Old 06-30-2015, 08:41 PM   #1
Jake_86
Jake_86's Avatar
Trans insert and block whine reduction
Question for those with a (torque solutions/whiteline etc) transmission insert AND/OR the replacement transmission block (Perrin, supertek etc).
I have the combo and the feel is great but after 3-4 months or so, the loud transmission whine( in 6th gear mainly) is just too much for me. So I'm wanting to remove one of the two to reduce the whine once i install a new header. I know there will be whine with either but I'm wondering which one will reduce it more? (The block I'm guessing?) thanks. Pic for attention.
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 06-30-2015, 08:44 PM   #2
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
hmmm probably the block, since I have that and it whines, but my friend has the insert and I don't notice it whine as much. i could be wrong though
The Following User Says Thank You to Wes For This Useful Post:
Jake_86 (07-01-2015)
Old 06-30-2015, 08:45 PM   #3
ramiram1984
Drives: 2016 STi DGM
no pic needed for attention. but sure, just get rid of the tranny support mount. put stock back on.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
Old 06-30-2015, 10:41 PM   #4
Jake_86
Jake_86's Avatar
Do you get that 6th gear whine at <50mph and another quieter when 70-80?
(Because I don't really mind the whine first few gears)
Old 07-01-2015, 12:01 AM   #5
Wes
Wes's Avatar
yup only in 6th gear under 50 mph
Old 07-01-2015, 07:46 AM   #6
vroom4
Go back to 100% stock bushing under tranny.
vroom4 is offline   Reply With Quote
Old 07-01-2015, 08:36 AM   #7
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
I'm highly tolerant of noises because of aftermarket parts. The cusco motor mounts are installed in my car and it does not bother me one bit while others cant live with it. That said, this combo (Torque Solutions/Whiteline) has been the only one that has beaten me. The noise from the trans (supercharger like whine) was annoying for the not noticeable "performance" gain. Left just the Whiteline and I'm happy.
Also, I think you can only have the option to keep the Whiteline because you cant use the Torque solution by itself since it was meant to work with the bushing.
endless_pain is offline   Reply With Quote
The Following User Says Thank You to endless_pain For This Useful Post:
Old 07-01-2015, 11:41 AM   #8
emutcfut
Drives: 2013 Argento
Get the STI Group N transmission mount. It's like the stock mount but with thicker and harder rubber. It costs a fair amount more than an insert but if you're noise sensitive than it's worth it. I have it installed for over a year and haven't heard and whine.
emutcfut is offline   Reply With Quote
The Following 2 Users Say Thank You to emutcfut For This Useful Post:
chaoskaze (07-01-2015), norcalpb (10-22-2021)
Old 07-01-2015, 12:11 PM   #9
Jake_86
Jake_86's Avatar
not sure if your thinking of the correct part due to the brands i used.
I have the torque solutions insert here
i think you have the whiteline version here
Is that Correct that is the part you left on?
because the part im removing would be this super tek block when i think you are referring to removing this torque solutions part
Note: i do have the TRD quickshifter kit which added a similar part but i doubt it adds the whine
Thanks for the help!!!!!
Old 07-01-2015, 12:30 PM   #10
endless_pain
My apologies, misinterpreted when read the "AND/OR". I thought you meant this:
http://www.forcedfabllc.com/ForcedFab-Transmission-Mount-Stiffener-Subaru-BRZ-Scion-FR-S-_p_6927.html
Which works with the bushing. So you have both for a stiffer trans mount.
To answer you question, I have the whiteline trans insert with the trd short shifter and was using until very recently the energy suspension shifter bushing. Zero whine.
Then I replaced the energy suspension piece for the one that came with the short shifter, still zero whine.
Sorry for the confusion.
Old 07-01-2015, 01:05 PM   #11
OkieSnuffBox
Drives: '23 BRZ Limited
Stop lugging the engine around like that.
Old 07-01-2015, 01:08 PM   #12
Wes
Wes's Avatar
oops i shall, thx!
Old 07-01-2015, 05:36 PM   #13
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
I get whine out of my whiteline insert. I've been meaning to take it out buy am too lazy.
P@ul is offline   Reply With Quote
Old 07-01-2015, 06:33 PM   #14
Jake_86
Jake_86's Avatar
How loud is your whine with just insert? Because I could tolerate a lower decibel
FS: Kartboy Short Shifter w/Rear Bushing & Trans mount insert Opie Transmission and Driveline 4 09-16-2013 05:43 PM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 08:45 PM
Trade your BRZ fender insert for FRS insert? Whiteout/Satin white pearl jacobzking Exterior Parts (Aero, Lighting, Etc.) 0 06-05-2013 12:15 AM
AT trans whine? Anyone else? Hardrock4445 Engine, Exhaust, Transmission 1 05-30-2013 06:46 PM
