RR Racing
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Software Tuning
Old 11-13-2019, 01:25 PM   #15
tomm.brz
Drives: brz 2017
@Rezi
you asked me how to get it in ecutek
i took a stock map as example, if you want ghost cam in Map 4 you do something like this:
there is a little bug that after the engine is started and you enable it, only exhhaust cam go to retarded value
but then you just have to touch the throttle even minimally and also the intake cam will advance and creates more overlap
also raise idle to at least 900-950 and play with idle timings if necessary
do this by yourself, i won't take any responsability
gt7877 (11-14-2019)
Old 11-14-2019, 03:21 AM   #16
gt7877
Drives: turbo frs
But this tune is it effects oil pressure ??
This can coze crankshaft engine damge after some time
Correct me if I'm wrong�
gt7877 is offline   Reply With Quote
Old 11-14-2019, 05:37 AM   #17
tomm.brz
Drives: brz 2017
that's why I said to take your own responsability
better to have an oil pressure sensor hooked up possibly to the ecu so you can always check it and possibly set up failsafe custom maps
gt7877 (11-14-2019)
Old 11-14-2019, 07:37 AM   #18
solidsnake11
Drives: brz
The oil galleries are pretty small in the vvt. Pretty sure it will not effect oil pressure. From what I see it only uses oil during timing changes, not continuously.
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
gt7877 (11-14-2019)
Old 11-14-2019, 11:38 AM   #19
gt7877
Drives: turbo frs
Originally Posted by tomm.brz View Post
@Rezi
I think this can be done at OFT ROMs at BASE TIMING A coze this used before vvt open
Correct me 😁
Old 11-14-2019, 11:40 AM   #20
tomm.brz
Drives: brz 2017
Absolutely not, it wont move from 0 with oft without a specific patch
Also ignition timings have nothing to do with cam timing tables
gt7877 (11-14-2019)
Old 11-14-2019, 01:23 PM   #21
toast
Drives: 14 BSP Edelbrock BRZ
If someone throws a big ass wing on a stock car it is called 'rice'. We need a word that is similarly-insulting for purposely making your car idle like shit and waste gas.
toast is offline   Reply With Quote
Old 11-14-2019, 02:15 PM   #22
solidsnake11
Drives: brz
Please post your car and mods so I can find something about your car that I don't like. Then I can come up with a word for your car.
The Following 2 Users Say Thank You to solidsnake11 For This Useful Post:
DarkPira7e (11-25-2019), tomm.brz (11-14-2019)
Old 11-14-2019, 03:21 PM   #23
toast
lol. My wheels are Bronze, you should start with that.
Ghost Cam Idle wizzo Software Tuning 25 08-07-2017 12:04 AM
Ghost of Akina's 2013 Firestorm FRS Ghost of Akina Member's Car Journals 3 08-22-2015 01:51 AM
Ghost Car/Dad vividracing Off-Topic Lounge 4 07-23-2014 05:51 PM
Ghost Lights DuroSquad Cosmetic Modification (Interior/Exterior/Lighting) 7 07-04-2014 07:14 AM
Ghost's BRZ Build RurumariGhost NY / NJ / CT / PA 5 05-23-2013 09:31 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
