11-14-2018, 09:33 PM | #85 |
Fuel lines are done, assuming they don't leak. Checked clearance on my new fans from Spal. Fit just fine. These cost about $95, and move just over 1300 cfm. 13amp so I'll try Sportsguys advice and bump up my fuse one notch to 30amp. If I had to go any higher, I would rewire the fans entirely like ILLSMOQ did.
I think I solved my spark plug issue with some 135degree cut to length wires but I haven't installed them yet. I now have 98% of all the parts I need. Just a few more fittings and... A shiny new Accusump |
11-21-2018, 06:15 PM | #86 |
Anyone know what this plug is? Right by the ABS unit
11-21-2018, 06:29 PM | #87 |
I Love custom Turbo kits
Drives: Limited BRZ
AC pressure sensor
11-21-2018, 06:32 PM | #88 |
The Following User Says Thank You to Ashikabi For This Useful Post: | Sportsguy83 (11-21-2018) |
11-22-2018, 11:24 AM | #89 | |
Drives: Red BRZ
Sent from my SM-G950U using Tapatalk |
11-22-2018, 01:22 PM | #90 |
I did. I'll have to get back to you on that though. Dunno if it even works. I came to the conclusion I did on wiring by looking at the letters printed on the connectors/alternators and compared them. I wrote it down somewhere but I'm out of town right now
11-24-2018, 06:11 PM | #91 | |
I'll be honest. I have no idea if this is right and I haven't been able to test it yet. Use this information at your own risk. http://www.pirate4x4.com/tech/billav...art2/#csseries That's where I got most of my info Update: alternator seems to work fine like this. I haven't tested output, but it charges so... There's that Last edited by Ashikabi; 08-05-2019 at 09:53 PM. |
12-01-2018, 04:01 PM | #92 | |
Drives: Limited BRZ
What fans did you end up going with, what part no? The same I posted (30102029)? Or did you go with 30201522? I see those cost 95.03 on Summit.
12-01-2018, 04:07 PM | #93 |
30101522. I'm 99% certain that they will fit. I held it up to the rad and the fan motor is slightly closer to the floor than the thermostat fitting. So presumably the fan could be even deeper.
The Following User Says Thank You to Ashikabi For This Useful Post: | Sportsguy83 (12-01-2018) |
12-01-2018, 04:20 PM | #94 |
Made some short spark plug wires. I could have gotten away with just replacing the one that was touching the header but I did all of them. Wrapped in titanium sleeve. Made a super short one for the third back/passenger side as it was the one touching the header. Ended up being a tiny bit shorter than I intended so there is some tension on the wire I'm not happy with but it has plenty of header clearance.
Also got started on my switch panel. I need a switch to activate my Accusump for pre-oiling. I don't use my USB port so I'm deleting it and attaching a carbon fiber plate (eBay) over the face of my dash cubby. Also wired an "active" light for the Accusump right above my odometer control buttons. I have yet to make a mount for the Accusump and I'm still waiting on a solution to my oil lines. Left to do: install motor with transmission permanently shifter and reinstall interior panels Wire the starter oil and transmission coolers radiator ducting Intake Plumb catch can Clean up loose ends Start up |
12-09-2018, 12:01 PM | #95 |
Ok guys. Been pondering on modifying my radiator (Koyo) to be triple pass. I could slit the end tanks and insert a divider to force coolant thru in an "S" pattern. My concern is that the now 1/3 cross section won't flow enough and will create a great deal of pressure or will just straight up not flow enough. What do you guys think? I'm thinkin about it because obviously the car is torn apart and I hate redoing stuff. I could get a "universal" triple pass and make it fit if my current setup isn't good enough. But I'd have to pull the radiator out after the fact. I expect a proper triple pass would have greater flow than a modified single but modification is practically free. What do you guys think?
12-09-2018, 12:12 PM | #96 | |
Drives: Limited BRZ
Mitsurugi: Reforged
Given I have the swap in hot/humid weather, I’d say keep it simple; 2 pass for now. I have the full blown radiator with the bigger spal fans and have not had any temperature issues after getting the bigger fans AND getting a 160 thermostat from lingenfelter. If in the future you start seeing any temp issues then go and get the triple pass. I don’t think you’ll have issues unless you’re looking at tracking the car (in which case it might do fine, I just haven’t done yet so I can’t comment on how good will it radiator do).
12-09-2018, 12:51 PM | #97 | |
12-09-2018, 12:54 PM | #98 |
Drives: Limited BRZ
Ok, hopefully one of the people who have tracked it can chime in
