04-05-2013, 01:05 PM | #295 | |
04-05-2013, 01:12 PM | #296 | |
Drives: 2013 Subaru BR-Z Limited
04-05-2013, 01:13 PM | #297 |
04-05-2013, 01:40 PM | #298 | |
Drives: 2013 Black FR-S
Superchargers will consume more fuel than a turbo in light throttle conditions the same way a AC consumes more fuel. It is connected to the crank and must be spun. It consumes power, thus fuel. The difference in mpg may be as small as 2 mpg. Just depends on the system. 2 mpg to Toyota or Subaru for example is HUGE for their marketing strategy. The majority of their customers do care about mpg especially in this day and age. It is a selling point. They can also inch out a few more ponies out of a turbo at the same boost level vs. a s/c. Hence the use of turbos and not superchargers. Its all sales and marketing. Last edited by sw20kosh; 04-05-2013 at 01:53 PM. |
04-05-2013, 01:58 PM | #299 | |
Drives: 86 (FR-S)
The Following User Says Thank You to Jeff86 For This Useful Post: | Huehuecoyotl (04-05-2013) |
04-05-2013, 02:14 PM | #300 | |
"Superchargers do affect gas mileage slightly. The bypass is a good step, but it doesn't completely compensate for the fact that you're spinning a mechanism around. We usually see about a 1-2 mpg drop in fuel efficiency with supercharged Miatas and a 1-2 mpg gain with the turbos." http://grassrootsmotorsports.com/for...s/36262/page1/ "The parasitic drag of turning a supercharger can exceed 25 hp at high rpm and probably is no worse than an AC compressor [3-4 HP] at idle or cruise in top gear. Each HP consumes ~~ 1/2 pound of extra gasoline per hour. An extra 1/3rd of a gallon per hour added to the base 2.5 gallons per hour during 60 mph cruise. Miles per gallon is harder to calculate than pounds of gasoline per hour since the ecu deals in mass flow per time unit. Air flow is calculated in grams per second as is fuel flow. Having a supercharger drag on the engine will usually decrease normal MPG by 8 -13% just like running AC on a HOT DAY. Why many oem superchargers have a clutch to disengage supercharger until needed. Radial superchargers use less HP than Axial versions......function of impellar weight and gear multiplication and oil frictional losses. Without a clutch the oem would be forced to publish a 2 MPG hit in highway MPG on EPA test so the fines [gas guzzler] must be weighted against cost of clutch and warranty on clutch." http://forums.nicoclub.com/mpg-with-...r-t315640.html |
The Following User Says Thank You to sw20kosh For This Useful Post: | jonnyozero3 (04-06-2013) |
04-05-2013, 02:19 PM | #301 |
I Love custom Turbo kits
Drives: Limited BRZ
Good God... Can we stop the pointless discussion and get back on topic? Both SC and TC affect mileage when you get on boost. If one uses more or less gas.. who cares???
The decision to shell out 5K+ dollars on a kit is not based on MPG, you can assume MPG will take a dump as soon as you FI and if anything be surprised that it is not that bad. Never expect it to be good and move on.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post: |
04-05-2013, 02:24 PM | #302 |
Drives: WRB BRZ
@Sportsguy83 This thread is and others similiar are all full of off topic banter, can we get some on topic moderation? Im sick of seeing menial and trivial banter and bickering over shit that has nothing to do with the thread. Holy Raptor Jeezus its annoying! Feel free to delete this post after reading it also. Its the same 8-10 people doing this crap all over this forum.
People if you have an off topic post CREATE A NEW THREAD! OR USE PM's thats what they are for. /rant
04-05-2013, 02:24 PM | #303 | |
04-05-2013, 02:27 PM | #304 | |
Drives: Limited BRZ
Unfortunately, I am only regional moderator, so I have no say or participation of what happens in Technical Forums. I just try to help a little bit from the outside.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | norsamerican (04-05-2013) |
04-05-2013, 02:31 PM | #305 |
Drives: Vortech Supercharged M6 FR-S UM
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post: | HotLeopardMama (08-27-2013), Sportsguy83 (04-05-2013) |
04-05-2013, 02:35 PM | #306 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following 2 Users Say Thank You to King Tut For This Useful Post: | civicdrivr (04-06-2013), norsamerican (04-05-2013) |
04-05-2013, 02:38 PM | #307 |
04-05-2013, 02:41 PM | #308 | |
Automotive Connoisseur
Drives: too many cars
LSx Powered 86/ASE Master Certified Automotive Technician
The Following User Says Thank You to AZFA20 For This Useful Post: | Huehuecoyotl (04-05-2013) |
Tags |
ft86, perrin, phastek, supercharger, vortech |
Similar Threads | ||||
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! | Visconti | Forced Induction | 67 | 04-03-2013 03:56 PM |
Vortech Supercharger Kits @Pure Automotive Performance | Pure Automotive | Forced Induction | 25 | 01-15-2013 11:48 PM |
