01-07-2017, 10:04 AM | #211 | |
Drives: '13 SWP GT86
IG @squareddesign
http://www.squareddesign.se |
01-07-2017, 07:55 PM | #212 |
Drives: 2014 Silver BRZ
01-08-2017, 09:56 AM | #213 |
Front will probably have a slight stretch, but still look meaty since R888 are fat tires, and 40 profile. Rears will be pretty square, so meaty as well.
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post: | fizzymike (01-13-2017) |
01-20-2017, 01:31 PM | #214 |
Drives: 2015 FR-S
18x10.5 -13 Front
18x11.5 -26 Rear Tires will be stretched accordingly. Hoping not massive camber, like -3 to -5 F/R. On V1 fenders, and coilovers as low as will allow with this fitment. I want flush as can be, or maybe a very slight poke. According to calculators, the rear seems totally fine, but it's the front I'm not 100% on. What do you guys think? |
01-21-2017, 04:57 PM | #215 |
so I plan on going wheels first before fenders. Will a 18x10 -7 front and 18x11 -25-30 rub when turning on the stock fenders? I know this sounds stupid and everything should be done at once but is this a bad idea?
01-23-2017, 11:20 AM | #216 |
Drives: Scion frs
Toyota r888 275/35/18 on 18x10.5 +30 squared. I have a 25mm spacer on the rear and a 22mm spacer on the front. Rear sits perfect. Couldn't be happier about that. The front rubs a ton. Barely can turn without the tire crushing the fender liner. Any suggestions for tires sizes up front to prevent rubbing in front and behind the face of the tire? It's practically touching the front bumper as you can see from the last picture |
The Following User Says Thank You to JarredH For This Useful Post: | DustinS (01-28-2017) |
01-25-2017, 08:57 AM | #217 |
Drives: 2015 FR-S
Cut the fender liner and bumper? Those tires are huge though. If you don't want to run stretched then you'll just have to adjust other things like ride height, caster, camber, etc.
01-25-2017, 11:49 AM | #218 | |
I mean you could get the wheels on stock fenders, but you would have to run stock height so they dont hit your fenders lol. What kind of wheels were you looking at? Maybe I can help? |
01-27-2017, 08:30 AM | #219 | |
First the guy asking if 17x8 +40 is a good fit for RB fenders, now someone who wants to fit 18x11 -30 without a kit... I've seen it all!
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post: | Tcoat (02-01-2017) |
01-28-2017, 12:45 AM | #220 |
Drives: 2014 GT86
Given thick enough spacers (i guess, 500mm should do), you can forget about rubbing issues with any wheel! Well .. maybe steering angle in front also should be limited, but that's minor issue
01-31-2017, 10:47 AM | #221 | |
Drives: 2013 Ultramarine FR-S
I am showing a 18x10.5 et10 should be flush which is what I am going to shoot for. Then clearance the car for a 285 and eventually a 315.
02-01-2017, 09:18 AM | #222 |
Drives: '14 Red Toyota GT86 RocketBunny
ordered these.
will post pics when they arrive. http://www.ravspec.com/shop/te37v5100gb 18×9.5 -15mm 5×100 18×11.0 -8mm 5×100
'14 Toyota GT86 - 2JZ GTE - R154 - GTX3582R 1.06 - Motec M130 PNP - RocketBunny v1
'09 Audi RS6 C6 - MTM 850HP |
02-01-2017, 01:30 PM | #223 |
And people wonder why I lose my shit every now and again?
02-02-2017, 02:21 AM | #224 |
Right, but you'd go crazy either way, seeing how much you're here
Closing in on 35k posts.. You've lost your shit a long time ago
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post: | Tcoat (02-02-2017) |
Similar Threads | ||||
Replica rocket bunny | crildz | Cosmetic Modification (Interior/Exterior/Lighting) | 103 | 05-09-2014 04:35 PM |
Rocket Bunny FRS in Dubai | TAP Auto Parts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 49 | 12-04-2012 01:39 PM |
Red Rocket Bunny FR-S - Speedhunters | RaceR | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-12-2012 12:48 AM |
Rocket Bunny or Modelista? HELP!!! | ShowstoppersUSA | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-16-2012 01:23 PM |
GReddy/Rocket Bunny Wheels? | Coultergeist | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-15-2012 02:39 AM |
