Old 11-07-2018, 12:47 AM   #1
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
New OEM camber bolt for coilover install?
I'm getting ready to swap out my coilovers for a different brand, and I was just wondering if it was advisable to replace the two bolts that hold the coilover to the hub.
I wasn't sure if the threads on the originals can elongate over time, and was just thinking it might be a good idea to replace them with new OEM bolts since everything will be apart anyway.
For reference, these are the ones I'm referring to:
I have camber adjustment on my top hats, so I don't need actual camber bolts.
Any advice/insight would be appreciated as I'm not a suspension expert.
Originally Posted by humfrz
I'm old and lazy
Old 11-07-2018, 01:03 AM   #2
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Not sure if necessary, but I did. I believe factory instructions note that you should. Relatively inexpensive so I just figured why not.
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 11-07-2018, 01:27 AM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Which part#(s) did you order? It appears that the top is a different size than the bottom.
I'm old and lazy
Old 11-07-2018, 01:47 AM   #4
asdf
asdf's Avatar
Drives: #0517
I can try and check my garage tomorrow to see if i still have the part#
online search found:
SU003-02805 upper bolt
SU003-02818 lower bolt
SU003-02889 nut
R1 3 5
. 2 4 6
Old 11-07-2018, 02:07 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Imho replacement is not needed. After all, how often alignment on car is redone. I doubt for threads to be anywhere close to stripping. Also i'd probably get lobed cambolts instead of at least one of oem bolt pair. Eases alignment adjustment versus simply smaller diameter bolts, which is case if one reuses stock 14mm bolt in 16mm upper hole. Even if you have camberplates, imho in some cases it's simpler to adjust from knuckle side, simply because of location (if car is rised on alignment rig for example and working from below car, also toe adjustment is also near).
BTW, in 2nd pic upper bolt looks like it's cambolt, not OE "crash cambolt" relocated from lower to upper hole.
The Following User Says Thank You to churchx For This Useful Post:
Leonardo (11-07-2018)
Old 11-07-2018, 08:16 AM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
^ 100% Aggree.
top hats are nice, but a PITA to adjust compared to a cam bolt. Im running my lower oem bolt in my coils top hole and a 14mm cam in the lower. My oem bolts threading still look "new".
I LIKE TIRES!
Old 11-07-2018, 11:17 AM   #7
Racecomp Engineering
For the coilovers on my own car, I used 2 of the lower 14mm bolt and maxed out my camber adjustment at the lower mount. My camber plates were left in the OEM position, though I'm only running -2.2 degrees camber at the moment.
I did this to keep a lower SAI and this is what I recommend for most people. Get as much camber as you can from the lower mount, and get any more you need from the camber plates (but make sure the tops are even).
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Leonardo (11-07-2018), wparsons (11-07-2018)
Old 11-07-2018, 11:28 AM   #8
Code Monkey
Drives: Subaru BRZ
I run -3.6 camber in front; with just the camber plates maxed out I was at -3.1 and needed aftermarket cam bolts to get to -3.6.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
strat61caster (11-09-2018)
Old 11-09-2018, 01:55 AM   #9
Clipdat
Proud of BOXER
Clipdat's Avatar
I ended up ordering the OEM hardware from Subaru.
Here are the Subaru part numbers for those interested:
Upper bolt: 901000371
Lower bolt: 901000394
Nuts: 902380008
I'm switching to KW V3 which have a slotted upper hole, so I should be able to get some camber at the knuckle even with the OEM bolts.
Thank you all for the replies.
I'm old and lazy
asdf (11-09-2018)
DIY Camber Bolt Install? Prmspen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-08-2019 12:33 PM
SPC Camber bolt install issue AnotherDude000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-10-2017 05:59 PM
Will OEM camber bolt install affect alignment B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-23-2014 11:30 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Whiteline Camber bolt install TimR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-06-2013 08:33 AM
