Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 08-21-2017, 12:21 AM   #267
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
I fitted formula friction pads with power brake rotors.
Made a huge difference from stocks pads.
Then, swapped the stock calipers for WRX 4 pots.
That made a huge difference on top the first difference.
GeeTee86 is offline   Reply With Quote
The Following User Says Thank You to GeeTee86 For This Useful Post:
86 South Africa (08-21-2017)
Old 08-21-2017, 02:53 PM   #268
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Thanks. So you have the same sized rotors, just better ones with different pads?
I like driving!
86 South Africa is offline   Reply With Quote
Old 08-22-2017, 12:14 AM   #269
GeeTee86
86 Nut
GeeTee86's Avatar
PB rotors are 294 x 24mm, same as stock.
But it is better quality, heat treated and slotted
86 South Africa (08-22-2017)
Old 08-22-2017, 12:43 AM   #270
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Same as GeeTee86 - WRX calipers front & rear, PB discs front and braided lines all round running Motul RBF660 fluid.
Just bear in mind, std spec got tiny rotors so upgrading to 294mm would make an even bigger difference.
If you're set on getting a big brake kit, have a look here:
http://www.ctsvbrakeswap.com/subaru-...er-bracket-kit
A friend's done it on his Subaru with 330mm STi discs from PB. Just make sure they'd clear your wheels. He's running 18".
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
The Following User Says Thank You to sav For This Useful Post:
Old 08-22-2017, 02:58 PM   #271
86 South Africa
I have stock 17" rims so if the PB rotors, pads and better fluid makes a much bigger difference then I'd rather do that than spend big dollar on a BBK.
I like driving!
Old 10-11-2017, 02:02 PM   #272
86 South Africa
Finally got around to ordering a set of power brake rotors with endless pads and motul 660 fluid - should all arrive in a few days.
Excited to see the difference
I like driving!
The Following 2 Users Say Thank You to 86 South Africa For This Useful Post:
Fish Eagle (10-11-2017), FT_86_SM_GP (10-13-2017)
Old 01-30-2018, 08:14 AM   #273
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
If you use Bendix Ultimate DB1803U rear pads (for standard spec) from Powerbrake, then right now their pricing is very good.
I don't know if this is due to exchange rate fluctuations or a mistake.
In April 2017 and again in August 2017, I paid 1793.20 incl, and today they're at R1300.74 incl.
Fish Eagle is offline   Reply With Quote
The Following User Says Thank You to Fish Eagle For This Useful Post:
86 South Africa (02-06-2018)
Old 01-31-2018, 03:28 AM   #274
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Just received new pads from Powerbrake and the front pads are the real deal again - genuine BLUE Endless pads from Japan.
Some of you will know that I had a big fight with them last year about the quality of their locally made RED clones.
Thrilled that they've listened to their customers
Also pleased to see that the Bendix rear pads I received are the ones manufactured in Australia which are better than the others.
The Following 2 Users Say Thank You to Fish Eagle For This Useful Post:
86 South Africa (02-06-2018), Gregore (02-10-2018)
Old 02-06-2018, 12:06 AM   #275
86 South Africa
Glad to hear that!
Must say that so far I’ve noticed a huge difference in mine!
I like driving!
Old 06-12-2018, 11:50 AM   #276
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Drives: 2014 Crystal Black Silica GT86
Hi
i have EBC rotors on my car and it has a strange noise when driving about 50-60 Kph,and when i brake the sound stops,does anyone know what the problem?
this is the sound
and this is the rotor
http://www.ft86club.com/forums/attac...1&d=1352695118
Follow Me on Instagram: @Stock_GT86
Admin & Founder of @GT86PersianClub
Nur Spec Body-Rays Gramlights 57Xtreme-Rays Dura Nut L42 Straight type Lug nuts-EBC Brake Rotors-K&N Filters-D2 Racing RS Coilvers-GReddy EVOlution GT Catback-HKS Dual Resonated Front Pipe-JDL Catted UEL Header-Valenti FT86SF tail light & 4th Brake light
Mehrshad is offline   Reply With Quote
Old 06-16-2018, 03:58 AM   #277
86 South Africa
Originally Posted by Mehrshad View Post
Hi
this is the sound
Very hard to hear, but definitely something rubbing/scratching/touching.
All I’d say is this.... when it comes to brakes get someone with REAL knowledge to help sort it out. It really is 1 part of the car you don’t want to fail.
Also maybe take the wheels off and check for obvious signs of something wrong in the meantime?
I like driving!
Old 06-19-2018, 04:07 AM   #278
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Decided that today's the right time to fit the new front discs I bought a few months ago.
I've been watching this crack slowly growing, and now it's time to replace.
Old 06-20-2018, 03:07 PM   #279
86 South Africa
Caused by excess heat on the track?
I like driving!
Old 06-20-2018, 04:01 PM   #280
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Yep, surface cracking is normal.
Deeper cracks like this one are a problem.
86 South Africa (06-21-2018)
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 04:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 12:33 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
