Old 02-03-2018, 04:03 PM   #71
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by Gunman View Post
@DocWalt Quantity of clips is high, you don't need 30, I just copied from someone else, and they got extras. Still have not purchased these myself.
Part No. Qty MSRP
56411CA000 UNDER COVER R RH 1 $82.45
56411CA010 UNDER COVER R LH 1 $82.45
42045CA020 PROTECTOR TANK RH 1 $18.18
42045CA030 PROTECTOR TANK LH 1 $18.18
909140065 CLIP 2PECE D8 30 $1.14
901000344 BOLT FLG 6X16 3 $1.02
909140007 CLIP BUMPER* 4 $2.47
Add this to the list of parts if you're doing this: 023508000 x 3 Flange nuts. $1.86 ea
And for sure don't need 30 of the 901000344 CLIP 2PIECE D8....18 at the most and that's if you don't reuse any of the originals.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Gunman (02-03-2018)
Old 02-03-2018, 05:03 PM   #72
Brink
Drives: 2017 BRZ
Im thinking about getting these - any idea if just putting one end of the car up on ramps would give enough space to install these, or am I going to need the whole car up in the air? I have some ramps that will give me 8" of lift at one end, wondering if I can just install these in my driveway or if I'll need to get it done at a shop.
Brink is offline   Reply With Quote
Old 02-03-2018, 05:13 PM   #73
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Since you can do the front and rear panels independent of each other, you may be able to do the fronts with the front wheels on ramps then the rears with the rear wheels on ramps. Put your car on ramps and slide under there to see if you have enough room to work.
Brink (02-03-2018)
Old 02-03-2018, 05:26 PM   #74
Brink
Drives: 2017 BRZ
I'll have to explore this a bit next time I put the car up, see how far under there I can comfortably work. I'll probably be doing some work on Wednesday so I can check it out then. In the middle of my work week now so I don't really have the time before then.
Old 02-03-2018, 05:28 PM   #75
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Better yet, use a second jack and lift the car from the side and set it down on the ramps and do one side at a time, I'll bet that's going to be much easier.
Gunman (02-03-2018)
Old 02-03-2018, 05:32 PM   #76
Brink
Drives: 2017 BRZ
Don't have a jack, just the ramps. They work pretty well for getting access to one end of the car or the other, but working more towards the middle I'm not sure if I'll have enough space.
Old 02-05-2018, 04:20 PM   #77
Shibby
Drives: 2013 WRB BRZ
Can the OP update the guide with pictures that aren't hosted on dog shit photobucket PLEASE?
Shibby is offline   Reply With Quote
Old 02-05-2018, 07:12 PM   #78
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
yeah sorry I'll try and get them up tonight-been swamped!
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Myriad (02-14-2018), Shibby (02-06-2018)
Old 02-05-2018, 07:18 PM   #79
monkeybike
Drives: 86
Or everyone can just use an extension on Chrome browser that fixes that problem themselves?!
monkeybike is offline   Reply With Quote
The Following 2 Users Say Thank You to monkeybike For This Useful Post:
BirdTRD (02-05-2018), Nails (02-06-2018)
Old 02-05-2018, 08:14 PM   #80
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Well I'll be damned! Photobucket Hotlink fix extension took care of it...I was wondering why there weren't more people screaming about this!
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
monkeybike (02-05-2018), Nails (02-06-2018)
Old 02-06-2018, 12:43 AM   #81
Shibby
EVERYONE SHOULD KNOW ABOUT THIS NICHE EXTENSION REEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Old 02-06-2018, 01:21 AM   #82
Brink
Drives: 2017 BRZ
But...Chrome never worked right for me on this computer for some reason. Always had some issue where if I closed the browser it wouldn't end the process so I couldn't launch it again, or it wouldn't even install properly to begin with or something. Tried it a few times, always had problems.
Old 09-10-2018, 08:39 PM   #83
86TOYO2k17
Drives: 2017 toyota 86
So I just did this install. One of the side push clips that are painted broke off into the underbody. Any ideas how to get it out? Probably going to be rattling around under there.
Old 09-10-2018, 10:49 PM   #84
Chuckls
Moutain Runner
the LH and RH on mine came off the tS Ripperoni.
Chuckls is offline   Reply With Quote
skid plate, underbody, underpanels
SoCal JDM Underpanels Set Groupbuy JDKane527 Southern California 109 10-31-2013 08:29 PM
FS: JDM OEM Underpanels (LI Local Pickup) Perihelion NY / NJ / CT / PA 30 07-26-2013 07:20 AM
SoCal JDM Underpanels Groupbuy Round 2 Trojan_SC Southern California 99 06-21-2013 12:35 AM
FS: JDM OEM Underpanels (LI, NY Local Pickup) Perihelion Exterior Parts (Aero, Lighting, Etc.) 8 05-09-2013 02:45 PM
Interest in JDM underpanels GB? sittinSideways Northwest 3 04-04-2013 12:57 AM
