Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
03-27-2017, 07:55 AM | #15 | |
Drives: '14 Red Toyota GT86 RocketBunny
Just an opinion on this.
Since the tachometer on the car communicates using CAN signals, and all the relevant systems in the car send CAN signals, shouldn't it actually be a plug and play and the display would stay on the default out of the box setting without the steering wheel to control it.? the only issue i can think of is the ECU not being able to communicate, here's a quote by steve99 from the other thread Quote:
'14 Toyota GT86 - 2JZ GTE - R154 - GTX3582R 1.06 - Motec M130 PNP - RocketBunny v1
'09 Audi RS6 C6 - MTM 850HP |
03-28-2017, 09:37 PM | #16 |
I LOVE YOUR GT86
Drives: 2017 BRZ with PP 1982 Datsun210
09-23-2017, 03:19 AM | #17 |
Drives: Frs
Bump
09-23-2017, 05:58 AM | #18 |
The Fail Boat
Drives: CWP S.B.
You can't even swap the old gauge to a different car.... pre facelift model gauge swap involves getting dealer to get a code from subaru to swap for you....... why do you think the new one with all digital stuff will be easier.
Figure most guys that actually know about this just assume it's pretty expensive hence nobody posted about it? But please do try and let us know the result. *To be honest i just wanna know if the older car can get the new track mode. lol |
The Following User Says Thank You to chaoskaze For This Useful Post: | funwheeldrive (11-08-2017) |
10-23-2017, 03:36 AM | #19 |
Drives: Frs
Bump
11-05-2017, 09:37 AM | #20 |
Drives: Frs
Bump?
11-08-2017, 12:49 AM | #21 |
Drives: Frs
Bump!
01-07-2018, 04:01 AM | #22 |
Drives: 2013 White brz Limited.
I’d like to confirm. I swapped the gauge cluster and steering wheel with clock spring. Still need dash harness to make this work but so far gauges work fine. I just can’t change screens on gauge lcd till I pin the wires in or get the dash harness. They changed clock spring and also the clock spring connector from a 12pin to a 14pin. Parts from a 2017 Limited brz and I own a 2013 Limited brz.
The Following 5 Users Say Thank You to brentjones518 For This Useful Post: | derpz86 (02-26-2018), DustinS (03-05-2018), jorgerendonjr (01-07-2018), Sportsguy83 (07-17-2018), zc06_kisstherain (03-01-2018) |
01-07-2018, 04:43 AM | #23 | |
Drives: Frs
02-19-2018, 02:14 PM | #24 | |
Drives: 2015 BRZ
parts
02-26-2018, 08:54 PM | #25 | |
Drives: 2015 Scion FR-S RS1.0 #507
Sent from my Mi MIX 2 using Tapatalk |
03-16-2018, 01:44 PM | #26 |
Drives: 2015 BRZ
03-16-2018, 09:37 PM | #27 |
Drives: BRZ Limited; GR86
07-17-2018, 03:11 PM | #28 | |
I Love custom Turbo kits
Drives: Limited BRZ
Similar Threads | ||||
2017 Limited Gauge Cluster | halleffect | Electronics | Audio | NAV | Infotainment | 26 | 10-22-2020 07:32 PM |
2017 BRZ limited wheels are Not Black. | ~el~jefe~ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 07-30-2017 12:15 PM |
2017 Limited Gauge Cluster | halleffect | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-16-2017 03:55 AM |
2017 BRZ Limited Spoiler | Chayce808 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 01-04-2017 12:49 AM |
2017 Subaru WRX STI, STI Limited, WRX, WRX Limited, WRX Premium | mark0006 | Other Vehicles & General Automotive Discussions | 0 | 10-27-2016 06:22 PM |
