Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-12-2014, 08:06 PM | #1 |
Drives: Toyota FT86 2014
Top speed
Hi guys,
I wanted to try my 86 with the top speed and I could only reach up to 185 km . It wouldn't give more! What would the problem be? And I don't really feel there is power in my car, is this normal? |
07-12-2014, 08:14 PM | #2 |
Drives: 2013 Whiteout FR-S
Here's a list hope it helps
NOS the big bottle Wait better make it 2 of them Next you'll need a laptop to set up the stages of the NOS Make sure you pay attention if the lap top warns you of any manifold problems Don't just slam it shut and tell it to shut up Don't drive with too heavy of a foot either And please don't blow the welds on your manifold intake or exhaust (especially the plastic ones on the intake manifold) Don't blow yourself up Hope that helps have fun |
The Following 10 Users Say Thank You to Ghost 86 For This Useful Post: | BlueDubbinTDI (07-13-2014), ciro (07-13-2014), Creole (07-16-2014), Dipstik-sportech (07-13-2014), Gt86_nick (07-13-2014), Muaddib (07-13-2014), raven1231 (07-13-2014), troek (07-15-2014), wparsons (07-13-2014), wtrxprs007 (07-14-2014) |
07-12-2014, 09:54 PM | #4 |
Drives: 2012 86
07-13-2014, 05:58 AM | #5 |
Yeah, your right but i don't think up to 180 Km, that would be so F. stupid
07-13-2014, 05:15 PM | #6 |
There are many factors that limit top speed. The most important one is if your IAM has dropped low. This happens if your running lower octane fuel. To fix this you need to make sure the fuel you run is of sufficient octane not to lower IAM (IAM should be 1 all the time). If your IAM is at 1 then you should be able to hit at least 225 km/h. After this the speed limiter kicks in a starts to close throttle from 100% to 50% (see my post linked below). To fix this you have to remove the top speed limiter via ecu mapping. I am from bahrain so also have a Middle East car and I can get my brz to 245km/h easily.
Two other things effect top speed. First is if you have a body kit on your car your top speed will be down by a lot. Second is if you have big wheels (width and diameter) this would reduce your achievable top speed too. http://www.ft86club.com/forums/showthread.php?t=58835
2013 Lightning Red - 6MT Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler |
07-13-2014, 09:47 PM | #7 | |
Drives: Scion FRS asphalt
07-14-2014, 12:05 AM | #8 |
Drives: 2013 wrb brz
[ame]http://youtu.be/sAC5dPFKeHI[/ame]
The Following User Says Thank You to brz2013 For This Useful Post: | newports (07-14-2014) |
07-14-2014, 05:55 AM | #9 |
Amazing the maturity of responses in this thread...
07-14-2014, 07:11 AM | #10 | |
Drives: 2017 Fiesta ST
Maybe the air filter is clogged or something? How was the ambient temperature while you tried? Last edited by OnkelC; 07-14-2014 at 07:14 AM. Reason: typo |
07-15-2014, 08:17 PM | #11 |
Drives: 2014 BRZ
Top speed
I got up to 192.... Canadian spec. Ran out of road lol
07-15-2014, 11:59 PM | #12 |
Drives: 2012 Toyota 86
185 is almost certainly speed limiter. these cars hit that no problem. the speed limit in these cars is very smooth so you barely notice you hit it. its not sudden like some cars.
Similar Threads | ||||
Seeing the top speed you went in the BRZ? | Corby26 | BRZ First-Gen (2012+) -- General Topics | 42 | 12-08-2013 04:21 AM |
Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
D-SPEED | ANREX | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-29-2012 07:47 AM |
BRZ top speed | speedracer38 | BRZ First-Gen (2012+) -- General Topics | 66 | 07-08-2012 03:37 PM |
speed | eindio | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-27-2012 10:59 AM |
