12-31-2018, 03:36 AM | #113 |
When are you getting the SC installed?
2013 Series 10 FRS #553
12-31-2018, 11:10 AM | #114 |
Drives: 2014 Subaru Forester
12-31-2018, 12:28 PM | #115 |
Drives: 2017 BRZ (Sold), 2023 GR86
Let's just say I have a certain time I told myself I would hit at RMP before installing the JRSC. I'm hoping for early summer.
The factory paint made it worth the expensive shipping. You can actually pop the existing caps off quite easily with your hands. I started with clips closest to the windows and worked my way out from there. Takes just a few minutes start to finish. |
The Following User Says Thank You to mistople For This Useful Post: | new2subaru (12-31-2018) |
12-31-2018, 12:46 PM | #116 | |
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to jflogerzi For This Useful Post: | mistople (12-31-2018) |
12-31-2018, 10:02 PM | #117 | |
Drives: Crapcan
I may stay NA a while longer too, that will give me time to spread out buying the supporting mods over a longer period. Plus I think a mid season changeover will be better then coming out of the winter cold and tracking the car with way more power. |
01-02-2019, 03:43 PM | #118 | |
The Following User Says Thank You to mistople For This Useful Post: | NoHaveMSG (01-02-2019) |
02-12-2019, 12:41 PM | #119 |
Not much car news to report given the weather up here lately. I have however signed up for an initial set of track dates for the upcoming season. Hoping to get to at least 10 events this year.
March 24: Pacific Raceways w/ ProFormance Driving School April 5: Ridge Motorsports Park w/ Hooked on Driving May 25: Ridge Motorsports Park w/ Turn2 June 14: Ridge Motorsports Park w/ Turn2 July 19: Ridge Motorsports Park w/ Turn2 August 13: Ridge Motorsports Park w/ Turn2 Last edited by mistople; 02-20-2019 at 10:53 AM. |
02-12-2019, 05:05 PM | #120 | |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
The Following User Says Thank You to Elliotw For This Useful Post: | NoHaveMSG (02-24-2019) |
02-14-2019, 11:53 AM | #121 |
02-17-2019, 10:14 PM | #122 |
Drives: Crapcan
Damn that's a lot of track days. I am just shooting for 6 again, and at least one new track and will likely head south for at least 1 86cup. I am going to give autoX another go this year as well since it is a lot less money for a bit of seat time. I am thinking about keeping my car NA all year now and just doing a winter build next year as I still have some lofty NA goals. You, KCH and I really need to make sure we hit up a couple days together and run the same class. We are all pretty close in speed.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | kch (02-19-2019) |
02-18-2019, 04:48 PM | #123 | |
Definitely looking forward to running with you guys again. I think I'll finally move up a group after the first few sessions in March. Can't wait to get back out there and keep learning. This year I'll come prepared with an AiM Solo and a proper pyrometer. |
02-19-2019, 06:37 PM | #124 | ||
Senior Misanthrope
I plan to register for some Turn2 events, and I'm currently registered for a TSS event at Ridge on June 23. This year I'll have some shiny new SPL parts to dial-in, so that's exciting. Still trying to figure out what tire I want, though. Leaning towards Z3s again. Back in Texas I could get 24+ days per year. That's just not possible anymore. |
02-23-2019, 04:34 PM | #125 |
Longacre Accutech Deluxe Pyrometer + Fresh alignment
I picked up a Longacre pyrometer to help with car setup this year. Really looking forward to dialing in pressures and future alignments with this.
Having bought a nice Longacre tire pressure gauge last year, I was glad to see that they include a case for their pyros as well. It's a nice touch. I also had Doug at Chase Race do a fresh alignment the other week in preparation for an upcoming track day on 3/24. After resetting the ride height to the recommended spec, I was amazed to see that the rear camber was still sitting dead even at -2.4 on both sides. At this point I still haven't found the need to buy aftermarket LCAs. I decided to stick with the same alignment spec as last season until I have more data to know if I need a change. The car is relatively neutral as is. It has a slight lean towards understeer but I'll keep playing with damper settings and pressures before changing the alignment. I think I'm starting to prefer a looser car so we'll see how things go for the first few events. |
The Following 2 Users Say Thank You to mistople For This Useful Post: | Code Monkey (02-23-2019), NoHaveMSG (02-24-2019) |
02-23-2019, 04:57 PM | #126 |
Really loving this build! I might have missed it but, what camera are you shooting with?
Similar Threads | ||||
2017 BRZ Performance Package DD Build | mjanmohammad | Member's Car Journals | 230 | 11-01-2023 12:31 PM |
QueenBRZ's 17' BRZ performance package DD / track build | QueenBRZ | Member's Car Journals | 125 | 06-29-2021 01:34 PM |
Spicy.Ricecake's 2017 CWP BRZ PP Build | spicyricecake | Member's Car Journals | 115 | 12-15-2019 07:42 PM |
Ohlins Road & Track - settings (clicks) for street/track/ax | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-27-2016 09:36 PM |
MVP Track Time 2014 Road Atlanta Track Dates | Feffman | Southeast | 2 | 03-27-2014 06:51 AM |
