Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
07-31-2013, 10:10 AM | #1 |
Drives: 2013 Firestorm FR-S
0-60 time vs. 0-58 (one shift)
Just curious, the magazine's report the 0-60 for our cars around 6.4-6.5 sec but I know that requires three shifts (2nd tops out ~58mph). Has anyone seen a test that shows what the 0-58mph (one shift only) is?
Given the ECU tunes raise the rev limiter, I would think 60 is achievable in 2nd gear now. I realize the car is not a drag racer but I'd be curious to see if the car is in the high 5s with only one shift to 58mph.
2013 Firestorm FR-S, MTX, build date 1/13.
07-31-2013, 10:23 AM | #2 |
Drives: Gx 460, FRS, Prius
Its also possible with a taller tire. Ill try it out once my wheels get in.
07-31-2013, 10:41 AM | #3 |
Drives: Argento FR-S
Hmmm. Very interesting proposal
This is your first performance car?
07-31-2013, 10:50 AM | #4 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Limit is at 59.2mph. You can use inertia to JUST hit 60 if you clutch at the right time. Doing so, I've had my data logger read 5.9 second 0-60 on a few occasions (this is with a drop in air filter, axleback delete, 14.5 lb wheels and very very sticky 215 tires). Though it's a purely academic exercise as you then have significantly slowed down all further acceleration
07-31-2013, 10:56 AM | #5 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
I clocked a 0-58 of 5.7 this morning (hand timed by a friend in my passenger seat. Only "performance" mods are K&N drop-in and Unichip EMS. ~70degf ambient air temperature.
Not half bad.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
07-31-2013, 11:13 AM | #7 |
what rpm are you launching at? Are you drop launching to achieve those numbers?
07-31-2013, 11:18 AM | #9 |
I'm an automatic (in manual mode) so I'm using that whole fake launch limited thing. Engage it by holding the brake for more than a second or so at >5mph, then once you stop, give it gas. Launches at about 4000rpm.
07-31-2013, 11:20 AM | #10 |
@jsimon7777 it depends on the road surface. I've had it a couple of times, but more often I don't.
07-31-2013, 11:22 AM | #11 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
07-31-2013, 11:24 AM | #12 |
07-31-2013, 11:45 AM | #13 |
Drives: 2013 Whiteout Scion FR-S 6MT
07-31-2013, 11:52 AM | #14 |
Drives: Raven Black
I did a 0-60 in 5.8 with: stock tires, 16.4lb rims, e85 tune, 8000 redline... I can spin second and chirp third anytime I want, unless i have a heavy passenger...
Similar Threads | ||||
HUD shift up and shift down display question | JS86JS | Electronics | Audio | NAV | Infotainment | 6 | 05-17-2013 02:54 AM |
Shift knobs | Minovsky | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 03-01-2013 02:22 AM |
How do you shift? | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 12-30-2012 01:11 PM |
Shift light. | Style | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 07-19-2012 03:19 AM |
Shift Apparel | Lexicon101 | Other Vehicles & General Automotive Discussions | 2 | 05-02-2010 12:44 AM |
