Old 04-24-2019, 02:57 AM   #1
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
HKS 2.1 stroker kit & camshafts
I would like your opinion on the improvements of the HKS 2.1 stroker kit and the relevant camshaft:
Notice the 20hp improvement in the middle and high rev ranges. In this graph there aren't any exhaust changes.
How it would compare with a stock engine and a good catless header with a tune? No E85 fuel comparisons please.
Old 04-24-2019, 10:02 AM   #2
86TOYO2k17
Drives: 2017 toyota 86
I dont think the cam used on this dyno is the one that is compatible with stock pistons. I believe the one that is, had very minimal gains mostly in the top end because lift cant be increased with out recessed piston heads for valve clearance, only a little duration and it wasn't worth it. If going all out NA looking for some high peak power and money isn't an issue i am sure it would add a little. I could see it stacking well on top of E85 or at least WMI for that top end. maybe some 210whp NAs could be possible on generous dynos.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
nikitopo (04-24-2019)
Old 04-24-2019, 10:15 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes I agree. I believe most of the gains are from the stroker kit and the camshaft was used to enhance a bit the top end marked with black circle. The engine displacement increase from the stroker is minimal, but the torque increase looks to be substantial.
I checked also some results from a couple good catless headers. The difference is not that large, so I guess the effort and the cost to install the stroker kit is a serious disadvantage. I would say it makes more sense only if someone combines it with FI. There are other stroker kits too, but these are even more complex with a mandatory cylinder bore honing process.
Old 04-24-2019, 10:44 AM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Look at the chart again. That's not horsepower.
Old 04-24-2019, 10:49 AM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I converted kw to hp
Old 04-24-2019, 02:13 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
I will add here that one of the few cars here in the UK that had a blown engine was running a HKS stroker kit that let go shortly after install. HKS admitted manufacturing defect.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-28-2019, 05:49 PM   #7
Hawk77FT
Drives: GTS 86
Very reassuring! Pheww!
Hawk77FT is offline   Reply With Quote
Old 03-24-2020, 06:51 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Any update on this? Did anyone install the HKS 2.1 stroker & camshaft kit lately?
Just ordered new Camshafts Fonzi Forced Induction 21 02-11-2018 02:31 PM
Piper Camshafts brn12345 Engine, Exhaust, Transmission 120 10-02-2017 10:28 AM
Camshafts and Boost! Dream20b Forced Induction 23 01-16-2016 02:49 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 07:35 PM
