Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-12-2017, 07:25 PM | #15 |
Only happy when it rains.
Drives: series.blue
low end torque on a na car is 100% about back pressure. This is the exact opposite of what you want for high end performance. Down at 2000 rpm or so the car makes very little actual torque, so every little bit helps. The second you increase pipe diameter of any part of the exhaust the low end torque will suffer.
As was said though, just rev it a little higher and it will be fine. |
09-13-2017, 08:09 AM | #16 | |
Drives: BRZ JDL uel headers oft Perrin 2.5
The Following User Says Thank You to Leland For This Useful Post: | why? (09-13-2017) |
09-18-2017, 11:27 AM | #17 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
I'm almost 100% positive that what you (and i) was experiencing was all in our heads. The Perrin has a slight more airy tone to it. You can hear a little bit more air being pushed out when you step on the throttle. Overall though other than that the car seems to drive exactly the same.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
09-20-2017, 03:50 PM | #18 | |
09-20-2017, 10:20 PM | #19 |
Drives: Wrb 2014 limited brZ
Just a comment about noise......
I have the same exact setup. I drive with my backseats down 100% of the time. It's way more enjoyable to hear both the header and exhaust than with the seats up. With the seats up, it's well, kind of quiet. |
09-21-2017, 02:55 PM | #20 |
[QUOTE=dtrop;2981468]Just a comment about noise......
I have the same exact setup. I drive with my backseats down 100% of the time. It's way more enjoyable to hear both the header and exhaust than with the seats up. With the seats up, it's well, kind of quiet.[/QUOT I am generally okay with quiet but I will have to try with the seats down for curiosity sake. |
The Following User Says Thank You to Leland For This Useful Post: | nullredvector (07-01-2021) |
07-01-2021, 12:26 AM | #21 | |
Drives: BRZ Limited PP '17
How did you test for leaks, soapy water? Did you blimp the throttle? Sent from my ONEPLUS A6013 using Tapatalk |
07-02-2021, 07:51 PM | #23 |
Drives: 2020 Brz Sport-Tech Auto
I have the 2.5 resonated Perrin and have found a fairly loud resonance around 2700 rpm. It is mostly noticeable under acceleration but is always there. The better Subaru hangers that have been discussed on another post helped somewhat but did not eliminate it.
I wanted to hear the exhaust but did not want the annoying drone. I have the auto so it is more difficult to adjust the running rpm but the sound from the exhaust when cruising on the highway is fine. I have installed a couple of small lined muffler sections inside the muffler outlets and have added a little sound barrier layer to the trunk. It now sounds the way i like. After reading this post I will check the connections to see if there are any leaks that would contribute to the noise. |
07-02-2021, 08:36 PM | #24 |
Also check out the thread for the exhaust hangers that come with the STI axle back exhaust that really help drone
2013 Series 10 FRS #553
Similar Threads | ||||
Does anyone have any experience with Perrin's Positive Steering Response System? | autograph | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-31-2017 08:23 PM |
FS: Perrin 3in Catback Exhaust, Perrin 3in Front Pipe, Perrin Overpipe SOLD | johnb831 | Engine, Exhaust, Bolt-Ons | 13 | 05-21-2015 05:27 PM |
Perrin Steering Rack Lockdown: Anyone Have Experience? | TouchMyHonda | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-20-2014 01:27 PM |
Perrin Front Control Arm Braces: Anyone have Experience? | TouchMyHonda | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-20-2014 02:39 AM |
My experience. Injen/Perrin | Chen | Northwest | 10 | 10-20-2012 10:18 PM |
