Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-16-2014, 07:50 PM | #1 |
Drives: 2014 SWP BRZ Limited 6SP
A little blue smoke on startup
Long story short , a friend and I did some hooning last night (fully warmed up) for about 3-4 minutes and then continued home. Parked the car for the night.
This morning it was in the 20s and it cranked a little slow and gave a little puff of blueish exhaust. Ran fine on my errand, then when I started it up to come back from home depot it idled a little low (600 rpm) and I was getting a slight intermittent rattle/knock. Turned the car off, started it up again and the idle was fine with no similar noises. I drove carefully home without incident. Haven't started her up since but I will before I commute tomorrow. Am I being paranoid here? I know our engines are far from quiet. Oil was changed by Subaru at 11,500 miles two weeks ago. 2014 Limited / 11,900 miles / stock but for a drop in and cat back & motul diff & tranny fluid.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now. |
11-16-2014, 07:54 PM | #2 |
in orbe terrum non visi
Drives: violent
Possibly damaged valve seals. Knock and low idle could be from momentarily fouled spark plugs on start up. How badly did you over rev it while hooning?
11-16-2014, 07:57 PM | #3 |
Bounced off the rev limiter a couple times on one drift/donut.
I'm in the car now and it's idleing fine after a cold start. About 800 rpm. Maybe I'm being a bit nuts.
11-16-2014, 08:02 PM | #4 |
A Demon
Drives: Raven GT86
Are you 100 on it being blue smoke?
Because that's never a good sign Sent from my iPhone using Tapatalk |
11-16-2014, 08:05 PM | #6 |
No, I'm not. I noticed the 'puff' right after I cranked it when it was floating away from the car to my left. Grey-ish I suppose, but darker than normal when it's 25 degrees out.
11-16-2014, 08:10 PM | #7 |
Oil is good, right in the middle of high and low.
11-16-2014, 08:19 PM | #8 |
A Demon
Drives: Raven GT86
11-16-2014, 08:26 PM | #9 |
Agreed on the oil level. I don't plan on taking any chances so a check up seems like a safe plan.
11-16-2014, 08:32 PM | #10 |
Drives: 2013 raven frs
could it possibly be from oil blow by? i know alot of people on here posting how if you're driving at high revs you should get a catch can. just a thought
11-16-2014, 09:05 PM | #11 |
Drives: Slow
Most likely thing happening is its just "smoking" more because it's getting colder outside. That's probably why your car took a little longer to crank over as well
11-16-2014, 09:07 PM | #12 |
Right, and it was a slow crank, not a long one, if that makes sense. Like a slightly low charge on the battery type of crank.
11-16-2014, 09:17 PM | #13 |
Drives: 2013 red FR-S, OFT. 2000 Miata SE
These are horizontal engines. Unlike a V or inline engine where residual oil drains out of the combustion chamber, the oil will pool. In aircraft engines, especially when cold, it is not uncommon for them to puff on startup. I wouldn't worry about the engine."Honing" and drag racing is very hard on an drivetrain, and you are likely to wear out drivetrain parts prematurely.
John
2013 firestorm FR-S OFT, OFH, U-Haul Trailer Hitch
2007 Stormy Blue Mica PRHT GT NC Miata, OFT |
Similar Threads | ||||
Cloud of white smoke on startup | wawro569 | Issues | Warranty | Recalls / TSB | 25 | 01-16-2015 12:55 PM |
Stall on startup? | Mhenderson | Software Tuning | 3 | 06-28-2014 04:27 PM |
Knocking on Startup? | 636 | Issues | Warranty | Recalls / TSB | 17 | 02-03-2014 07:18 AM |
startup behaviour | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 01-30-2014 09:07 PM |
long startup!!! HELP! | juanam0909 | Issues | Warranty | Recalls / TSB | 11 | 05-18-2013 08:17 PM |
