07-21-2015, 03:57 PM | #71 |
Drives: 2010 MS3
Not trying to side with anyone...
But my previous car was a Mazdaspeed3, it was modded and as fast as the stock STi and EVO on the freeway. I was getting a better gas mileage on that car over my BRZ. That's how turbocharged cars work.. if you are not on the boost range, you could get a great mileage out of it. And just for daily driving, you don't have to be on boost. Just my 2 cents. |
07-21-2015, 05:22 PM | #72 | |
Drives: many
What is the EPA/DOT doing wrong that their certified numbers don't bear this out? Granted they do a lot wrong in general, but let's keep on topic heh. IME driving a turbo car completely out of boost is akin to trying to stay in electric mode on a Prius. Horrible experience for DD. Maybe our ideas of "out of boost" are different. Well, let's stay focused on the '15 WRX rather than introduce another variable with no comparison like a modded Mazda 3 that's > an Evo. I'm just looking for apples to apples comparisons of the '15WRX being a more fuel efficient car than the 86 supported by evidence and a MechE and/or ChemE explanation if so that's unrelated to all the factors I already mentioned a few posts ago. |
07-21-2015, 05:26 PM | #73 |
Drives: 2010 MS3
Not sure if it's my English or yours, but I don't get what you are trying to say. LOL
07-21-2015, 11:37 PM | #74 | |
Drives: many
1-I have not seen any actual evidence that the '15WRX gets better mileage than the BRZ under the same exact conditions. All the evidence I can see and find says the opposite. 2-I have not seen anyone explain why the '15 WRX would get better mpg (if true) other than you saying, "that's how turbocharged cars work." Forgive me if I don't find that a scientifically valid explanation. How's my English now? Unfortunately I can't read this for you so that's that. So here's some questions for you since you know 'how turbocharged cars work'. 1-Why didn't Toyota put turbos on the Prius and their hybrid lineup if that's just how they work (adding mpg for free)? Don't you think Toyota would love to market an extra 10-20% improvement in mpg over the base model if they could just slap a turbo on the same sized engine? 2-Why doesn't Subaru protest the EPA/DOT certifications that unfairly diminish the fuel efficiency of the '15 WRX (like some claim here)? Seems like Subaru (and everyone else) would love to advertise higher mileage figures for the sake of marketing! 3-Under the same normal conditions (sea level environment, throttle application, tribology, etc.), a 2.0L Boxer NA should pretty much universally show better BSFC (brake specific fuel consumption) than the same 2.0L Boxer when turbo'd when under the same conditions. Now if you change fuel mapping to better tailor the turbo'd motor to both the gear ratios and driving habits of the driver (and not do the same for the NA motor), then maybe things get more interesting. This might be the case with the '15 WRX where the BRZ was tuned for window sticker EPA tests. However, none of the examples or evidence presented so far shows that's what's going on yet. See: http://www.bobistheoilguy.com/forums...&Number=410549 "The forced induction S.I. engines almost invariably show a poorer Brake Specific Fuel Consumption than their naturally aspirated counterparts, which, by definition is thermal efficiency. And in the real world, which is predominantly throttled driving, the lower compression ratio gives you a lower expansion ration, and poorer efficiency under that regime also. Pull out some BSFC maps for speed and load, and see for youself (Internal Combustion Engine Fundamentals by J.B. Heywood has such maps)." So either the 'magic' mpg numbers are due to magic in the motor, superior gear ratios, or driver behavior. In the first two cases, the DOT numbers should bear out an advantage for the '15WRX. They do not. Extra weight and AWD are not helping with mpg either, unless those BRZ Primacies were slipping all the time resulting in wasted energy... |
07-22-2015, 01:45 PM | #76 |
Drives: many
07-22-2015, 02:00 PM | #77 |
Can we argue about something else! Like whether or not the 2017 FRS will be a convertible or turbo, or maybe even both?
07-22-2015, 02:31 PM | #78 | |
1st86 Driver!
Just don't get your fingers or head in the way in the process. The only other change will be optional fuzzy dice.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 07-22-2015 at 03:36 PM. Reason: Grammar...apparently my new nemesis |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | GT86_PRAGUE (08-07-2015), raven1231 (07-22-2015) |
07-22-2015, 03:12 PM | #80 |
Drives: '24 GR86
Given the high compression, small displacement, and lower hp output of the BRZ, I would hope it can get better gas mileage than a WRX.
I had my FRS for a little over 2 years. Daily driven, mostly city miles, though about 30% were highway miles across country. Also had 6 or 7 days out at the track drifting (runs last all of 60 seconds). Stock for the first 12k miles. Stage 2 (headers, exhaust, tune) for the last 7k miles. My average at the time of selling it was just over 26MPG. This abraxis guy seems a little defensive about the FRS/BRZ. Lol wait a sec, this ft86club, of course he is.
07-22-2015, 03:26 PM | #81 |
Need scientific evidence! Where's my experimental design!!! Raar! Prius turbo not why is mileage be that is frs?
07-22-2015, 04:55 PM | #83 | |
The MPG has nothing to do with the fact that the WRX is turbo. 10.6:1 is high enough that it can extract a good amount of torque from a given combustion event, but low enough that you don't have to pull timing to prevent detonation at low load, low RPM, so that you can get more power at high RPM. Even with the extra weight, and extra drivetrain losses of having AWD, the WRX still gets better cruising MPG. If i'm on the throttle and driving hard, MPG drops instantly. |
07-22-2015, 08:25 PM | #84 | |
Drives: '24 GR86
LOL I'm at about 800 miles on my '16 STI and I'm averaging 21mpg. 75% highway miles. Driving normally; don't baby it, but don't beat the hell out of it. Funny seeing economy like that from a 4cyl engine. Gotta love the good ol' EJ motor.
Similar Threads | ||||
Someone "decorated" my driver-side door! | AAghassi | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 35 | 07-15-2014 06:29 PM |
Car Shopping - "Fun Daily Driver" | Toyota86Fan | Other Vehicles & General Automotive Discussions | 51 | 10-21-2012 03:02 PM |
BRZ Commercial "Cool Driver" | Dusky | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 10-15-2012 02:10 PM |
Interest in a Racecomp BRZ/FRS "Performance Pack" to match Mustang V6??? | Racecomp Engineering | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 05-10-2012 12:10 AM |
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 03:58 AM |
