09-02-2016, 04:07 PM | #1429 |
Drives: WRB Brz
Would anyone be able to take a look at my datalog? I'm waiting to hear back from motoeast but want to make sure it's running safe and get some advise.
kraftwerks supercharged with UEL header and catback. Capture contains 3rd gear pull and the other where the rpms stick at 2k when the clutch is disengaged going to a stop. Takes a few seconds after stopping to go down. When doing normal driving, I notice a drop in power from 2.5k to 3k. Haven't captured that but it's noticeable. Working on that capture. Thanks in advanced! |
10-25-2016, 10:06 AM | #1430 |
Drives: Firestorm
Hey Everyone,
Purchased my OFT this past weekend.Thanks Shiv! On stage1 93Oct. Hopefully a UEL header in the near future. I have been doing as much reading as i can to learn about the tuning process. Still trying to learn what correlations to look for. Could someone shed some light on what I am looking at: http://www.datazap.me/u/tvars/102420...l?log=0&data=1 |
10-28-2016, 09:52 AM | #1431 |
Drives: Silver 86
Hi All,
Running a Stage 1 OFT Tune on our local gas which is only 95 ron here in SA. I have been working on getting this tune dialed in but I am struggling with the AFR. AFR is always running a little leaner then the Commanded AFR. I have tried absolutely everything and cant get the AFR to get rich or very close to the commanded AFR. It's getting close, just want to find out if this is looking okay? Cause I dont know what to do anymore Here is a log: Was about 30'C out, 3rd gear 2 pulls http://www.datazap.me/u/86driver/281...16-20-28-31-34 |
10-28-2016, 02:43 PM | #1432 |
AFR is close enough to target and there's no knock. I'd call it a day, you done good.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
10-31-2016, 08:03 PM | #1433 |
Drives: 15' FRS
http://datazap.me/u/richardfrs/jdl-u...data=1-5-12-13
GUYS I'm fairly new to this so please refrain from bashing due to my ignorance. I have installed the JDL UEL and tuned it with OFH specific tune with the VVT tables posted by Shiv somewhere. I datalogged today (2-7k pull) and I am getting one instance of -0.7 knock correction and EXTREMELY varying FLKC during the pull. (This is very bad right) IAM Seems to be at 1. For fuel I am using Shell vpower 91. The only higher grade (which is debatable) fuel here is Petro 94. ANY HELP IS APPRECITED!! Should I switch to the OTS Stage 2 tune? |
11-03-2016, 12:48 PM | #1434 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
11-03-2016, 09:35 PM | #1435 | |
Drives: 15' FRS
I thought the car was running real bad so for now I switched to the off the shelf stage 2 tune. Before I was using the OFH specific stage 2 tune. I will do some more logging but this time I'll up the fuel to petro 94 and see if that helps. Thank you very much for your input! |
11-04-2016, 10:24 PM | #1436 | |
Intent > Content
11-05-2016, 02:57 PM | #1437 |
Boost Creep
Drives: 2016 HyperBlue BRZ
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
12-03-2016, 08:13 PM | #1438 |
Drives: 2016 Asphalt FR-S, 2008 E90 335i
Hey everyone. Brand new OFT tablet user here. I have the Stage 1 US 91 tune loaded currently. Attempted to do some data logging but I have some very weird values... ie IAM pegged at 0. I made a few logs and they all show the same.
I swear I saw a similar issue in another thread and that a template update solved the issue. I cannot seem to find said thread however... If somebody could take a look and point me in the right direction I would be very grateful. http://datazap.me/u/jevenson123/log-...0&data=1-11-12 * Edit * After some more research, it appears OFT may not yet support proper data logging for my CAL ID. F00C. If someone could chime in just to make sure I am not crazy... Last edited by Blue_Elite; 12-03-2016 at 08:32 PM. |
12-14-2016, 09:14 PM | #1439 |
Drives: 2014 BRZ
If anyone is feeling generous and could give me any pointers. Advance Multiplier keeps dropping to .75ish after a few days, this is a 3rd gear WOT pull minutes after a fresh reflash. Shell 93 Octane, no boost leaks and/or pre-turbo exhaust leaks. Thanks in advance!
http://www.datazap.me/u/kevinlebrun8...ot?log=0&data= |
12-14-2016, 10:52 PM | #1440 |
Your log is broken; re-upload it removing the lines starting with # at the beginning of the file.
12-15-2016, 09:39 PM | #1441 |
Drives: 2014 BRZ
12-19-2016, 04:50 PM | #1442 |
Drives: 2014 86 GTS
Hi All,
Im just refining my e85 tune (actually using eflex e70ish relatively consistent) and am slightly confused where the car has -6 LTFT but shows the afr is lean in relation to commanded afr. Fuel trims are pretty good most of the time but spike to a supposed rich -8% at times probably due to my maf scale and myself trying to keep it perfectly smooth. actual AFR is 15.7 with commanded being 14.6 with the negative spikes, though on most of the log its ok I'm using Waynos v111.2 e85 stage 2 tune with my scaled maf (trims used to get to -13% with the supplied maf) Let me know what you guys think |
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
