05-11-2019, 09:04 PM | #127 |
Drives: LS Swapped Scion FRS = 440HP
Clean pass with my new GoPro:
SEND IT:
The Following 5 Users Say Thank You to spitsnaugle For This Useful Post: | Axis2011KR (06-13-2019), DAEMANO (06-22-2019), gtpvette (05-12-2019), TofuJoe (06-17-2019), Zer0 (05-12-2019) |
05-12-2019, 02:56 AM | #128 |
Drives: 2015 frs
How does it feel swaped compared to the original engine configuration handling wise? Obviously the torque dip has been fixed lol
05-12-2019, 10:37 AM | #129 |
I made some very significant changes all at once with coilovers but with that in mind, its still very balanced.
The Following User Says Thank You to spitsnaugle For This Useful Post: | Zer0 (05-12-2019) |
05-12-2019, 05:37 PM | #130 |
Drives: 16' BRZ
05-12-2019, 06:51 PM | #131 | |
Here is a more recent autocross run, struggling with some loose gravel, but was a fun run with a fellow BRZ owner riding shotgun, he provides his feedback after the run:
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post: | Sportsguy83 (06-17-2019), Zer0 (05-13-2019) |
06-17-2019, 12:56 PM | #132 |
I'm dragging the rev limiter too much around autocross.
Bought a used 3.73 M85 rear diff. Hoping it keeps the engine a little happier, but if not I'll use it temporarily hold me while I swap my original to 3.55. I've calculated the top speeds per gear for two T56 variants and have included it here, and in my first post for future reference. All shift points at safe-ish 5500rpm (because thats the max I'm comfortable sustaining in a straight), though I'll push 6k to shift. http://tremec.com/calculadora.php
06-17-2019, 02:56 PM | #133 |
Where are you finding the rear gear options? I need to do some research on that for myself.
06-17-2019, 03:06 PM | #134 |
I just got my 2001-05 Lexus IS300 m85 3.73 LSD rear end off of a member here, currently two are on ebay ($700). They're a direct swap.
Nitro Gears makes 3.73 and 3.58 for the toyota rear end. Would require a new New 29 spline Flange (ours is 60x60mm) ($350 for both, might need shims?) Best prices I've found at JustDifferentials linked in the text just above. I dont have experience rebuilding rear ends so I went with the m85 to start with.
06-17-2019, 03:16 PM | #135 |
Drives: 2015 FRS - FFR GTM
Got a quote earlier this year from Just to swap in a 3.53 in my diff that I shipped to them. $938 Seemed like a good price to me.
2015 FR-S - One Day I'll Finish The Swap |
06-17-2019, 10:12 PM | #136 | |
Drives: 16' BRZ
If you’re shifting at 5500 RPM I think you might want the 3.55 rear. I went 3.73 but my engine was built to rev a bit higher. 2nd gear at 7K RPM should equal 78.5 MPH. I don’t think I’ll be going faster than 75 MPH which should be 6700 RPM so hopefully no need for 3rd gear. My rev limiter is all the way at 7400 RPM but I’ll shift before 7K RPM and power slowly starts to drop off after 6600 RPM |
06-20-2019, 01:20 PM | #137 | |
The three local groups I run with- the courses are pretty tight/technical. I'm hoping to expand out a bit more to some larger events to open the car up more. I'm planning on attending LS-fest this september, likely running the road course and autox https://www.lsfest.com/bowling-green/ I do shift around 6k or so, but I used 5500 as its what I'd consider my max sustained straight RPM. I installed the M85 IS300 3.73 rear end last night. Went pretty smooth, took about 45 minutes. It was raining last night and this morning or else I'd be testing it out on the road, will report back once its rolling. If it is not enough, I may use this as a temporary stepping stone while I rebuild mine to 3.55.
The Following User Says Thank You to spitsnaugle For This Useful Post: | Sportsguy83 (06-20-2019) |
06-21-2019, 03:39 PM | #138 | |
Update: I've been driving this 3.73 on the road now for a bit, I like it a whole bunch better than the original 4.11. However I dont think second gear is where I want it yet for autocrossing. I'm going to send my original rear to get built at 3.55, then sell this 3.73.
06-21-2019, 03:58 PM | #139 | |
Drives: Red BRZ
Sent from my SM-G950U using Tapatalk |
06-21-2019, 06:01 PM | #140 |
Drives: 2013 frs red
That thing is nice! If I gut my cats and install lightweight pulleys, will my car run like that?
Tags |
cx racing, ls swap, ls2, pure automotive |
Similar Threads | ||||
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP | ILLSMOQ | Engine Swaps | 172 | 11-24-2022 07:01 PM |
LS2 swap by KAB Customs with Pure Automotive Motec | Sportsguy83 | Engine Swaps | 254 | 10-17-2018 12:45 PM |
Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 11:10 AM |
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Engine, Exhaust, Transmission | 23 | 05-15-2016 04:21 PM |
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 9 | 01-31-2013 01:03 AM |
