013 10:54 AM |
