BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
View Poll Results: What color of Series.Blue did you opt for? | |||
Blue | 176 | 55.87% | |
White | 139 | 44.13% | |
Voters: 315. You may not vote on this poll |
08-16-2014, 09:45 PM | #253 |
Drives: 2015 Subaru Series.Blue (WRB)
I got a chip on the way to install my clear bra. What are the odds?
I got the custom full hood installed now. Jeremy did an awesome job. |
08-16-2014, 10:01 PM | #254 |
Drives: '15 BRZ Series.Blue
Why was the full hood custom? Xpel has a pattern that covers the entire front end already.
08-16-2014, 11:27 PM | #255 |
If the edges need to be tucked they may use the template for the general shape but still do the rest custom
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
08-16-2014, 11:30 PM | #256 |
The Xpel pattern covers edges. All Xpel patterns cover every edge that can be covered without risk of lifting, which is most edges. I've never seen a full hood pattern of theirs that didn't cover all four edges. I hope you weren't charged extra because I know their full hood FR-S/BRZ pattern covers all four edges.
08-17-2014, 12:16 AM | #257 | |
@dsomegax.cars
08-17-2014, 12:33 AM | #258 | |
I would have to check but I thought the hood was custom. Spent about $1250 for the entire thing including door trims and a trunk liner over the rear bumper. (All front lights covered too). |
08-17-2014, 12:51 AM | #259 | |
The Fail Boat
Drives: CWP S.B.
You really can't see what's close to your tail when the car isn't moving. (when the car is moving, all 3 rear view mirror can cover up to like 200 degree if set up right) |
08-17-2014, 02:36 AM | #260 | |
08-17-2014, 10:04 PM | #261 |
Ahhhh, that explains it. The Suntek is definitely less expensive but I will disagree about the rest. I replaced Suntek on two cars because of cloudiness and the film didn't heal like they said it would. My STI got Xpel Stealth and my GTI got Ultimate. IMO both Xpel products were better than Suntek but at the end of the day, as long as you're happy with it that's all that matters. ANY film is better than nothing.
08-18-2014, 02:05 AM | #262 |
Installed the rear view camera today. In hindsight, I should have installed the camera further back away from the edge.
Thanks to all the post out there that did most of the work. I basically followed this post http://www.ft86club.com/forums/showthread.php?t=32452. Thank goodness for fish tape, nylon string and straws+chop sticks because that helped speed the process when feeding the wires through the rubber tube, the side panel and up to the HU. I did use the power and ground from the HU by splicing into pin 7 and 15 on the 16-pin camera socket. Pin-out: Pin Label Description 6 PKB Parking brake input 7 CA+ +6V supply (output to camera) 8 V+ Camera Video Signal Input (+) 15 CGND HU grounds this internally 16 V– Camera Video ground/shield Also it helps to take the panel above the glove compartment off to get to the panel for the HU. Last edited by BRZ.SeriesBlue28; 08-18-2014 at 02:36 AM. |
The Following User Says Thank You to BRZ.SeriesBlue28 For This Useful Post: | fungizmos (08-30-2014) |
08-18-2014, 12:56 PM | #263 | |
I would definitely recommend using this camera kit because you don't have to cut any of the factory wires or look for a ground. That part was easy. |
08-18-2014, 03:33 PM | #264 |
08-21-2014, 02:04 AM | #265 |
Anyone figure out how to tell what number their car was made out of 500? Just curious.
08-21-2014, 02:10 AM | #266 |
Shoegazer
Drives: 2015 WRB BRZ Series.Blue
Tags |
2015, brz, heuburger, series.blue |
Similar Threads | ||||
Subaru USA's New 2015 BRZ Series Blue with STI Parts has a Placebo Effect…. | vh_supra26 | BRZ First-Gen (2012+) -- General Topics | 393 | 07-30-2014 12:27 AM |
10 series vs. 2015 fr-s | initialrt | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 06-28-2014 09:40 PM |
2015 FR-S or discounted 2013 10 Series? | bostnwhalr | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 06-12-2014 09:19 PM |
(10-SERIES) Any way to disable blue LED on emblems? | R4PT0R-X | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-27-2014 09:46 PM |
