05-09-2014, 12:05 AM | #1177 | |
05-09-2014, 01:19 AM | #1178 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
I will say, looking into the numbers a bit more because of this thread, a surprising number of very fast cars make lift - off the top of my head from the stuff I was reading earlier (if I'm remembering right), both the GT-R and the Ferrari 458 make a significant amount of front lift at speed, though both do make rear downforce. On the other hand, surprisingly, the Porsche 991 Carrera S is almost perfectly neutral at speed - no downforce, no lift. It just goes to show that it is very difficult to guess the aerodynamics of a car just by eyeballing it. |
05-09-2014, 01:33 AM | #1179 | |
05-09-2014, 09:37 AM | #1180 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
05-09-2014, 10:30 AM | #1181 | |
Drives: '06 AM V8V Coupe
It's more like most cars just don't have a lot of money spent on the aerodynamics, or certain design criteria mean they have compromised aerodynamics. Most cars aren't streamlined well, and those turbulent areas will often cause lift. In the case of the S2k, the trunk is too short to allow air coming from the roof to reattach, so the entire trunk and rear window sits inside a very low pressure area. Another thing is tires, tires add massive amounts of drag and lift to all cars. Supercars usually have very well thought out aerodynamics on the body, but their massive tires will ruin it a bit. |
05-09-2014, 01:22 PM | #1183 | |
For anyone interested in the only data I've been able to find on this across a wide range of cars, if you either know German or are willing to put up with an autotranslated webpage, the supertests at sport auto (http://www.sportauto.de/supertests-978719.html) include aero data such as Cd and front and rear lift/downforce measured in a wind tunnel. It can be really interesting to look into the data. For example, according to their data, the 911 Turbo S makes more downforce (by quite a bit) than the GT3 - I never would have guessed that from looking at them. |
05-09-2014, 01:50 PM | #1184 |
05-09-2014, 02:13 PM | #1185 |
Drives: small
05-09-2014, 02:18 PM | #1186 |
Drives: small
Cd and likely CdA. The Veyron is not very slippery, it's just a big brute. I believe the P1 is something around .31-.35 somewhere in there for obvious reasons. I love that the 86 can get the same Cd as a Prius and blow it out of the water with a diffuser (around 0.23ish). |
05-09-2014, 02:18 PM | #1187 |
Drives: '23 BRZ
It is unusual for a "normal" car to make downforce up front. Even if the body of a car is totally neutral, producing no lift or drag or moments, there is effective lift at the front and effective downforce at the rear because of the offset between the Cp of the body and the ground plane (pure drag on the body makes a moment that is resolved as additional load on the rears and reduced load on the fronts).
The 240Z produced a TON more front lift than rear. Some guys tested a lot of aero mods on the Z in a wind tunnel a few years back, the best single thing that addressed front end lift on the car was when the hood released during a run! |
The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (05-09-2014) |
05-09-2014, 02:34 PM | #1188 |
05-09-2014, 03:27 PM | #1189 | |
Drives: Attitude
05-10-2014, 04:17 AM | #1190 |
Similar Threads | ||||
FR-S vs S2000 | vang | FR-S / BRZ vs.... | 436 | 09-19-2012 04:52 PM |
E36 M3 vs FR-S vs S2000 (for me) | RearDrive | FR-S / BRZ vs.... | 48 | 07-02-2012 10:46 PM |
S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 02:01 AM |
S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 09:05 PM |
