Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
12-13-2017, 08:17 PM | #29 |
Drives: 2016 4Runner / 2016 FR-S
Another Hard Start
Update:
Tonight I went to start my car, and unlike last time, this time it didn't start at all. On the first crank I held it for about 5 seconds and it sounded like it was about to pick up but nothing. Second crank, no start either. Waited 15 seconds, cranked it a third time and had to hold it for about 6 seconds until it started. I drove earlier today and didn't have this problem, even though the weather this morning was colder than what it is right now tonight. Hope this doesn't become an issue...
I pay more per month for insurance than I pay for the FRS.
12-13-2017, 10:28 PM | #30 | |
The Dictater
Drives: '13 Red Scion FRS
Either bring it to a mechanic/dealership to resolve or do the following. Step 1: when you turn the key to on (not ignition) do you hear the pump in the back priming? Should sound like a buzz for a second or 2. If so, proceed. Step 2, does everything you expect come on when the key is in the on position? Step 3, take your battery to an auto parts store and have them test it. If it's good, it should come back fully charged. Doesn't usually cost anything. Step 4: if battery is good and charged and car still doesn't start, check all cables and ground straps for damage or looseness. If car starts, but after a while you have this issue again, get the alternator tested. Also usually doesn't cost anything. Step 5. Do you always fill up at the same place? Might be consistently bad gas with water seeping into the tank at the station. After that, things get more difficult. |
12-14-2017, 01:36 AM | #31 |
Drives: 2013 FR-S 10 series [755]
1) E85 without a proper tune
2) battery suck 3) Bad Alternator Get a free check at pep boy, oreiley first, if battery and alternator are ok, go to a dealer. |
12-22-2017, 07:23 PM | #32 | |
12-22-2017, 07:44 PM | #33 |
Itsalex is not running E85 so all of the answers to his questions saying that E85 is the issue are meaningless in his context.
12-22-2017, 09:04 PM | #34 |
義理チョコ
That's wonderful news. I'm thrilled for you.
12-23-2017, 10:57 AM | #35 |
Drives: 2013 BRZ Sport-tech WRB
Is this your daily? How long since you last filled up with gas?
If it's been a while, could be the low RVP of summer blend gas causing it to be difficult to ignite when cold. |
02-01-2018, 11:42 AM | #36 |
Update:
It's been more than a month since I've experienced this issue again so I don't think my vehicle is at fault. Since the last time it's happened, the temperatures have only been colder and it starts just fine. I think it's safe to assume that I probably had a bad batch of gas or something. Will update if it happens again.
02-01-2018, 12:34 PM | #37 | |
Senior gif poster
Drives: 2013 Asphalt FRS
02-04-2018, 12:00 PM | #38 |
Car N00B
Drives: Honda Accord (2002)
My steering wheel has been extremely squeaky this year... I've been meaning to look into the issue but haven't had a chance... From what I've seen on here others have run into this issue when it's cold out as well...
Sometimes cold weather does weird things... |
The Following User Says Thank You to 02.ACCORD.DUDE For This Useful Post: | Tcoat (02-04-2018) |
02-10-2018, 01:35 AM | #39 |
Drives: 2013 Scion FRS
Something a bit funny happens when I've just started my car. I pull away, and as I accelerate the car feels to lack power, not that I'm flooring it or anything. Just the first time I accelerate, then after that it's fine.
02-10-2018, 01:45 AM | #40 | |
Stop sniffing petrol!
02-10-2018, 02:02 AM | #41 | |
Just stop doing this ....... humfrz |
Similar Threads | ||||
Weird hot start issue | mike the snake | Software Tuning | 21 | 01-18-2021 07:03 PM |
Car won't start! Making weird sounds. | B_Rad | Issues | Warranty | Recalls / TSB | 35 | 01-25-2017 05:33 PM |
Cold Start Help | Kayysonie | Software Tuning | 39 | 03-31-2016 11:35 PM |
Cold start | JG | Engine, Exhaust, Transmission | 8 | 08-29-2015 02:55 AM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
