Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-11-2018, 01:51 PM | #1 |
Coolant temps with Jackson radiator?
I just got out for the first test run after installing the Jackson Racing combo radiator / oil cooler and an Innovate oil pressure gauge on a stock 2013 BRZ (no tune, no bolt-ons). Do these numbers look reasonable? Coolant temps are from Kiwi ODB-II, pressure is from innovate gauge. It was 94 deg out during the test.
idle - hot: 190 deg, 10-12 psi 2500-3500 RPM @ ~40 mph in town: 192 deg, 50-ish psi 6000 rpm @70 mph for 3 miles: 208 deg, 100-ish psi 75 mph in 6th, 198 deg 80-ish psi oil pressures are rough guesses from memory, so they have fairly wide error bars on them. Even so, does that seem in the ball park? thanks! |
07-11-2018, 03:26 PM | #2 |
That would be well within normal operating temperature yes.
Oil pressure will vary with rpm and temp. |
The Following User Says Thank You to CSG Mike For This Useful Post: | dstrout (07-11-2018) |
Similar Threads | ||||
Adjusting radiator fan temps | ML | Software Tuning | 44 | 04-16-2020 08:44 PM |
Coolant Temps Running High | Dezoris | Tracking / Autocross / HPDE / Drifting | 43 | 09-29-2016 11:58 AM |
Coolant Temps WAY TOO HIGH | itsjustdavep | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 45 | 08-25-2016 01:41 PM |
Dots in coolant(open radiator cap) | Tank42 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 01-26-2016 10:52 PM |
Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
