Old 11-21-2012, 05:31 PM   #1
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Torque for Android
Has anyone used this or is using this now? The tablet is paired, and the reader is plugged in and the vehicle profile is set up.
What else do i, should I, do before using it?
Sent from my Nexus 7 using Tapatalk 2
Freeman is offline   Reply With Quote
Old 11-21-2012, 11:10 PM   #2
shishand
Drives: Whiteout
Use it.. Its a reader it, I'm almost 100% sure it can't possibly do any damage to your car
shishand is offline   Reply With Quote
Old 11-21-2012, 11:37 PM   #3
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
I've found that with some of the less expensive BT dongles that it can cause the car to go into limp mode.
I bought one from newegg that I posted on in another thread and the dongle would cause my car to fault if the ELM327 timing adjust was disabled.
I then bought another different model off Amazon and turned the ELM327 timing adjust back off. The fault happened again causing my car to go into limp mode again.
I turned the ELM327 timing adjust on in the app and it hasn't gone back into limp mode again.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
Old 11-22-2012, 02:52 AM   #4
Freeman
Freeman's Avatar
Lol well I hadn't even thought of it damaging the car. I was more or less looking for tips on set ups and such.
Old 11-22-2012, 03:01 PM   #5
shishand
Drives: Whiteout
Oh by your first post i assumed you were scared to even try it, is your set up not working?
Old 11-22-2012, 03:07 PM   #6
neutral
Drifter-Wannabe
Drives: Firestorm MT FR-S
Send a message via AIM to neutral
I use it. Mostly just in the morning while my car is warming up. Start the car, go back inside my house, wait till torque tells me the coolant temp is warm enough. Bluetooth is awesome lol
Sent from my Nexus 4 using Tapatalk 2
neutral is offline   Reply With Quote
Old 11-22-2012, 04:49 PM   #7
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
whoah, this is very very strange. Hop on the torque site and send him a message to investigate, it shouldnt be writing to the ecu, let alone in a way that would trip a safe mode.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 11-22-2012, 11:05 PM   #8
whataboutbob
In every case where it went into limp mode it had a bus error when I scanned for error codes. That was my hint to turn the timing adjustment function on. I've never had any issues with the SEL/ECU problems others have noted. I've also never had my ECU flashed by the dealer. Maybe a newer ECU build wouldn't have this problem?
BT OBDII/Android/Torque Confirmed working Dadhawk Engine, Exhaust, Transmission 54 12-06-2012 12:57 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 10:37 PM
