Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-07-2019, 11:21 PM | #1 |
Drives: Scion Frs
Rota titans and Teen street basis for a track day?
I have some Rota titan 18x9.5 +38 with 255/35/18 michelin PS4s in front and 255/40/18 rear. I am running Tein Street basis coilovers.
I also have Stoptech pads, stainless lines, slotted rotors and some ST f/r sway bars. I know rota has somewhat of a reputation for cracking under high pressure, but considering the are JWL/VIA certified how likely is that to happen? Also for the coils, since there is no dampening/camber/caster adjustment and relatively soft springs and damping rates meant for street driving, how well will they do on track? Planning a Track day in March at VIR. Ive done 3 autoX events on this car but this will be my first track day. |
01-07-2019, 11:43 PM | #2 |
Drives: BRZ 2017 Pure Red, MT
I'm no expert, but depending on what model of stoptech pad you got, that's more likely your weak spot than anything else.
The Following User Says Thank You to nico_rsx For This Useful Post: | kch (01-08-2019) |
01-08-2019, 12:20 AM | #3 |
Thanks
What's up with those tire sizes? As the guy above said, I would upgrade to a track spec pad before you go. VIR has some decent straights, at least the back straight braking zone is uphill. From what I recall the track wasn't particularly hard on brakes but there are a lot of track configurations so YMMV. In any case I think you would benefit from upgraded pads, for peace of mind if nothing else. Seen a lot of different cars destroying stock and Autocross/mixed duty pads.
Other than that don't overthink it. Even if you don't get new pads, run what ya brung. Have fun and learn.
The Following User Says Thank You to ZionsWrath For This Useful Post: | kch (01-08-2019) |
01-08-2019, 12:31 AM | #4 |
Drives: '13 FRS - STX
This is a must read:
http://www.ft86club.com/forums/showthread.php?t=25485 You'll be fine as a newb, are you getting a coach? Make sure you do your best to connect with your coach and if it's not working out try and switch before lunchtime, not everyone connects with every coach. As above brake pads and brake fluid are the weak points in your setup right now but don't try to be a hero, try and listen to what the car tells you and you'll be fine. If you want to try and prevent brake problems which would cause you to at a minimum slow down and take it easy or worst case risk a crash check out upgrading to at least a hybrid pad and better brake fluid. Here's a big list of brake pad reviews from forum goers. Be prepared that this will be a $200+ cost if you want to upgrade but it's very easy to swap pads since a lot of them are annoying to DD, but most entry level track/hybrid pads will be good for autox too. http://www.ft86club.com/forums/showthread.php?t=23680 If you're thinking about damping rates and spring choice while you're out there you're probably not thinking about the right things. Don't pound the curbs and go off track and your wheels will be fine. Most importantly have fun. |
The Following User Says Thank You to strat61caster For This Useful Post: | DarkPira7e (01-08-2019) |
01-08-2019, 12:49 AM | #5 |
Drives: Scion Frs
Currently I just have the stop tech street pads, but im running castrol SRF fluid. Tire sizes are staggered like this just due to the fact that I got a 40 sidewall last time all around when coming from the previous owners stretched 235/40/18s, and now i am moving to a 35 sidewall and just wore through the first 2/4 tires.
01-08-2019, 01:59 AM | #6 |
[insert cool phrase here]
Drives: BRZ Premium
Lol PS4's? For track days? Lol
It's a good street tire, but no where near a good track tire. As others said brake pads and fluids are going to be your best upgrade. Oem wheels and good tires would be more than enough.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
01-08-2019, 08:25 AM | #7 | |
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Rotas will be fine. They had an early reputation with a few wheels. In any case, thicker spokes > thinner spokes. This is coming from someone that did have a rota subzero break at an autox in 2003 (yes, 16 years ago) which they replaced no hassles. Nothing drastic happened, just made a sound like a pebble in the brake rotor. Inspected, found, and put on spare. Just pay attention to what your car is saying. Not saying this to scare you... you should be fine considering the nature of the tires you want to run. (again, not ultimate grip, but will break away more progressively). Honestly, I wish everyone learning track days would just run decent all seasons... you learn a LOT more about the friction circle, more safely, while you learn the lines. --kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
The Following 2 Users Say Thank You to Imp For This Useful Post: | GrandSport (01-09-2019), strat61caster (01-08-2019) |
01-08-2019, 10:16 AM | #8 |
Drives: Scion Frs
The PS4s are just my daily tires, if i ever got a 2nd dedicated set id just get 17x9 RPF1s and RE71Rs. But Im just gonna run what i got, but ill prob end up buying a 2nd set of race pads
01-08-2019, 10:27 AM | #9 |
PS4S are fine on the track for a beginner. I would recommend against RE71R for beginners and most people that aren't trying to set 1 fast lap.
Anyway...as others have said, keep on eye on your brake pads or bring another set. Check your alignment and the general maintenance of your car. The thread @strat61caster linked is good. - Andrew |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
01-08-2019, 12:42 PM | #10 |
I don't know why PS4S is getting a bad reputation in here. It's a perfectly fine tire to take to the track, especially in OP's case.
The PS4S tire is also the main tire used for OLOA - It doesn't suck
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | kch (01-08-2019), Racecomp Engineering (01-09-2019) |
01-08-2019, 02:01 PM | #11 |
Drives: Track preped NA FRS
The PS4S are not a dedicated track tire for sure, but they are not a winter or a 4 season tire. I mean, Mike Kang won Global Time attack SLB enthusiast (I think?) class with them, and that was a turboed car with lots more power and a beast of a driver behind the wheel. I can see the PS4S lasting an acceptable amount to a beginner and maybe even an intermediate driver.
01-09-2019, 10:34 AM | #12 |
Drives: 06 Exige, 17 BRZ PP
Go with the car as-is, you will be fine. There is zero reason to upgrade pads for your first track day, you will be learning and not going very fast. Its much more important to focus on you, the driver your first few track days.
As you get more experience, you will see your car's weaknesses and where you will need to make modifications. Have fun! VIR is a great track, what club are you running with? |
01-10-2019, 06:02 AM | #13 | |
Drives: 2014 BRZ Limited
Anyways, OP your car sounds fine for a first track day. Read the prep thread at the top, check/change your fluids, check your rotors and pads and have fun. |
01-12-2019, 02:49 PM | #14 |
btr.life
Drives: 2022 GR86
I'll echo what the others have said, just go with what you have. As a beginner with those tires, you won't be creating enough grip to stress the wheels. I've tracked on my Rota's with RE71R's many times, no issues.
One thing I would recommend is be conscious of your braking habits. The way you brake will affect your pads/braking ability more than the pads/fluid itself. In other words, when you brake, brake hard and quick, do not drag your brakes going into a turn - or "pre-brake" before the braking zone. You want to spend as little time on the brakes as possible to keep them from overheating. Lastly, have fun!
Tags |
rota, stop tech, tein coilovers, track, track day |
Similar Threads | ||||
17x8 +45 17lbs Rota Titans FS/FT | Keenercarguy | Wheels and Tires | 11 | 08-05-2018 12:56 PM |
FS: (FL) Bronze Rota Titans 17x9 +42 Hoosier R7's 245/40 | Deep Six | Wheels and Tires | 2 | 05-04-2018 07:05 AM |
WTB Rota Titans | hattrickey | Want-To-Buy Requests | 1 | 02-10-2015 07:46 AM |
Magnesium black 18x8.5 rota titans on wrb brz. | Bongertz | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-05-2014 03:57 PM |
WTB: Rays 57xtreme SPs/ Rota Titans | Taro | Canada Classifieds | 1 | 09-09-2014 04:22 PM |
