Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-14-2012, 05:43 PM | #15 |
Driving Coach
Cool, I may have to switch intakes if it's too difficult to fit with the Airaid on. Perhaps a slightly taller adapter and then a flat oil filler cap would give enough room to have the fittings and lines right over the cap, but then filling the oil would be.... difficult.
09-14-2012, 05:44 PM | #16 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Chris, any chance you need more warm weather track whore testers?
09-14-2012, 05:52 PM | #17 |
09-14-2012, 05:53 PM | #18 |
Driving Coach
Maybe this would work?
Excuse my shitty mspaint skills |
09-14-2012, 06:19 PM | #19 |
El Presidente
Drives: it like I stole it!
Any options in the works for those running an FMIC?
The Following User Says Thank You to Apex Chase For This Useful Post: | usptwins (09-14-2012) |
09-14-2012, 06:29 PM | #20 |
09-14-2012, 07:37 PM | #21 |
Drives: 2013 Scion FR-S Raven
Can we index the adaptor?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
09-14-2012, 07:52 PM | #22 |
Drives: Raven Black
So how much does this actually cool the oil temp down?
09-14-2012, 08:05 PM | #23 |
Great question!
The Following 2 Users Say Thank You to tonystewart For This Useful Post: | CBR600RR (09-14-2012), whataboutbob (09-15-2012) |
09-14-2012, 10:06 PM | #24 |
Drives: 2013 FR-S Blue MT
Is there a thermostat?
09-14-2012, 11:33 PM | #25 |
Drives: 05 GDB, 97 GF8
09-14-2012, 11:44 PM | #26 |
Drives: JDM LN130 Toyota Hilux Surf
looks great. very tidy.
also a vote for an off centre mount. and a question: if the stock oil filter has that 'cup' underneath it to avoid oil spills when changing the filter. does the sandwich adaptor get in the way at all? what I mean is, or suggest is; would it be a reasonable/necessary idea to implement another cup/tray on top of the sandwich adaptor, so that it's more like the original design, without interruption? but if it's not needed, then all the better! hope that makes sense. cheers |
09-15-2012, 12:54 AM | #27 |
Drives: DGM BRZ Limited
The oil filter o-ring should seal towards the inside of the adapter, any residual oil should have drained down from the center when you remove the filter. Correct me if I'm wrong, but it seems the outside of the adapter will mate to the outside of the filter, but the o-ring seals towards the inside.
Look at this pic to see what I mean: |
09-15-2012, 05:32 AM | #28 |
Because compromise ®
Drives: Red Herring
@PERRIN_Chris,
Call me old fashioned,skeptical,Luddite,scared,no idea what I'm talking about, all of the above but could you please re-assure me about these clampless oil hoses? The concept fills me with trepidation. |
The Following User Says Thank You to Captain Snooze For This Useful Post: | gmookher (09-15-2012) |
Similar Threads | ||||
Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
Got my AGP catback installed today!! | track_warrior | Engine, Exhaust, Transmission | 59 | 08-21-2012 08:10 PM |
Greddy oil cooler coming soon | DIG1992 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 08-20-2012 12:02 AM |
Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 12:55 AM |
