Old 04-14-2019, 04:00 AM   #1191
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by tomm.brz View Post
you can install it on every laptop/PC you want
Officially that is untrue, read the licence agreement. IIRC it's 3 or 4 devices
Unofficially.... I bet they don't check
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-14-2019, 05:44 AM   #1192
tomm.brz
Drives: brz 2017 hksv2
Offficially your car can't have a Sprintex installed if it's a road car and you can't drive fast anywhere :P
I have my ProEcu installed in at least 7 different locations and everything is good since 2 years
Old 05-15-2019, 12:00 AM   #1193
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have released new NA Stage 1,2 and ACE tunes for the BRZ/86/FRS.
Version 12.00 for Stage 1
Version 13.00 for Stage 2
Version 14.00 for Stage 2 + ACE header.
Improvements include
- New Cam Table Profiles
- New Fuel Table Adjustments,
- New Timing Advance Tables
- New DI/PI control mechanism
We also have added on the EcuTeK ECUConnect
- Custom MAF Trim %
- Custom WOT Timing %
- Custom Traction Control % (NA Tunes)
- Custom Boost Pressure Set Point (Flash & Go Tunes)
- Optional Pops % Bangs Switch
- Optional Crackle Slider
RaceROM Maps Have Also Changes
- Custom Race Throttle Spec (tested for immediate response)
- Improved Autoblip (for those that like that option)
- New Valet features
Regards,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
craigpitts7 (11-10-2019)
Old 05-19-2019, 08:15 PM   #1194
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Can we expect emails for updating ACE tunes, or should we pay for the service first?
thatfilipinoguy is offline   Reply With Quote
Old 05-26-2019, 09:32 AM   #1195
rx3
Since Zach left I can't get a response from William.
Apparently my car (AVO Turbokit) is producing too much boost (after adding a larger IC and a cat-back - don't necessarily see the relation but this is what has changed since Zach tuned it) but instead of opening the WG, it closes the throttle apruptly.
rx3 is offline   Reply With Quote
Old 05-26-2019, 11:19 AM   #1196
rx3
I should add that when I initally tested it after adding intercooler and cat-back, it was ok. (Well apart from some ignition correction).
But after a while it occasionally started to bog abruptly (due to closing of the throttle), which it meanwhile does all the time at WOT.
For whatever reason, the WG Duty goes to 100% immediately and then the throttle closes (screen shots attached). Maybe it is also some sort of a defective contact? I don't think it is a mechanical issue otherwise it would have done it all the time - besides, the software appears to be giving a false command anyway.
Any ideas?
Old 11-16-2019, 12:03 PM   #1197
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Is there a way to pull data from Ecutek regarding what was going on when the engine blew?
B T is offline   Reply With Quote
Old 11-17-2019, 04:02 PM   #1198
tomm.brz
No, it doesnt collect data if you do not log it
Old 11-17-2019, 04:27 PM   #1199
steve99
Drives: FT86
Any ideas?
Ecutek racerom 10 and above, the built in overboost system closes the throttle to 20% whwn overboost detected. It monitors manifold pressure and if limit exceeded tgrottle is closed .
Sounds like your getting overboost for some reason, strange you say wg duty goes to 100% this seems to indicate its trting to male moore boost.
Old 11-20-2019, 11:12 PM   #1200
HaXx
Drives: jrsc_brz
to fully utilize pops and bangs tune, can i have catless header and catback, but still have oe front pipe? currently im on c30 jrsc ecutek and invidia n1. im looking to get catless header, hopefully i can leave the oe front pipe in.
HaXx is offline   Reply With Quote
Old 01-25-2020, 06:33 PM   #1201
DeliciousTuning
Hi All,
We wanted to let everyone know with the changes to the business last year, I personally went back through all our 86/BRZ tunes and started from a blank canvas. I felt the way the tunes were being handled from initial delivery to final revisions for all our customers, new and old, was not to the level I expected. At the end of the day I am the owner and the lead calibrator of Delicious Tuning, so I can only blame myself on this.
So about a year ago, I made the choice to rebuild the process, work with some highly technical engineers in airflow design, and network/server automation so that we can build a better tune (better airflow in and out of the engine) and have a faster turnaround time (hopefully finish that up this year). It seems that the changes we introduced so far have worked well, as we became the #1 EcuTeK Dealer in the world. Thank all our customers for their support, it was greatly appreciated.
All the NA tunes we offer are brand new as of March 2019, they included extensive testing on quite a few header designs, including specific tunes for the following applications.
2013-1016 Intake Intake Manifold
- Stock 2013-2016 header,
- Stock 2017+ headers,
- ACE 350,
- JDL 4-2-1
- Tomei Unequal
2017+ Red Intake Intake Manifold (manual cars)
- ACE 350,
- JDL 4-2-1
- Tomei Unequal
The major difference between the old/new tunes is in how the ECU adapts to sensor inputs, in what scenarios it adapts, how it adapts in those various scenarios and how quickly it will make changes. These adaptation help smooth out the power delivery, offer a wider / more controlled throttle input, and adjust to the environment conditions more so than before to ensure as much consistency.
Of course we are now using EcuTeK BlueTooth Connect and taking advantage of this through some cool features
EcuTeK BlueTooth Connect Delicious Tuning Customization
- Custom Traction Control Level Slider
- Custom Pops & Bangs Level Slider
- Custom Crackle On/Off Switch
We also have been developing tunes for the following:
- Greddy ITB's - Manifold Air Pressure Sensor Based
- Greddy ITB's - Alpha - N Based (throttle vs RPM)
- Full Blown Motorsports Manifold
In the works are some custom setups we are hoping to release this year, based on the results of of the customers we are working with. The plans are to increase the NA power above what the current limits with the current level of parts in the market.
There is also more in the works this year with further safety features and cool tricks we are implementing with the ECU. So be on the look out.
Safety Features In the Works
- Triple CEL Blink: to notify you when the VVT is not enabled. This is to inform you to drive lightly, as the cams are not active. (complete)
- More custom check engine lights coming for additional safety measures as the year progresses
Cheers,
William Knose
Pushing The Boundaries Since 1999
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
BA9092 (01-25-2020), craigpitts7 (02-21-2020), HaXx (01-25-2020)
Old 03-02-2020, 11:06 AM   #1202
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
Originally Posted by DeliciousTuning View Post
Hi All,
- ACE 350,
- JDL 4-2-1
- Tomei Unequal
- ACE 350,
- JDL 4-2-1
- Tomei Unequal
Cheers,
William Knose
on your site , you claimed that your flex tune are tuned to work with your flex fuel kit
Does that mean it doesn't work with any other tuens?
And also what's the different between crackle and pop&bangs?
ojuniour is offline   Reply With Quote
Old 03-08-2020, 06:37 PM   #1203
DeliciousTuning
I believe you are asking if our Flex Fuel Kit will work with other tuners/tunes? If so then yes they will work with other tuners using EcuTeK software.
Crackle is the small pops you get when you let off the throttle between shifts.
Pops & Bangs are designed to be above 4K and controlled by you right foot.
Regards,
William
sroby (03-18-2020)
Old 04-17-2020, 07:04 AM   #1204
Eazy-V
Regards,
William
I already have another flex fuel/sensor kit on my FI FRS, so will that work with your flex fuel tunes?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
