Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-28-2014, 12:01 PM | #99 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
So what exactly is the pros/cons of using the 16mm whiteline bolts in the upper hole (for 35$) vs instead using the 14mm SPC bolts (25$) in the lower?
Does one set offer more total -camber than the other? Is one "safer" than the other assuming they are both at max setting? I have an order including the 14mms from frsspeedfactory but I'm thinking I should switch to the 16mm uppers. But they know more than I do. |
04-11-2014, 09:55 AM | #100 |
Drives: Sc10n Series FR-S
Using these adjustable one what would be a good setting on them for stock suspension height?
I figure as long as you smile while driving the car, you're doing it right.
01-19-2016, 06:11 AM | #101 |
Drives: PEARL WHITE GT86 TRD
I'm also curious about this.
01-29-2016, 10:47 PM | #102 |
Drives: 2013 Fr-s
Hey guys ,
I'm a newbie at this, but When i put in the whiteline bolts, I just put them in the lower hole? if so , what is with the camber plates? is that a different way to camber your front? It seem so , i've been reading through the forums and I probably sound like a dumbass but with the bolts, since it goes on the lower hole, do i leave the upper bolts the way it is and just negative the bottom and it'll camber my front? Lastly , what is better? Camber plates or just bolts? I feel kinda iffy, with bolts . since camber plates seem to hold better then bolts, am i wrong? |
02-08-2016, 04:51 PM | #103 |
Drives: Toyota GT86
I got these 16 mm Whiteline camber bolts (Whiteline sealed bag, but has SPC stamped on them).
Is the square plate in the middle of the picture supposed to be used? It doesn't figure in the illustrations. The bolts were depicted in black on the reseller website. Is it normal for the Whiteline bolts to come in raw finish like this? Doesn't seem like a very resistant finish. Third question. Should the bolts be tightened to 125 lb-ft or 83 lb-ft!!!? (second picture 125 on the plastic bag and 83 on the paper instruction (KCA416). Last edited by Tor; 02-08-2016 at 05:02 PM. |
02-08-2016, 07:29 PM | #104 | ||
I'm no expert but the fastest way to find the right answer on the internet is to post a wrong one so anyone feel free to correct :P
Camber plates can offer more camber on this car, usually adding about -2 degrees or more of camber (or about 0.5 or more positive camber) and are easy to adjust on the fly to dial in your setup. More importantly, for maximum grip the car seems to like more than -3 degrees of camber (I've heard claims of -3.5 from a few different people) which isn't attainable with just one method to my knowledge so most aggressively setup cars will be running both bolts and plates with the exception of coilovers which may have additional camber adjustment or more negative camber built into the struts. What's better? I don't know, it's situational, just like a Lotus Elise is not better than an 86 for transporting 4 people. If it's a casual car that sees mostly daily driving, tire wear is a concern, the owner does not want to adjust things and keep an eye to exposed camber plates that can get dirty, wear out quicker and begin to make noise after heavy use, the bolts should be hassle free and can be installed and aligned by any shop worth it's salt without breaking the bank and keeping the front camber to <-1.5 degrees should have almost no impact to tire life. I think your fears about the bolts are not unfounded, they absolutely can slip and throw your camber out of whack but I haven't seen anyone post a situation like that around here and mine have been great for the past year of daily use. IMO if you're going to spend extra money on the camber plates they only become worth the money if you're using them to extract every ounce of grip from the car, you'll probably end up with bolts and/or coilovers anyway. Or it's for looks then idk do whatever's prettiest. Quote:
Mine were also raw as are most that I've seen, no significant corrosion but my climate is very mild so ymmv. There might be some sort of protection you can spray on but that won't save the exposed threads so idk. I don't remember at all what I set them to but I doubt 125 would be an issue, mine felt pretty beefy (I believe 16mm variant as well, top hole only fitment). Could always try 83 see how confident you feel in the tightness and then slowly build up to 125. Or check the shop manual and copy what it says: http://www.ft86club.com/forums/showthread.php?t=8374 |
The Following User Says Thank You to strat61caster For This Useful Post: | Tor (02-08-2016) |
02-08-2016, 07:29 PM | #105 | |
The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post: | strat61caster (02-08-2016), Tor (02-08-2016) |
02-08-2016, 10:02 PM | #106 |
Drives: Toyota GT86
Thanks for the replies. I'll skip the square piece and torque it to 125 lb-ft.
02-20-2017, 07:44 AM | #107 |
Drives: 2014 Scion FR-S
So, just to clarify because the thread jumped around a bit.... if I am to use the pair of oem crash bolts, they go in the upper, NOT lower hole on the strut, correct?
02-20-2017, 08:16 AM | #108 |
Drives: 2014 GT86
Lower hole 14mm, upper 16mm. Obviously to gain some play for adjustment by only using oem bolts, one needs to relocate oem "camber" bolt (normal bolt of 14mm size) from smaller lower hole to larger upper one.
02-20-2017, 11:54 AM | #109 | |
If you put them in the lower hole you will not see any change to your alignment as they are the exact same bolt. The upper hole is a larger size, putting a smaller bolt in it allows for camber adjustment. |
05-06-2017, 08:33 PM | #111 |
Drives: 86 GTS
I'm looking at getting these and from what I'm reading, SPC seem to make them for everyone
http://www.ebay.com.au/itm/251742184...%3AMEBIDX%3AIT |
05-06-2017, 08:41 PM | #112 |
Drives: 2013 Subaru BRZ
Whiteline claim their washer lock tab prevents the crash bolts from turning once torqued up. That would be worth the $10.
The size of the bolt is related to its strength. The bolts have an eccentric cam on the bolt body. The bolt itself needs to be strong enough to resist bending induced by the eccentric. |
Similar Threads | ||||
Installed coilover; Too much camber in the back. | trueno86power | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 69 | 04-11-2016 07:00 AM |
BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
Camber plates | Captain Snooze | AUSTRALIA | 7 | 07-02-2012 06:51 PM |
Camber arms? | skoodge | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 06-24-2012 10:09 PM |
Excessive negative camber? | MTeator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-22-2012 10:30 AM |
