Old 07-03-2013, 02:24 PM   #533
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by nelsmar View Post
So is anyone in here using a 3+bar sensor?
You mean more than 3 or 3 and above? I'm on the 3 bar.
Originally Posted by Dezoris View Post
Here is the pulley noise that is reported by myself and Amadeus.
This was recorded during my review video and has become more prominent namely the more the car heats up.
At 2000RPM is pretty consistent. When de-accelerating to a stop from 4000-2000RPMs in gear the noise sometimes gets much louder. However it's not always present, but getting worse.
Sounds like a whistle - is that what you're talking about? Is it definitely a pulley or is it possibly air being sucked through the intake or through the blower or some other part of the system? Whatever it is, mine definitely does not have that characteristic.
Old 07-03-2013, 02:41 PM   #534
Dezoris
Dezoris's Avatar
Did you guys re-use this washer on the new idler pulley?
Instructions dont say to, was wondering who did it?
Old 07-03-2013, 02:42 PM   #535
Dezoris
Dezoris's Avatar
Its that high pitch squeak sound.
Old 07-03-2013, 02:45 PM   #536
Foobar
SLO NO MO
Foobar's Avatar
I did not reuse that.
Sent from my Nexus 4 using Tapatalk 2
Old 07-03-2013, 03:17 PM   #537
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
The factory bolt and washer are not to be reused. A supplied bolt is used in place of the factory bolt and washer.
Brian@Vortech is offline   Reply With Quote
The Following User Says Thank You to Brian@Vortech For This Useful Post:
Pete (07-03-2013)
Old 07-03-2013, 04:41 PM   #538
Dezoris
Dezoris's Avatar
Ok thanks for clarifying, any opinion on the pulley squeak?
Old 07-03-2013, 05:42 PM   #539
Brian@Vortech
Nothing specific. Have you pulled that washer back off to see if that was the culprit? If it touches any rotational part of the idler, that could certainly be making the noise.
Old 07-03-2013, 05:43 PM   #540
DJCarbine
Thupercharged
DJCarbine's Avatar
Does the car have to be moving to reproduce the sound?
I've heard my fair share of bad/failing pulleys, from the video it doesn't sound like a pulley to me....
If the noise is able to be heard while stationary with the engine @ speed, it shouldn't be too hard to find out whats making the noise... if it doesn't, then my vote would be a loose bolt somewhere allowing metal/metal movement/contact
Where in Chicago are you? I wouldn't mind helping diagnose the problem
2013 FRS
Vortech V3 11psi
Old 07-03-2013, 05:44 PM   #541
Dezoris
Dezoris's Avatar
I never put that washer on. But always wondered why it did not need it.
Then saw Rallys install where they used it and wondered if others had.
Old 07-03-2013, 05:47 PM   #542
DJCarbine
Thupercharged
DJCarbine's Avatar
I did not
2013 FRS
Vortech V3 11psi
Old 07-03-2013, 06:01 PM   #543
Brian@Vortech
Someone should probably tell Rallysport they are borrowing someone else's logo...
nelsmar (07-04-2013)
Old 07-03-2013, 06:05 PM   #544
Dezoris
Dezoris's Avatar
I am pulling the airbox out and de-tensioning the belt Saturday at the shop. Checking everything. When the car gets hot enough I can get the noise idle barely but, its much easier under load. If I can't figure it out calling Vortech on this one.
@Brian@Vortech can you all do us and future owners a great service and get engineering to publish the proper TQ specs for all the bolts?
Old 07-03-2013, 09:57 PM   #545
Foobar
SLO NO MO
Foobar's Avatar
I asked Brian for the torque specs back when I did my install - this is what he shared with me:
2x 5/16-18 on top = 13-16 ft-lb
5/16 x 5 with nut = 13-16 ft-lb
3/8-16 to s/c plate =22-28 ft-lb
OEM pivot = 13-16 ft-lb
OEM long = 13-16 ft-lb
Old 07-04-2013, 02:20 AM   #546
frX50z
frX50z's Avatar
Drives: 2014 frs
Silly question, but is it safe for DDing?
I heard NA subie motors hate boost.
I really wanna avoid all the headaches I had modding/tuning/dealing with sh!t breaking on the X...
I know thats part of the mod game, but i want a safe plug and play sleeper kit. You'll have my business if that's the case.
Silver Wrx STI
Fr-s (sold)
350z HR (sold)
Evo X gsr (sold)
Celica GT convertible (exploded)
frX50z is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
