06-02-2016, 11:06 PM | #4201 | |
Drives: 2013 FRS
Give the FR-S some time and get the TRD bars. Maybe run the Strano on the front with the TRD rear or go even stiffer on one end. Anything to speed up the weight transfer on the car will probably work well with your kart driving habits. Dan sure was fast in that RX-8 and there was something about the tour courses that threw a lot of people off. It made me realize I still have a lot to learn about certain elements on National type courses. I am looking forward to your videos to see what you were doing with your car. See you next time! |
06-03-2016, 11:28 AM | #4202 |
C-Street AutoX
The guy at spring nationals in the RX-8 can wheel, no doubt about that. On the right course, the RX-8 is still a force...although everyone has ditched these cars because they're kind of shitty/impractical/weird.
As mentioned, I got my 16's back on the car, with a discounted set of 225/50/16 RE71R's. The event went well, with some very competitive C-street competition, I was able to take the win on the new tires, by a very slight margin. The car felt great, very responsive, balanced, easy to drive. New tires didn't seem to have the same grip as my 'worn-in' 225-47-17's, but that was to be expected. I'm anxiously awaiting to get more runs on these tires to see their true potential. I'll be another local event this Sunday to see how it goes. My last set of Bridgestones was much better on the second heat cycle, but really not up to full speed until well after 40-60 runs... [ame="https://www.youtube.com/watch?v=kCjO3lzNbls"]Sean Grogan May 29th 2016 - YouTube[/ame] (this finish resulted in a few 'incidents' into the grass, when the timing lights were actually placed 50 feet down the long road at the end) Results: http://www.nworscca.com/attachments/...e3_results.htm (10th on index out of like 100~) 16's On the drive home from the event I ended up in downtown Toledo looking for a bar, and was reminded how screwed up my front suspension is, making all kinds of clunking in the front end over low speed pot holes, substantial bumps. I just couldn't take it any more, so removed the 22mm perrin bar and tried out my TRD 21mm bar, hoping the sway bar bushings were the root of my problem. 100% problem fixed. It's amazing how much the slightest of front sway bar free-play can result in the most horrendous and obnoxious sounds from the front end. The bushings 'looked' okay, but after 65,000 miles, with never being re-lubricated, they were toast. They were really toast about 30k miles ago. Advice, if you have poly front sway bushings (and everyone in this thread probably does) don't be lazy like me and let them go un-lubricated. Grease them every 20-30k miles at least. Turn in response seems improved in the round-abouts with the 21mm front bar, and balance seems much better. Hopefully I'm not giving up too much in the slaloms. We'll see how Sunday goes.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
The Following User Says Thank You to SeanRTR For This Useful Post: | Lumbajackmeh (06-16-2016) |
06-03-2016, 01:36 PM | #4203 | ||
Drives: Yes
06-03-2016, 02:28 PM | #4204 | |
C-Street AutoX
I don't really count, but I assume 60-80 runs on my 225 45 17's....I've not yet needed to flip tires on this car for any set of tires I've gone through yet. Very minimal sidewall wear if you rotate tires front to rear often enough, and they always wear flat across the tread for me. The 22mm Perrin is adjustable, and I ran mine on soft.
06-03-2016, 04:50 PM | #4205 |
Custom User Title
After reading someone else's post about what pressures they run on their Bridgestones I'm curious now what are you guys running? Someone said they tried running higher at 35/32 and it worked well for them but I've found that 29/27 gives me the best results. Am I way off from what everyone else is doing? A bit hesitant to test it right now since I don't have any non-comptition runs in the next three events.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
06-04-2016, 03:28 PM | #4206 |
Drives: 2015 FR-S
Here are my videos from Spring Nationals. Like I said, I had low air pressures on day 1 and it felt like crap, raised them up for day 2 and felt much better.
06-14-2016, 11:39 AM | #4207 |
Drives: FRS?
What's everyone's thoughts on 2017 changes in regards to c street? This includes a tad more hp/torque, bbk, gearing changes, and damper (and spring?) changes.
Sent from my SM-N920V using Tapatalk |
06-14-2016, 12:21 PM | #4208 | |
Drives: '13 FRS - STX
A pyrometer has been well worth the money to take the guesswork out of tire pressures. |
06-14-2016, 01:11 PM | #4209 | |
Drives: Raven 6 speed Manual FRS
Not worried about 5 hp/tq peak, more interested to see a dyno to see if they worked on that torque dip. The bbk is just extra weight with no real benefit for autocross imo. Gearing is going to be... interesting... Not sure how I feel about it. We have options to tweak with wheel diameter and tire height, so it might not matter much Damper changes.. Who cares Spring changes... good for BRZ, irrelevant for FRS unless they move the non-TRD to DS. More worried about how the CS/DS thing shakes out. If given the option I'll take off the TRD parts and go to DS... I think the ND is an overdog, like my chances against the WRX better
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel. |
06-14-2016, 01:57 PM | #4210 | |
Drives: 2015 FR-S
06-15-2016, 02:59 AM | #4211 | |
Custom User Title
The Following User Says Thank You to Locust For This Useful Post: | strat61caster (06-15-2016) |
06-15-2016, 05:06 AM | #4212 |
Drives: 2016 FRS
Reclass and Move FRS
The stock FRS can not compete with the so called PORT installed TRD springs and sway bar cars in autocross. Some claim they were PORT installed but were self installed parts. I have sent in my letter to SEB to change the rules like many have done already. To move NON TRD cars to DS. Send in your request SEB for rule change at https://www.crbscca.com/index.php?page=submitLetter
06-15-2016, 07:06 AM | #4213 | |
SCCA Solo C Street Discussion
The SEB did receive many letters and already responded that the TRD springs and swaybars are legal for Street class. They aren't going to change their mind about that. The best thing you can do is write a letter in support of the move of the non-TRD cars to DS. The parts are legal, there is no question about that as far as the SEB is concerned. The options are to move TRD or non TRD cars to a different class or somehow convince the SEB to re-write the rules to allow the BRZ to equip the TRD parts. It's a raw deal for the BRZ, but we are talking a tenth or two of a second, which by no means puts them out of contention for a win with a good driver.
The Following User Says Thank You to AlanLGuy For This Useful Post: | simpleisbest (06-15-2016) |
06-15-2016, 08:36 AM | #4214 |
Stiggasaurus Rex
Drives: '14 WRB Subaru BRZ 6MT
I think someone mentioned this at Toledo too, I'm really looking forward to see a twin compete in both CS/DS if that happens. It is totally plausible to switch out the strut assemblies and swaybar between CS and DS with a good pit crew.
meh.
Similar Threads | ||||
Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
