Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-29-2017, 01:28 PM | #1 |
Drives: 2013 Subaru BRZ
what trans and diff mounts to get
Changing the diff and trans oil I'd like to do any mounts that are readily available with solid mounts can y'all suggest a brand and what mounts to get??
07-29-2017, 04:35 PM | #2 | |
Stiffer mounts will do nothing but allow the drivetrain to shake the frame more. I suggest you just change the fluids and call it good. (most likely there was nothing "wrong" with the old fluids anyway) humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | ichitaka05 (09-11-2017) |
07-29-2017, 05:48 PM | #3 |
Because compromise ®
Drives: Red Herring
Diff an trans mount is not then only for them to be good vibe stop. Also though meyby do stuff when look cool.
07-29-2017, 06:53 PM | #4 |
I'll copy and paste what a very helpful anon told me to help with sharper handling and shifting:
Sliding out has nothing to do with how stiff the drivetrain mounts are. That's purely suspension. If you throw 12K springs and massive swaybars on there, then yes. The suspension can't flex and the tires will break loose. If you put solid drivetrain bushings everywhere and leave the suspension alone, all that'll happen is you'll take all of the compliance out of the drivetrain and greatly increase NVH. You may increase wear on actual drivetrain components because the housings can no longer move under load and all the stress goes on the components themselves. You might chirp the tires if you shift like a gorilla, because the drivetrain can't flex to absorb the shock of a rough shift. Op, the second two letters of NVH are vibration and harshness. The engine moves around a lot. Putting it on sort of stiffer mounts such as Perrin or STI will minimize its movement at the cost of increased noise, vibration, and harshness being transmitted to the rest of the car. If you go with much stiffer mounts such as Cusco, it can quickly become intolerable. A lot of people who initially went with Cusco shortly downgraded to Perrin, STI, or OEM. Most people have only done engine mounts if they've installed an aftermarket header and overpipe and the pipes are hitting the subframe when the engine flexes. The transmission is connected to the engine, yes. So I wouldn't do solid mounts on anything. You want a little bit of compliance in the system to account for shock to the drivetrain, occasional clumsy shifting, normal movement under load, etc... OEM drivetrain bushings are very soft because they're a tradeoff between effectively transmitting power to the wheels and making too much NVH for the occupants. It's up to you to decide if that line is drawn in the correct place for your own preferences. For me, it isn't. When the engine twists under load I can feel it in the shifter. When I shift I can feel the diff move around. I don't like that. The Whiteline transmission bushing insert (there are others, that's just the one I bought) fixed the first issue. The transmission can still move, it just takes more effort to do so. More power gets sent to the diff instead of being used to move the transmission around. I also threw in an Energy Suspension rear shifter bushing, because it's $20 and I was already under the car. I can't even say if it helped with shifter feel or not. It's stiffer than OEM, but how much did that part really move anyways? For the diff, I went with the diff carrier inserts, but not the subframe inserts. Either one will reduce, but not eliminate, the OEM bushing compliance. Watch the below video; it's what convinced me to go with the diff carrier inserts. It's officially for Whiteline's subframe bushing inserts. Watch how the subframe mounting points move before and after bushing install. It didn't move a lot to begin with and now it moves less. Still moves, just not as much. Then look at the two big vertical bushings in the middle of the subframe behind the swaybar. Those things flop around like professional soccer players. Those two bushings and two smaller bushings at the front of the diff are the diff carrier bushings. If you shift heavily and you hear a clunk from the rear of your car, you're hearing the diff flop around on those bushings. Whiteline's inserts remove a lot of that compliance, but not all of it. Putting power down to the wheels has gotten much smoother since installing those bushings, at the cost of a little gear whine at low speeds. At high speeds road noise covers the whine. I didn't do both sets of bushings because I specifically wanted to leave a little compliance in the system and not significantly increase NVH. If you're after that super loud mechanical whine that you hear from actual race cars; what you're hearing are straight cut gears in the transmission meshing. Most consumer cars have helical cut gears. Straight cut gears are much stronger and can take a lot more abuse, which is why they're in race cars. They don't care if it's super loud and harsh, because performance comes before comfort. In consumer cars, it doesn't. Very few people would buy a street car that sounded like that from the factory. Whiteline diff carrier bushing inserts Whiteline transmission insert Energy Suspension rear shifter bushing MTEC shift springs (very highly recommend these. It strengthens the shifter's return to center.) If you're after gear whine, do the diff bushing inserts. If you like those but you'd like a little more, then do the subframe inserts. |
The Following User Says Thank You to NRXRaptor For This Useful Post: | TofuJoe (07-30-2017) |
07-30-2017, 08:45 AM | #5 |
Señor Member
I have the TRD motor and gearbox mounts. I got them because in some situations my overpipe was hitting my subframe. You definitely get more shake and vibration from the motor and you get a noticeable increase in noise from the gearbox. Other than stopping the overpipe hitting the subframe and increasing NVH they haven't changed how the car drives.
1974 TA22 Celica
2013 86 GT |
08-31-2017, 10:19 PM | #6 |
Well I did them I did the Perrin transmission support the whiteline little wedge thing under it
The rear shifter bushing the diff mounts and the rear subframe also got whiteline inserts it increased nvh a LOT when I started the car for the first time I thought I broke something No driving impressions until I take it up the mountian |
09-02-2017, 12:49 PM | #7 |
I have put about 500mi on them now initially in town driving from the shop to my house I hated it it's way louder in the cabin especially from 3500 on up at 3500rpm I get this weird resonance that sounds like the cars falling apart lol 20 year old pho20 would have loved this but late 30s pho20 was annoyed by all the engine noise. There is lots of gear whine and you can hear the shifter click into place (both sound cool as shit)
Driving impressions man it shifts a lot better now it's so fun rowing through the gears I find myself making unnecessary shifts just to hear that snick of it going into gear Through the mountains I have a lot of long sweepers that are high speed (top of 5th gear) before the bushings if I would get on the gas through the turns the car would start to push and if I let off of the gas I would notice the front would start to tuck in this eliminated that it's much more consistent throughout the turn reguardless of throttle input im sure this would be much more noticeable at the track All in all for me it was worth the tradeoff in nvh for more precise handling/shifting but it's definitely not for everyone if I wasn't driving through mountain passes daily and was commuting in the city I'd really give it some thought |
The Following User Says Thank You to Pho20 For This Useful Post: | Somerandom18 (09-02-2017) |
09-11-2017, 08:07 PM | #8 |
Nvh has all but gone away (or I've gotten used to it) loving this so much I've decided to do the whiteline steering rack bushings and Perrin steering rack lock downs
09-11-2017, 08:27 PM | #9 |
Site Moderator
Drives: ichi 86 Project
^This, you just got used to it... but hey, as long as you love it, that's all it matters
09-12-2017, 12:31 AM | #10 |
That's good to hear. I'm doing exhaust before I do other things (still gotta do overpipe and frontpipe) but I'm glad I helped someone by posting some copypasta from a much more knowledgeable anon
09-13-2017, 09:56 AM | #11 |
Similar Threads | ||||
Help! Washers for Oil/Trans/Diff | Bevans555 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 05-12-2023 09:41 AM |
What oil to use in your Engine, Trans, Diff? | ArKiTeCkT | CANADA | 31 | 03-10-2018 03:23 PM |
What the hell came out of my trans/diff? | BatStig | Engine, Exhaust, Transmission | 13 | 04-06-2015 02:35 PM |
Where can I buy the trans and diff washers? | ngabdala | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 05-09-2013 12:35 AM |
Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 03:11 PM |
