10-28-2013, 08:29 PM | #43 |
Yes you could use a small diameter spring with a similar rate. We can customize that option. Will add money to the cost of them though.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | PRORICAN (10-28-2013) |
10-28-2013, 10:52 PM | #44 | |
Senior Addict
Drives: 86 GT
By the way....can anyone explain whether adjusting the height on coilovers affect the spring rate in any way? i.e. does it increase stiffness the more you preload the spring and vice versa? Last edited by Fizz; 10-29-2013 at 01:28 AM. |
10-29-2013, 01:23 AM | #45 | |
Drives: TOYOTA
The Following 6 Users Say Thank You to Ro_Ja For This Useful Post: | *KID* (10-29-2013), chanomatik (03-28-2014), diss7 (11-01-2013), Fizz (10-29-2013), FT-86 SpeedFactory (10-30-2013), rcm47 (10-31-2013) |
10-29-2013, 11:27 AM | #46 | |
- Andy |
10-30-2013, 04:12 PM | #47 |
Drives: '13 WRB BRZ
Wow these look great, I prefer the stock top hat as it reduces the harshness of the coilovers, also should keep them quiet.
Definitely at the top of my list for the price.
In God We Trust - Hold No Faith That Violates Reason
10-30-2013, 09:46 PM | #48 |
Senior Addict
Drives: 86 GT
Thanks....so would that mean it's not recommended to corner balance a coilover with progressive springs? Because by doing so one side of the axle may end up with more preload than the other thereby giving uneven spring rates on that axle?
10-30-2013, 11:02 PM | #49 |
Looks great.
10-31-2013, 02:17 AM | #50 |
Senior Addict
Drives: 86 GT
10-31-2013, 02:32 AM | #51 |
Drives: TOYOTA
10-31-2013, 03:39 AM | #52 |
Senior Addict
Drives: 86 GT
Noob question: when adjusting vehicle ride height, does the increments on the shock body translate to equal increments in actual ride height?
i.e. say you wanted to lower/raise your car by 5mm, would you adjust the spring perch by that same amount? |
10-31-2013, 10:31 AM | #53 | ||
In reality though the differences will be extremely minor and I wouldn't worry about it. Quote:
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Fizz (10-31-2013) |
10-31-2013, 10:59 AM | #54 |
Drives: FR-S 10 #103 AT
At what driver weight should you start considering setting the driver's side a little higher to allow for additional compression to make the ride height be level when your lard butt is in the car? Yes, I'm large.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
10-31-2013, 12:05 PM | #55 |
Drives: EVO
Throw some bags of salt or concrete in the car to match your weight while setting the ride height. The softer the spring rate, the more pronounced the ride height change will be.
Of course, doing it this way, it's purely cosmetic and you are likely messing up the corner balance. Myself, I measure spring free length and then compressed length with my weight in the driver’s seat. Even up the spring length change left to right on the car and you should be pretty close to 50/50 cross weight. This of course assumes you are using good springs, like Hyperco or Swifts. I wouldn't try this with Ebay junk. |
The Following User Says Thank You to mike156 For This Useful Post: | mid_life_crisis (10-31-2013) |
10-31-2013, 03:48 PM | #56 |
Whatever comes with the coilovers. I'm either going very basic with a set of springs (probably "Yellows" based on reviews and product description) or entry level coilovers like ST or maybe step up to the Bilsteins. Obviously there won't be any adjustment to worry about if I go with springs.
Now that I think about it, I suppose I could just get in the car and have the wife measure the fender heights to see how far off they are.
Similar Threads | ||||
Bilstein Damptronic pics. | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 202 | 10-08-2014 08:13 PM |
Anyone ETA on Bilstein coilovers? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 01-31-2014 11:26 AM |
Bilstein Damptronic on an FRS | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-10-2013 12:15 AM |
All Bilstein and Muteki 10% off during month of July! | Infamous Performance | Brakes, Suspension, Chassis | 24 | 07-31-2013 01:52 PM |
Bilstein Shocks | wahsaihin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-23-2013 03:12 PM |
