03-25-2014, 10:00 AM | #29 |
Drives:
Now where can I find the bulbs for the hvac in blue? Sent from my iPhone using Tapatalk
Sent from my Subaru BRZ Limited using plastic cup 2.0
03-29-2014, 01:26 AM | #30 |
Drives: Subaru BRZ
You guys do know that the voltage drop for red LEDs is usually around 1.7V and White LEDs are around 3.3V! That could be why the BRZ and FRS LED clusters have different numbers of LEDs.
Depending on how their wired, doing this might cause damage. I guess nobody has had any issues, but I would definitely have probed the voltage rail and included resistors for proper current limiting. You don't want to overload any LEDs or voltage regulators. BTW, my speedo is off by +1mph when compared to the digital. Never messed with my cluster so thats from the factory. |
03-29-2014, 02:16 AM | #31 | |
Drives: 13 CSB BRZ Ltd
I can speak with some authority on this subject. Swapping blue LEDs for red is not a problem.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
03-29-2014, 02:19 AM | #32 |
Drives: Subaru BRZ
03-29-2014, 11:21 AM | #33 | |
03-30-2014, 01:53 AM | #34 |
Drives: Subaru BRZ
03-30-2014, 02:27 PM | #35 |
The Following User Says Thank You to Acree For This Useful Post: | sshole (04-03-2014) |
03-30-2014, 02:32 PM | #36 |
And nope, it's just a simple resistor LED series string. But the LEDs draw enough current to put out plenty of light. There's no reason to change the resistor in this particular application when going from red to blue. If you were going from blue to red, I would recommend changing resistors.
04-03-2014, 07:47 AM | #37 |
Great DIY!! I like the look of the darker red for the end result.
Off topic question-sort of. Never soldered anything before. Any recommendations for a good place to learn besides trial and error? |
04-03-2014, 08:08 AM | #38 |
Find something that has surface mounted components and start soldering away. Learn how to desolder components - this is especially useful when working in the gauge cluster.
The Following User Says Thank You to sshole For This Useful Post: | Mooseknuckle44 (04-03-2014) |
04-03-2014, 08:09 AM | #39 | |
But yes. Agreed. Don't buy ebay electronic components. They're terrible and you'll have at least 10% dead on arrival. |
The Following User Says Thank You to sshole For This Useful Post: | Acree (04-03-2014) |
04-03-2014, 08:10 AM | #40 |
I'm assuming one soldering tool is just as good as the next? Or is there a Walmart version and a Snap On version?
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
04-03-2014, 08:32 AM | #41 | |
Yes. I've been getting by with crappy throw-away $10 RadioShack soldering irons for the past 10+ years. I've seen no need to upgrade to the $50+ units from the "Snap-On" brands. |
04-03-2014, 02:23 PM | #42 | |
But food for thought, a soldering iron really is a tool that will last you 15-20 years if taken care of correctly. My personal recommendation would be an entry level constant temperature station, like [ame="http://www.amazon.com/Weller-WTCPT-Temperature-Controlled-Soldering/dp/B00004W463"]this.[/ame]
The Following User Says Thank You to Acree For This Useful Post: | Mooseknuckle44 (04-03-2014) |
Similar Threads | ||||
Gauge Cluster on FRS | tonytduc | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 07-24-2017 09:56 PM |
BRZ cluster gauge swap? | InYOHface | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 03-25-2017 06:31 PM |
WTB gauge cluster | Basti | Want-To-Buy Requests | 3 | 04-09-2014 02:54 PM |
Gauge cluster mod? | kALMIGHTY | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-27-2013 10:59 PM |
Want to try a gauge cluster experiment with me? | stockysnail | Northwest | 2 | 04-12-2013 10:57 AM |
