Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-05-2018, 08:38 PM | #43 |
It could be but it's not. I honestly don't know what to say when someone when weight and chassis flex are good for any car.
Drive upgrades. Don't buy them.
04-05-2018, 08:48 PM | #44 | |
Does stiffening up the front of the chassis add positive turn in response? Yes of course it does. But just like everything in motorsports, it’s another compromise you will have to deal with. As an experiment you should take out your oem steel v bars, and run over a crappy part of the road and tell me it doesn’t feel more comfortable. |
04-06-2018, 06:24 PM | #45 | |
Drives: 2019 Mazda Miata RF
The Following 5 Users Say Thank You to Gunman For This Useful Post: | Captain Snooze (10-03-2021), fuddbutter (10-24-2019), NoHaveMSG (04-06-2018), Spuds (04-08-2018), SuperTom (05-19-2018) |
04-06-2018, 10:27 PM | #46 |
Drives: 17 DGM BRZ Limited
04-07-2018, 07:49 PM | #47 |
I suspect lighten your wallet, but that is just because they make no claims.
https://www.gtspec.com/product/gtspe...-s-gt86-ft-86/ |
04-08-2018, 10:07 AM | #48 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Don't get crazy with braces to bushings. yes if you do a bunch you can transform your car like I did with my 04 WRX wagon. But as a DD you feel it everyday. It comes at a price. The BRZ probably does not need much as its got a nice feel stock for DD. If you track well then everything is on the table if it makes the car handle better.
The Following User Says Thank You to Ernest72 For This Useful Post: | why? (10-18-2019) |
04-09-2018, 11:14 AM | #49 | |
StreetKart
Drives: 2014 Scion FR-S Monogram
some older JDM cars the floor plans flexed like hell and they really could use seat rail bracing... not like that but they could use something.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
The Following User Says Thank You to Roadcone For This Useful Post: | Tristor (04-09-2018) |
04-12-2018, 06:11 PM | #50 |
Drives: 2013 BRZ Premium
I believe some bracing has its performance benefits, but of course will create more NVH. So it is up to you on how much, and what you want to brace. For the majority of driving I do, I can most certainly feel a difference in the way the car handles, and I feel that it is a big improvement. I personally like the chassis to be stiff, and don't mind the "discomfort" of daily driving with the braces. I actually decided to make most of the braces myself, not as pretty looking as what is available online, but I also did not want to end up spending $1k+ in just bracing. I also was having a very hard trying to find a good trunk/X-Brace online, so I decided to fabricate my own. I attached a photo of my DIY X-Brace
So far I have added bracing to : Both front and rear strut towers X-Brace inside of trunk Rear subframe upper brace Rear lower control arm braces Front lower control arm brace & front side subframe brace Steering rack lockdown & rear side front subframe brace Master cylinder brace |
The Following 3 Users Say Thank You to slacker221 For This Useful Post: |
04-12-2018, 06:17 PM | #51 |
Weight Weenie
Drives: 15 FR-S
^Nice job man!
The Following User Says Thank You to new2subaru For This Useful Post: | slacker221 (04-13-2018) |
04-13-2018, 10:43 AM | #52 |
Drives: 2017 Subaru BRZ Limited
That looks great slacker. I wish there was a solid commercial option like this that I could use.
The Following User Says Thank You to Tristor For This Useful Post: | slacker221 (04-13-2018) |
04-13-2018, 11:52 AM | #53 | |
and D2D has this, but it's not triangulated. http://d2bdmotorwerks.com/i-16297967...werks-com.html |
The Following User Says Thank You to Gunman For This Useful Post: | Tristor (04-13-2018) |
04-13-2018, 11:59 AM | #54 |
I've never bought braces outside of cars designed in the 80s but I feel like they would reduce nvh since they eliminate the flex that causes random squeaks and rattles.
04-13-2018, 03:17 PM | #55 | |
That Spencer design looks perfect and even appears to be compatible in this photo with the Shrader Performance rear seat delete (with maybe some minor modification). I'd be very interested in acquiring one of those. I know Spencer Fabrications has shut down, but I went ahead and emailed them at the last known good address to see if I can get a reply. The D2D setup isn't really what I'm looking for. |
The Following User Says Thank You to Tristor For This Useful Post: | Gunman (04-13-2018) |
04-13-2018, 04:20 PM | #56 |
You’re right it’s not true NVH as there’s no addition noise or vibration like suspension mounts, but the H for harshness rings true.
Similar Threads | ||||
Agency Power Chassis Braces and Strut Bar? | megamarines | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-17-2015 10:23 PM |
DIY Lower Chassis Braces | vividracing | DIY (Do-It-Yourself) Guides | 0 | 04-08-2015 01:30 PM |
TB Performance Products Chassis Braces | TB Performance Products | Brakes, Suspension, Chassis | 6 | 08-20-2013 07:58 PM |
Carbing Chassis Braces | ttknf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 08-14-2012 09:21 PM |
Coilovers, swaybars, chassis braces and more! | No Limit Motorsport | Brakes, Suspension, Chassis | 0 | 08-05-2012 11:31 AM |
